POLO GTI 2006 Lower Arm Bushings
Posted: Wed Feb 12, 2020 1:13 pm
My regular garage suggested replacing Both Lower Front Arm Bushes on my Polo GTI 2006. I hear fitting the cupra rear bushings in combination with powerflex front bushings is a good decision. Thinking of replacing the whole arm and ball joint for reduced labor cost in the future.
I am going to order these parts after someone could nicely confirm the following parts will fit and are what I need
2X REAR BUSHINGS - https://www.darksidedevelopments.co.uk/ ... forms.html
2X CONSOLE BUSHING - https://www.powerflex.co.uk/product-det ... 13016.html
2X CONTROL ARM - https://www.autodoc.co.uk/triscan/7228988
Whilst I am confident I have the correct part for rear bushings, I am struggling to identify the front bushing part.
Are "front bushings" and "console bushings" interchangeable terms? I.E Could either part fit as a front bushing?
1. https://www.darksidedevelopments.co.uk/ ... ibiza.html
2. https://www.powerflex.co.uk/product-det ... 13016.html
As far as I'm aware the rear bush sits in the rear axle, and the console bush is in the arm itself?
Also, on 9n3 polos, does wishbone = lower arm? What is the difference between - Are they for different chassis?
1.https://www.autodoc.co.uk/ridex/13544685 &
2.https://www.autodoc.co.uk/ridex/13632573
Sorry for the long post, I hope this makes sense!
Regards,
Lochdawg
Regards,
Lochdawg
