Abs/esp light
Posted: Sun Oct 11, 2020 10:29 am
by Dan-g4
Hi guys, new here but having some issues with my girlfriends polo, 2007 1.4.
The abs light came on about 6 months ago, fault code comes up with 00290 rear left wheel speed sensor, so i replaced the sensor, not sorted, then the bearing and still not fixed! So I thought for the price I'll just try one more sensor but still no better off
Thinking of testing the wiring from front to back but not too sure where each sensor terminates at the abs module, does anyone have a diagram of that connector??
Any suggestions welcome!
Thanks, Dan
Re: Abs/esp light
Posted: Sun Nov 22, 2020 6:56 pm
by Dan-g4
Had a pro take a look, he says its the abs module
Is the module a straight swap or are they coded to each car??
Re: Abs/esp light
Posted: Sun Nov 22, 2020 8:46 pm
by iichel
just save the coding of the old module and copy it to the new module and you should be OK
