Hi all! I own a polo gti 2007 (9n3) and I started to have issues with the steering wheel. After a burned fuse on battery fuse box (in engine bay) Which I replaced everything went ok. After a month suddenly the steering ,esp and oil sensor lamps goes on and the steering was only mechanic. So I started looking around.the ecu OBD saw air sensor fault.I change it with the original part. After that the fault went off. Some days later again everything goes on again. We saw that the fuse No.7 (10A) was blown. I changed it and when I was about to start the engine it was blown again..I can not find any short circuit and the Steering ecu doesn't connect to OBD. It Sims to have some sort circuit somewhere but when the fuse No7 is out everything except steering,esp,oil sensor works fine. Please if anybody have experienced something like that give me some advice!!
Steering wheel ,Esp, oil sensor fault
- Drives: Polo gti 9n3
Re: Steering wheel ,Esp, oil sensor fault
Hi guys..just for the info all the trouble was from a bulb in the rear light that was short circuit.
