Retrofitting of Auto leveling headlight system (AFS) for Polo 6R
Drives: 6R becoming 6C. slowly.
Re: Retrofitting of Auto leveling headlight system (AFS) for Polo 6R
Post by iichel » Tue Aug 15, 2017 7:21 pm
sanders, where do you live in the netherlands? maybe you can have a go with my module?
sanders
Drives: 6r bluemotion tdi 1.2
Post by sanders » Tue Aug 15, 2017 8:07 pm
Yes I live in Enschede, but do you have a spare module?
sanders
Post by sanders » Tue Aug 15, 2017 8:11 pm
@Adam87,
Thanks for reply, don't have VCP so not able to reflash the AFS module.
Post by iichel » Tue Aug 15, 2017 8:16 pm
My parents live near Ommen, we could meet up when I'm around.
sanders
Post by sanders » Wed Aug 16, 2017 6:00 pm
Changed the module, and same results. Same fault codes in can gateway and headlight range
Post by iichel » Wed Aug 16, 2017 6:14 pm
try this coding: 0192000001000000
sanders
Post by sanders » Wed Aug 16, 2017 6:17 pm
Did this code maken no difference.
Drives: 6R TSI R-line ☺ '13
Post by ciclo » Wed Aug 16, 2017 8:01 pm
Some ideas:
Check the wiring again (meticulously) from the rear sensor to module 55.
Unplug the sensor connector and plug it in again.
Do the basic setting again.
sanders
Post by sanders » Wed Aug 16, 2017 8:10 pm
Thanks for the reply Ciclo, wil report back with my findings.
sanders
Post by sanders » Mon Aug 21, 2017 6:37 am
Checked the wiring but made no difference. Strange thing is that the gateway still comes with faultcode 01771??
Eduard
Drives: 6C
Post by Eduard » Wed Sep 13, 2017 9:57 am
Hello gents! Anyone here can help with some tips on where exactly does the afs wiring get inside the car from the sensor ?
Thanks!
Post by ciclo » Wed Sep 13, 2017 10:42 am
Eduard
Drives: 6C
Post by Eduard » Wed Sep 13, 2017 7:53 pm
Thanks buddy! iichel pmed me earlier, wires are now in place :)
benzinkopf
Drives: 1.2TSI 105HP DSG7
Post by benzinkopf » Tue Dec 26, 2017 2:37 am
Hi. this is my brake line bracket in the area for leveling sensor. Do i need to replace this brake bracket to fit in the leveling sensor ? because i tried to fit the sensor mounting, seems like its not right.
Post by ciclo » Tue Dec 26, 2017 4:48 am
