BCM Max PQ25, adaptation. Automatic lights. Skoda Citigo/VW Up!
Re: BCM Max PQ25, adaptation. Automatic lights. Skoda Citigo/VW Up!
Look at your inbox, I sent you my email address.
Once you have installed my wiring looms, the two new DRLs wires, the new BCM Max, the new light switch with AUTO function and the new H7 headlights with Led module, these are your new codings.
Note: don't enter the new codings until the previous work is done.
NEW BCM Max
New coding
6CB82B0000010000010806E42CEB86C073C0626C600330E1200000460000
NEW RLS
New coding
0728DD
Everything should work correctly.
NEW BCM Max
New coding
NEW RLS
New coding
0728DD
Static cornering lights for your Citigo
The problem to make work the SCLs in your Citigo is that we do not have a +30 power supply wire in your fusebox SC that is direct/come from the battery.
(It's the reason why I asked you about slot SC39
This battery power wire would go to fuse box (15A fuse) and from here to T73b/11 BCM white connector.
In your case this new 2,5mm2 wire from the battery to the fuse box / BCM must be absolutely new.
You can not take it under any circumstances from another existing +30 supply wire dedicated to other devices.
Now, apart:
Your current electrical installation (wires) for fog lamps is not correct for SCLs and foglights at the same time.
You have to make a new electric installation. You can't use the original existing wires.
How?
Signal. From the light switch connector to BCM, i.e, from T10/3 new red connector to T73a/7 BCM black connector. (0.5mm2)
Output. From BCM to the fog lights.
- From T73b / 9 to T2 / 1 Left fog light connector. T2 / 2 to ground. (1,5mm2)
- From T73b / 10 to T2 / 1 Right fog light connector. T2 / 2 to ground. (1,5mm2)
Now, apart:
How?
Hello,
thx for all, now it clear to me ... T2/2 ground on Fog light connector, I will let original ... So only one wire to each foglight ...
Nice day. Daniel
Nice day. Daniel
A new BCM coding is necessary in case you make this new electrical installation for the SCLs and foglights.
Please, let me know anything you need from me in this regard, thanks.
Thx, I will let you know when I am finished ... or if its possible to get codung before ... Nice day ciclo! Daniel
New BCM coding with SCLs installed (in addition to... click)
6CB82B0000010000010806E46CEB86C073C0626D608F30E1200000460000
Hello, thx a lot, I dont want to bother you no more, so next steps after your harness instalation. Many thanks ... Daniel
Hello ciclo, pls I saw that you mentioned Citigo/Up!/Mii Emergency Brake Button in your Polo thread ...
I already retrofited Emergency Brake and nondirect TMPS ( via ABS ) but dont know where it must be activated.
Buttons via VCDS are working, harness is OK - exactly as in original ...
Emergency brake is on in cluster adaptations but unit throw error that external module is incorectly coded ... BUt I dont know where ... IN BCM? In ABS? VCDS has limited labels for this ...
My scan, can you pls help me ...
Nice day to Spain!
Daniel
Nice day to Spain!
Daniel
Sunday,10,September,2017,19:48:22:61091
VCDS Version: 17.1.3.0
Data version: 20170320 DS267.7
www.Ross-Tech.com
Dealer/Shop Name: DD
Workshop Code: 123 12345 012345
VIN: TMBZZZAAZDD615614 License Plate:
Mileage: 60780km-37766mi Repair Order:
Chassis Type: AA (1S0)
Scan: 01 03 09 10 15 17 19 25 44 56 AD
VIN: TMBZZZAAZDD615614 Mileage: 60780km-37766miles
56-Radio -- Status: OK 0000
AD-Brake Sensors -- Status: Malfunction 0010
Address 01: Engine (J623-CHYA) Labels: 04C-906-020-CHY.clb
Part No SW: 04C 906 020 K HW: 04C 907 309 D
Component: 1.0l R3 MPI H01 6470
Revision: U7H01--- Serial number:
Coding: 00110012022400000000
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_ECM10MPI01104C906020K 001010
ROD: EV_ECM10MPI01104C906020.rod
VCID: 23449CE433205256DD-8076
Readiness: 1110 0101
Address 03: ABS Brakes (J104) Labels: 1S0-614-517.clb
Part No SW: 1S0 614 517 F HW: 1S0 614 517 F
Component: EBC 460 ESP H16 0022
Serial number: A00QBIZ
Coding: 32BF247129AE02F64C0024F694AD4040590100
Shop #: WSC 57334 002 1048576
ASAM Dataset: EV_Brake1ESPEBC460TRW 002004
ROD: EV_Brake1ESPEBC460TRW_VW12.rod
VCID: 32577AD97FF7E83F45-8066
Address 09: Cent. Elect. (J519) Labels: 1S0-937-08x-09.clb
Part No SW: 1S0 937 090 F HW: 1S0 937 090
Component: BCM PQ25 1MX4 H81 0744
Revision: BW081001 Serial number: 0978 133170077
Coding: 6CB82B0000010000000800042C28A6C000C0400C60020000200000400000
VCID: 365372AD67C3C0DB25-8062
Subsystem 1 - Part No: 5K7 955 559 B Labels: 5K7-955-559.CLB
Component: RLS 111115 03 37 0059
Coding: 0080DD
Subsystem 2 - Part No SW: 5E0 919 719 L HW: 5E0 919 719 L
Component: E221__MFL-PR6 H02 0160
Serial number: 000000000B0452131116
Coding: 820000
3 Faults Found:
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 1
Mileage: 60787 km
Time Indication: 0
Date: 2017.09.10
Time: 04:19:02
03432 - Activation of Right Parking Light
011 - Open Circuit
Fault Priority: 2
Fault Frequency: 1
Reset counter: 1
Mileage: 60787 km
Time Indication: 0
Date: 2017.09.10
Time: 04:19:02
01516 - Terminal 30; Left
011 - Open Circuit
Fault Priority: 2
Fault Frequency: 1
Reset counter: 1
Mileage: 60787 km
Time Indication: 0
Date: 2017.09.10
Time: 04:19:02
Address 10: Park/Steer Assist (J446) Labels: 1Sx-919-475.clb
Part No SW: 1ST 919 475 HW: 1Q0 919 475
Component: PARKHILFE 3K H03 0005
Revision: -------- Serial number: 32901224704087
Coding: 100001
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_EPHVA14SK1200000 001001
ROD: EV_EPHVA14SE1200000.rod
VCID: 1B3CAC1C1348629E1D-804E
Part No SW: 1S0 959 655 HW: 1S0 959 655
Component: VW10Airbag00E H03 0005
Revision: -------- Serial number: 003G3004KBR+
Coding: 000000000000000000000000000000003045
ASAM Dataset: EV_AirbaVW10BPAVW12X 001001
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 7B9CECFC9368A23E1D-802E
Serial number: 3495RRB40591GLOMAGHG
Serial number: 3505RRB405J1GLOOE0C3
Serial number: 3555NRB405R1HA3O6P8.
Address 17: Instruments (J285) Labels: 1Sx-920-xxx-17.clb
Part No SW: 1ST 920 860 Q HW: 1ST 920 860 Q
Component: KOMBI H09 0021
Revision: X0009005 Serial number: 00000000000000
Coding: 114A00
ASAM Dataset: EV_KombiUDSMM9RM10 A04708
ROD: EV_KombiUDSMM9RM10_A04_VW12.rod
VCID: 62871A293FE7C88FC5-8036
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 1S0 909 901 HW: 1S0 937 090
Component: GW-K-CAN TP20 H81 0744
Revision: BW081001
Coding: 002000
VCID: 708906034FA11C6D75-8024
Part No SW: 5K0 953 234 HW: 1ST 920 860 Q
Component: IMMO H09 0021
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
ROD: EV_ImmoUDSMM9RM10_VW01.rod
VCID: 6A8F0A315FDF384785-803E
Address 44: Steering Assist (J792) Labels: 1Sx-909-144-44.clb
Part No SW: 1S1 909 144 G HW: 1S1 909 144 G
Component: EPS_ECU H30 1503
Coding: 0001000101000000
ASAM Dataset: EV_SteerAssisNSK 009004
ROD: EV_SteerAssisNSK_009.rod
VCID: 375074A863DCCAE23D-8062
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1ST 035 156 A HW: 1ST 035 156 A
Component: Radio H35 0050
Revision: R0000000 Serial number: SKZAZ1M3007678
Coding: 0000020801
VCID: 4D6A406AC34E4E786D-8018
Address AD: Brake Sensors (J939) Labels: 1S0-907-201.clb
Part No SW: 1S0 907 201 A HW: 1S0 907 201 A
Component: CV-SENSOR H06 0460
ASAM Dataset: EV_CVSen 001001
ROD: EV_CVSen.rod
VCID: 284196FB2709AC75B5-807C
1 Fault Found:
12291 - External Control Module
P150F 00 [009] - Incorrectly Coded
Fault Status: 00000001
Fault Priority: 7
Fault Frequency: 1
Reset counter: 1
Mileage: 60787 km
Date: 2017.09.10
Time: 04:19:01
End-------------------------(Elapsed Time: 02:06)--------------------------
I can not help you, I do not have the necessary knowledge. I am sorry.
Please inform us about the BCM adaptation, automatic lights, etc ... (if it is your wish). Thank you.
BCM adaptation is a priority step to any other electrical installation.
We all have to contribute something to the forum, asking and asking is a bad habit...
Please, I hope you understand what I mean. Thanks.
Thx for info, due personal changes in my work I am very busy, bbut in about 2-4 weeks I will have spare few days to all retrofits, your autohedlight in first place... I will post it her of course ... Thx. Daniel
Hello, installing, need help, Ciclo pls check your PM.. THX. Daniel
Remove and isolate original T73b/68 yellow/red wire. Install yellow wire.
download/file.php?id=1765&mode=view
Please, don't send me private messages.
Make your questions here. Thank you.
Hi, many thanks, tommorrow I will finish it ... Daniel
Ciclo, finally did it, fogs, DLR cables, new battery, new headlights, new BCM ... many thanks, working great. You are pro!
5 questions ...
1.
Pls see log - there is lic. plate error - have LED, so can be the bulb check uncoded? I find some :
check Bit 7 of Byte 17 and uncheck k Bit 6 of Byte 23 ... or any way?
Or resistor must be used? Bulb is working of course ...
2.
Module 61 battery regulator - its shows error in VCDS - see log. Only in module list, in detailed scan not ...My Citigo dont have bat. regulator - any way to disable it in BCM ( its part of BCM? )? Or coded to clear error permanently?
3.
Strange module 0B - Sec. Air Heating - showsa only in VCDS module screen, in scan not ... What its ???
4.
Gateway i recoded to 002000 - as was my old BCM Gateway ... Its OK?
5.
Its possible to install Auto Hadlight Assistent? Auto high beam? BCM support it ( right?), so need new stalks, camera ... how to check that instruments are compactible?
Many thanks for your great work master, nice day to Spain!
Daniel
5 questions ...
1.
2.
3.
4.
5.
Daniel
Sunday,02,December,2018,17:52:44:61091
VCDS Version: 18.2.1.2
Data version: 20180518 DS287.1
www.Ross-Tech.com
Mileage: 52230km-32454mi Repair Order:
Chassis Type: AA-VW12 (7E0)
Scan: 01 03 04 09 10 15 17 19 25 44 56 AD
VIN: TMBZZZAAZDD615614 Mileage: 52230km-32454miles
61-Battery Regul. -- Status: Malfunction 0010
AD-Brake Sensors -- Status: OK 0000
Address 01: Engine (J623-CHYA) Labels:. 04C-906-020-CHY.clb
VCID: 23E9EB59C0953D86C0-8076
Address 03: ABS Brakes (J104) Labels:. 1S0-614-517.clb
Part No SW: 1S0 614 517 L HW: 1S0 614 517 F
Component: EBC 460 ESP H16 0023
Coding: 32BF247129AE02F64C0024F694AD40405FB100
ROD: EV_Brake1ESPEBC460TRW_002_VW25.rod
VCID: 3802C518340ABF13A8-806C
Part No SW: 7E0 937 090 C HW: 7E0 937 090 C
Revision: B9082001 Serial number: 4000 228170707
Coding: 6CB82B0000010000010800647CEB86E073C0626D608F30E1200000460000
VCID: 2BF1DB21E84D6DBE00-807E
Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB
Component: RLS 121016 04 42 0106
Coding: 0728DD
Coding: 820000
1 Fault Found:
01504 - Bulb for License-Plate Light (X)
010 - Open or Short to Plus
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 63
Mileage: 52236 km
Time Indication: 0
Date: 2018.12.02
Time: 00:16:53
Address 10: Park/Steer Assist (J446) Labels:| 1Sx-919-475.clb
Coding: 100001
ROD: EV_EPHVA14SK1200000.rod
VCID: 1BE1FB71A0BDCDCE80-804E
ROD: EV_AirbaVW10BPAVN750_VW12.rod
VCID: 7B413B5120DD0D6E80-802E
Address 17: Instruments (J285) Labels:| 1Sx-920-xxx-17.clb-SRI1
Part No SW: 1ST 920 870 A HW: 1ST 920 870 A
Component: KOMBI H05 0008
Revision: X0005001 Serial number: 00000000000000
Coding: 114A010000
ASAM Dataset: EV_KombiUDSMM9RM10 A05808
ROD: EV_KombiUDSMM9RM10_A05_VW12.rod
VCID: 53198BA980851D5640-8006
Part No SW: 7E0 909 901 HW: 7E0 937 090 C
Revision: B9082001
Coding: 002000
VCID: 68326568FC3A9FE328-803C
Part No SW: 5K0 953 234 HW: 1ST 920 870 A
Component: IMMO H05 0008
ROD: EV_ImmoUDSMM9RM10_VW12.rod
VCID: 6A305966EC30EBF538-803E
Address 44: Steering Assist (J792) Labels:| 1Sx-909-144-44.clb
VCID: 3705C31D3031B50AA0-8062
Component: Radio H35 0051
Coding: 0000020801
Shop #: WSC 00070 000 00000
VCID: 4D1F9FDF90A339A010-8018
Component: CV-SENSOR H08 0460
ROD: EV_CVSen.rod
VCID: 28F2E528F47A1FA328-807C
End-------------------------(Elapsed Time: 02:24)--------------------------
