Middle seat belt stuck
PhilEvelyn
Drives: 2016 Polo 1.2 TSI
Post by PhilEvelyn » Wed Aug 15, 2018 11:23 am
Feel that there is going to be an easy fix to this that I just don't know but the middle seat belt is stuck so tight I can't lift the seat back into position.
Any suggestions gratefully received. I've tried releasing the belt while the seat is down, no luck, and I've tried turning round three times and saying 'release you ', that didn't work either.
Sent from my Nokia 7 plus using Tapatalk
Drives: Polo 6R 1.2 TDI
Re: Middle seat belt stuck
Post by iichel » Wed Aug 15, 2018 11:45 am
usually the 'release you' spell works quite well for me, but it sounds like the seatbelt is locked into place.
will it still roll back or is it really stuck in either direction? (roll out and back)?
PhilEvelyn
Post by PhilEvelyn » Wed Aug 15, 2018 1:26 pm
I can just get the seat back into position but there is no play in the belt to release it and it's tight as....
Tried releasing it with the seat down but allegedly it's locked when the seat is down.
jammydodger
Drives: 1.4 TDI SEL (6C)
Post by jammydodger » Wed Aug 15, 2018 3:39 pm
Mine locked too and the seat just about went back up. A friend who works unbolted the seat belt from the bottom and pulled it at different angles and it was sorted. Sorry it's not much help!
PhilEvelyn
Post by PhilEvelyn » Wed Aug 15, 2018 9:14 pm
Sounds like it works better than shouting at it so I'll go with it.
