Polo 6R - Useful Part Numbers
I think so yes
Hello guys!
I'm looking for an R-line front bumper for my 6R but everyone tries to sell it without the plastic spoiler that attached to the front bumper.
Someone could tell me the OEM part number of that plastic spoiler that could be attached to the front bumper?
Another question is it could be attached to the default 6R front bumper or only fit to the 6R R-line bumper?
Thanks in advance!
-limparka
Thanks in advance!
-limparka
- Drives: Polo SEL 1.4 tdi 2014
Looking for the part number of the air con compressor fitted to my tdi 1.4 3cly 6c polo 64 plate, vin number
6R0805915F 9B9 should be the lower lip for the R-Line bumper for Polo 6R/6Climparka wrote: ↑Wed Jul 15, 2020 12:36 pm Hello guys!
Thanks in advance!
-limparka
Thank you iichel !iichel wrote: ↑Wed Jul 22, 2020 5:51 pm6R0805915F 9B9 should be the lower lip for the R-Line bumper for Polo 6R/6Climparka wrote: ↑Wed Jul 15, 2020 12:36 pm Hello guys!
Thanks in advance!
-limparka
- Platinum Member
UPDATE: They fit, need cable tie mod like ciclo did.
Can someone tell me if the J500 Module is built in into the steering rack, or is it in steering pump, or seperate?
It is the steering pump.
- Platinum Member
Thank you, I'm getting some issues with power steering from time to time at random occasions. Got recently no communication J500, but after the car runs for few minutes all gets normal. Not sure if the pump is on the way out, or maybe i should investigate the wires and leads that go to the battery.
btw.
Airbag from this steering wheel
does it fit on this steering wheel?
btw.
- Drives: 1.2TSI 105HP DSG7
yes. it will fit
- Platinum Member
it should be
03L115561A
03L115561A
Looking to confirm part number for latest
in tank diesel fuel pump for my 90PS 1.4 3 cly CUSB Engine code
Also the HP pump number so I have a note of it.
- Platinum Member
Does some know the part number, or if its possible to buy this part seperate.
On Hydraulic pump for steering
This plastic "female connector", i see its held down by 3 screws, can this part be bought ?
- Hydraulic pump.png (52.32 KiB) Viewed 8253 times
No not from VW at least.
