Greek tdi bluemotion
Rocco-85
Drives: 1.2 tdi bluemotion
Re: Greek tdi bluemotion
Post by Rocco-85 »
The pins are sure all ok, I double check every time before I pin in.
With Y connection at the steering coloumn you mean this?
that looks OK. assuming you isolated it, but i'm sure you did.
the wire to double check is T73b/4 to T6aa/3. make sure it's clicked it well at both ends and that it's in the correct positions. i've made mistakes sillier than that.
Rocco-85
Post by Rocco-85 »
ok my fault.....
i checked again with multimeter the T73b/4 to T6aa/3 and saw that i has pinned it to T6aa/6.. shame on me
i clicked byte 27 bit 1 and now its working!
only the highbeam now, its working but i have an error massage byte 18 bit 5 unclick? (22B02BBF08FB2400B2380D916C6B0CD0DF80472F6005104C200000030000)
Dienstag,09,Januar,2018,16:13:40:12669
VCDS -- Windows-basierter VAG/VAS-Emulator lauft auf Windows 7 x86
VCDS Version: PCI 17.8.0.1
Datenstand: 20170809 DS276.3
www.VCDSpro.de
Fahrzeug-Ident.-Nr.: WVWZZZ6RZCY234732 KFZ-Kennzeichen: FIFTH
Kilometerstand: 106880km Reparaturauftrag:
Fahrzeugtyp: 6R-VW25 (7E0)
Scan: 01 03 04 08 09 15 17 19 25 2E 37 44 56 61 77 0B
Fahrzeug-Ident.-Nr.: WVWZZZ6RZCY234732 Kilometerstand: 106880km
01-Motorelektronik -- Status: i.O. 0000
03-Bremsenelektronik -- Status: i.O. 0000
04-Lenkwinkelsensor -- Status: i.O. 0000
08-Klima-/Heizungsel. -- Status: i.O. 0000
09-Zentralelektrik -- Status: Fehler 0010
15-Airbag -- Status: i.O. 0000
17-Schalttafeleinsatz -- Status: i.O. 0000
19-Diagnoseinterface -- Status: i.O. 0000
25-Wegfahrsperre -- Status: i.O. 0000
2E-Media Player 3 -- Status: i.O. 0000
37-Navigation -- Status: i.O. 0000
44-Lenkhilfe -- Status: i.O. 0000
56-Radio -- Status: i.O. 0000
61-Batterieregelung -- Status: i.O. 0000
77-Telefon -- Status: i.O. 0000
Adresse 01: Motorelektronik (J000-CFWA) Labeldatei:. DRV\03P-906-021-CFW.clb
Teilenummer SW: 03P 906 021 B HW: 03P 907 425
Bauteil: R3 1.2l TDI H07 9978
Revision: 12005001 Seriennummer:
Codierung: 00114014032401080000
Betriebsnr.: WSC 46471 001 1048576
ASAM Datensatz: EV_ECM12TDI03103P906021B 001041
ROD: EV_ECM12TDI03103P906021AA.rod
VCID: 2759A9A75EDC697EEB-8072
Kein(e) Fehlercode(s) gefunden.
Readiness: 0 0 0 0 1
Adresse 03: Bremsenelektronik (J104) Labeldatei:. DRV\6R0-907-37x-ESP82.clb
Teilenummer SW: 6R0 907 379 BC HW: 6R0 907 379 AF
Bauteil: ESP8.2i front H05 0002
Revision: --------
Codierung: 210224E3417000B6842C24E582D300521300
Betriebsnr.: WSC 00788 648 00255
VCID: 000BD23B97327E468A-8054
Adresse 08: Klima-/Heizungsel. (J255) Labeldatei: 6R0-907-044.clb
Teilenummer SW: 6R0 907 044 H HW: 6R0 907 044 H
Bauteil: Climatronic H11 0711
Revision: V0000000
VCID: 387B7ADB8B62F68672-806C
Adresse 09: Zentralelektrik (J519) Labeldatei:. DRV\7E0-937-BCM-V1.clb
Teilenummer SW: 7E0 937 090 HW: 7E0 937 090
Bauteil: BCM PQ25 Max4 H80 0733
Revision: B9080001 Seriennummer: 0771 220150189
Codierung: 22B02BBF08FB2400B2380D916C6B0CD05F80672F6005104C200000030000
Betriebsnr.: WSC 12345 123 12345
VCID: 68DBEA9B9B42A60622-803C
Subsystem 1 - Teilenummer SW: 6R0 959 801 AB HW: 6R0 959 801 AB Labeldatei: 6R0-959-801.CLB
Bauteil: J386__TSG_FT 008 1611
Seriennummer: KU0KU002031200013631
Codierung: 58BC30
Subsystem 2 - Teilenummer SW: 6R0 959 802 AD HW: 6R0 959 802 AD Labeldatei: 6R0-959-802.CLB
Bauteil: J387__TSG_BT 008 1611
Seriennummer: KU0KU001031200013755
Codierung: 58BC30
Subsystem 3 - Teilenummer: 1K8 951 171 A
Bauteil: DWA-Sensor 00 001 0103
Codierung: 000000
Subsystem 4 - Teilenummer: 1K8 951 605 B
Bauteil: LIN BACKUP HO H11 9005
Codierung: 000000
Subsystem 5 - Teilenummer: 1K8 951 171 A
Codierung: 000000
Subsystem 6 - Teilenummer SW: 1K8 959 442 HW: 1K8 959 442
Bauteil: E221__MFL-DC1 H04 0103
Seriennummer: 29170000778570077135
Codierung: A4FFFF
Subsystem 7 - Teilenummer SW: 6R0 959 811 G HW: 6R0 959 811 G
Bauteil: J388__TSG_HL 008 1611
Seriennummer: KU0KU028021200012587
Codierung: 58BC32
Subsystem 8 - Teilenummer SW: 6R0 959 812 G HW: 6R0 959 812 G
Bauteil: J389__TSG_HR 008 1611
Seriennummer: KU0KU029021200015174
Codierung: 58BC32
2 Fehlercodes gefunden:
01495 - Lampe fόr Fernlichtscheinwerfer links (M30)
010 - Unterbrechung/Kurzschluss nach Plus
Umgebungsbedingungen:
Fehlerstatus: 01101010
Fehlerprioritat: 3
Fehlerhaufigkeit: 1
Verlernzahler: 126
Kilometerstand: 106883 km
Zeitangabe: 0
Datum: 2012.06.01
Zeit: 16:09:05
01499 - Lampe fόr Fernlichtscheinwerfer rechts (M32)
Fehlerprioritat: 3
Fehlerhaufigkeit: 1
Verlernzahler: 126
Zeitangabe: 0
Datum: 2012.06.01
Zeit: 16:09:05
Adresse 15: Airbag (J234) Labeldatei:| DRV\5K0-959-655.clb
Teilenummer SW: 6R0 959 655 K HW: 6R0 959 655 K
Bauteil: VW10Airbag01M H10 0020
Revision: -------- Seriennummer: 003GX014SRK3
Codierung: 00314D
Betriebsnr.: WSC 01383 785 00200
ASAM Datensatz: EV_AirbaVW10BPAVW250 A01001
VCID: 4A9F3013ED8E741614-801E
Crashsensor fόr Seitenairbag Fahrerseite:
Seriennummer: 3575HRB404T150GSBHT4
Crashsensor fόr Seitenairbag Beifahrerseite:
Seriennummer: 3585HRB405115IRSA0KN
Crashsensor fόr Seitenairbag hinten Fahrerseite:
Seriennummer: 3515RRB405T134DQKP71
Crashsensor fόr Seitenairbag hinten Beifahrerseite:
Seriennummer: 3525RRB4067134DQD8C5
Adresse 17: Schalttafeleinsatz (J285) Labeldatei:| DRV\5K0-920-xxx-17.clb
Teilenummer SW: 6R0 920 861 H HW: 6R0 920 861 H
Bauteil: KOMBI H04 0206
Seriennummer: 00000010513275
Codierung: 140801
ASAM Datensatz: EV_DashBoardUDSJCIPQ25 A01015
ROD: EV_DashBoardUDSJCIPQ25_A01_VW25.rod
VCID: 3A7F60D3BD6EE49684-806E
Adresse 19: Diagnoseinterface (J533) Labeldatei:. DRV\7E0-909-901.clb
Teilenummer SW: 7E0 909 901 HW: 7E0 937 090
Bauteil: GW-K-CAN TP20 H80 0733
Revision: B9080001
Codierung: 002200
Adresse 25: Wegfahrsperre (J285) Labeldatei:. DRV\5K0-920-xxx-25.clb
Bauteil: IMMO H04 0014
Seriennummer:
ASAM Datensatz: EV_ImmobUDSJCIPQ25 A01001
ROD: EV_ImmobUDSJCIPQ25.rod
Adresse 2E: Media Player 3 (J650) Labeldatei:. DRV\5N0-035-342.lbl
Teilenummer SW: 5N0 035 342 E HW: 5N0 035 342 E
Bauteil: SG EXT.PLAYER H13 0240
Revision: A1001003 Seriennummer: 7662028739
Codierung: 020000
VCID: 295DAF9F40C85F0EFD-807C
Adresse 37: Navigation (J794) Labeldatei:| DRV\3C0-035-270.clb
Teilenummer SW: 3C0 035 270 B HW: 3C0 035 270
Bauteil: RNS310 H20 0357
Revision: 11000000 Seriennummer: VWZ1Z2M8462982
Codierung: 040004010200000000000000
ASAM Datensatz: VW_RNS310 A02007
ROD: EV_VWRNS310UDS.rod
VCID: 193D9F5F18A8CF8E6D-804C
Adresse 44: Lenkhilfe Labeldatei: DRV\6Q0-423-156.clb
Teilenummer: 6R0 423 156 B
Bauteil: LenkhilfeTRW V277
Codierung: 11230
VCID: 2F694187EA2C313E23-807A
Adresse 61: Batterieregelung (J840) Labeldatei:. DRV\1K0-907-534.clb
Teilenummer SW: 7E0 907 534 HW: 7E0 937 090
Bauteil: Batt.regelung H80 0733
Codierung: 030B1A59
Subsystem 1 - Teilenummer SW: 6R0 915 181 E HW: 6R0 915 181 E
Bauteil: J367-BDM H08 0181
Seriennummer: 00000000004970247327
Adresse 77: Telefon (J412) Labeldatei:| DRV\7P6-035-730.clb
Teilenummer SW: 5K0 035 730 F HW: 5K0 035 730 F
Bauteil: TELEFON H09 2902
Revision: 1B001001 Seriennummer: 00007662017862
Codierung: 0100000000000210
ASAM Datensatz: EV_UHVNA A01719
ROD: UHVNA.rod
VCID: 285BAA9B53C26606E2-807C
Ende----------------------------(Dauer: 03:16)-----------------------------
Rocco-85
Post by Rocco-85 »
ok next step, xenons are installed and working exept LED and steering light.
sure i must add wiring into bcm for LED!
i have only adapter from 10 to 14 pin without extra wiring for bcm, where i must add the wire in the bcm?
I am happy to know that with my help you are solving the problems that arise "in your electrical installation". With my BCM coding, ideas, etc...
I was waiting :twisted: , and you too, for someone -some master or clone- to give you the BCM coding.
For the bixenon headlights - "which you said you had already installed" - here, you have to do this:
left
right
What's left is easy, good luck!
Rocco-85
Post by Rocco-85 »
Yea you are my hero :)
We are all glad to have you guys!
Thank you for your time and knowledge.
Ok this wiring will be easy
I have a AFS here, it was first for my Scirocco to add the Facelift xenon but I never buy the newer xenons, the old one are good too.
I believe I need it for auto leveling?
If you disrespect me again, you will be banned. :)
Rocco-85
Post by Rocco-85 »
New mod, I don’t liked the white one
looking good! :mrgreen:
Rocco-85
Post by Rocco-85 »
Thanks :mrgreen:
Why I can’t find any tdi mfa+ Instrument cluster for my 6r..?
If I buy from the 6c sure it wouldn’t fit right? Like that on eBay ( 292418570888 )
If I modify to fit it in, will the electrical part work without any problem?
Or it they any other way to add the mfa+
there are a few MFA+ clusters for the Polo 6R:
- Polo 6R GTI petrol, redline at 7000, max speed 280, red needle
- Polo 6R WRC petrol, redline at 7000, max speed 280, blue needle
- Polo 6R BlueGT petrol, redline at 6500, max speed 240, red needle
If you have a diesel engine, you could think about fitting the cluster from these models, but the rpm are a bit high, and you'll miss the spiral and DPF light, or you could think about fitting a tacho from the VW Amarok 2H TDI, Seat Toledo TDI or Skoda Fabia TDI PQ25 (not the latest MQB generation). Take into account that these will need some adjustment of the cluster EEPROM and/or the housing of the cluster.
I have the cluster from a VW amarok with custom firmware running and the right scale from VW Polo Blue GT.
Rocco-85 wrote: Sun Jan 28, 2018 11:51 am New mod, I don’t liked the white one
(Pics)
8)
Check in your inbox my reply to your questions.
Check in your inbox again.
Rocco-85
Post by Rocco-85 »
Wirings arrived yesterday, thank you Ciclo!!!
I am waiting now some more wirings for Pdc front & rear and then I will install them together
