DO LM's suit a GTI Polo
Save money on tyres and also to make sure the tread is in the arches.
Re: DO LM's suit a GTI Polo
205 on 8" rims isn't really a stretch and inside of Toyos recommendations for maximum rim width.
The same reason why people but 195's on to 8/9 inch wheels, but don't think it would suit the polo and 215 is far enough, do you get rubbing on the back auspolo or just the front when turning?
Makes sense, but if the tyres are stretched on do they not have a tendency to pop off the rim? How does it affect handling too? I can't expect it to be in a good way. Presumably your insurance is invalid if you have tyres that aren't rated for your wheels too?benmkiv wrote:Save money on tyres and also to make sure the tread is in the arches.
i can get full lock without rubbing but the front rubs somewhere if i hit a bump too fastStugolf1 wrote:do you get rubbing on the back auspolo or just the front when turning?
I concur with the above. My set up is 18x7.5 ET48 (3 mm spacers) 225/35 with H&R 25/40 springs...and very rarely do I get any rubbing...maybe on a hard turn or with a slightly deflated tyre.auspolo wrote:definitive answer: yes they will rub...a lotStugolf1 wrote:Cheers for the help guys, I'm confused now, some people say 18" and 8" width with an offset of 35 will fit with 35/55mm springs and some say it will rub, does anyone have a definitive answer?
mine are 18x8 ET35, 225/35 and 25/40 H&Rs and the front rubs a bit if i'm not careful
If you want to drive spiritedly, avoid the 35/55 springs ...because you will absolutely get rubbing with 18x8 ET35 and anyone who states otherwise is dreaming.
Sorry for that old repost but I am after a set of 18x8 ET35 wheels with 225/35 tires. If I am using stock 6R GTI springs will them fit with no rubbings then?nodoze wrote: ↑Wed Mar 14, 2012 2:58 amI concur with the above. My set up is 18x7.5 ET48 (3 mm spacers) 225/35 with H&R 25/40 springs...and very rarely do I get any rubbing...maybe on a hard turn or with a slightly deflated tyre.auspolo wrote:definitive answer: yes they will rub...a lotStugolf1 wrote:Cheers for the help guys, I'm confused now, some people say 18" and 8" width with an offset of 35 will fit with 35/55mm springs and some say it will rub, does anyone have a definitive answer?
