ciclo's Polo. R-line 1.2 TSI 90hp 119gr.
- federicodrdpro
- Drives: White Polo 6R TDI
Ciclo, have you seen this mirror?
https://youtu.be/lIGOHgjXj2c
Yes, many times, and other models with different shapes with the same functions.
I think my current mirror (HBA) is also built to show the compass, but I have not investigated how to make it works.
I also have the HomeLink feature in my 6R, ...in a perfect place.
- Jay-Jay
- Drives: Polo 6R HL 1.2TSI 77kw, Audi S1 MY2018
I would like to do the same upgrade.ciclo wrote:Rear tweeters
In 6-speakers original/standard audio system.
Now that you have seen and heard the video without headphones, you heard it again with headphones and you will notice a better difference between treble and bass.
I'm not looking for a special sound or high definition for my 6R, I just want to give a bit of clarity to the sound in the back.
This type of tweeters are installed from the factory in VW models that don't have a special sound system, Golf, Scirocco, etc ... but not in our 6R.
10
Where do the rear tweeter can be installed?
I have another pair of front tweeter: could I use them or they don't work well for the rear?
iichel's 6R
I'll install anodized aluminum brackets - as you can see in the video - for a good finish.
For example, the original 6R front tweeters are 8 ohm, maybe the sound output signal is a bit low for the back.
Keep in mind that there is no perfect sound system to everyone, it depends on who is listening it and the personal tastes.
- Jay-Jay
Thank you so much for the info!
those brackets are actually quite a good idea. is there an easy way to obtain them?
In fact it's what makes this modification possible in a decent/subtle way.
https://www.aliexpress.com/item/GD-PART ... 66911.html
The indicated price is for one piece, buy two.
I still haven't received them, ...according to my measurements on the 5KD tweeters everything should fit.
- Drives: Polo R WRC 2014
I'm looking to pick up a pair of these myself (it's a low price to pay in order to look more handsome). Do they fit without modifications?
yes, 1:1 fit
Good luck!...
Well, jokes aside, they provide an ideal light, especially when we're driving and the passenger uses the vanity mirror at night/darkness. ...
To others:
you can use the arrow to UP inside the quote (below), or click here viewtopic.php?p=529330#p529330
- Drives: Transporter T5GP
Ciclo, don’t know if you can assist? I am looking to upgrade the BCM on a T5.1 2013
I currently have
And I have been given
I eventually want to install auto lights and maybe HBA but that’s a bit down the line at the moment
It’s a 2014 model year ‘E’
I currently have
