I will ask around then.ciclo wrote: ↑Thu May 24, 2018 8:44 pmIt should sound as good as if the VW Helix Sound System is installed in a Scirocco. In case you know someone with it.peter_dk25 wrote: ↑Thu May 24, 2018 6:42 am I wonder how it will sound with the VW Helix Sound System - coded for 6 speakers?????
But it looks nice
Looks better in live, the images and videos lose quality when I upload them.
ciclo's Polo. R-line 1.2 TSI 90hp 119gr.
- Drives: Blue GT
Good mod, I'm using mine quite often.
It's funny, it was a factory standard in the earliest Polo 6R's and in MY2011 I think, they simply took it out completely.
But the shape is still in the fabric.
Yes, the cut shape is drawn behind the plastic-shelf. (trim panel)
These are some of interesting things that can be found on aliexpress due to the parts they contain. (light, wiring connectors, etc)
https://www.aliexpress.com/item/ZUCZUG- ... 4c4dAuOBPF
I bought it because of those parts it contains because I already had the 12V socket, I do not know if the wiring will be long enough.
The wiring is not a special problem.
OEM lighter in trunk is without red backlight
https://www.youtube.com/watch?v=3J_uRghQc7c --> IC similar to our from 6R
https://nemigaparts.com/cat_spares/etka ... 66/920000/
my mate has Polo 6R 1.4 from 2009, he has got factory disc brakes on the rear and 12V socket in the trunk. I took some photos: https://imgur.com/a/rpt3uSZ
- Jay-Jay
- Drives: Polo 6R HL 1.2TSI 77kw, Audi S1 MY2018
My Polo 6R HighLine M.Y.2010 has the 12V socket in the trunk as well and it is exactly as shown in the pictures from your friend's Polo: without the red light.
I guess it was standard only in M.Y.2009 and M.Y.2010.
Inviato dal mio MHA-L09 utilizzando Tapatalk
my sister has 6R 1.4 from 2010, but without 12V in trunk
Passenger airbag OFF indicator light on center console.
In order to install the button for front PDC in the right place. (same place as original PA OFF indicator light)
Previous info:
https://uk-polos.net/viewtopic.php?f=56 ... 75#p533454
https://uk-polos.net/viewtopic.php?f=56 ... 20#p533920
https://uk-polos.net/viewtopic.php?f=56 ... 20#p533949
Previous info:
- Drives: 1.2TSI 105HP DSG7
Really I wonder how your centre console near the end compartment and cup holder there really clean and no scratch at all! Mine full of scratches. [emoji58]
I guess it has to be due to luck, I promise you that I use them often to leave all kinds of objects.
I'm kidding, I always replace all the parts that have scratches.
I don't have to replace the center console this time, however and due to some small scratches, I have to replace the central part between the center console and dashboard (where we support the knee) and also the black glossy trims for climatronic and radio-navigator. In process... (deep overhaul time).
Haha. I was thinking maybe there’s a coating product that can prevent such scratches[emoji23] out there that I’m not aware off. But again, I really adore how you really take a good care of your parts & trims! Excellent!
benzinkopf wrote: ↑Wed Jun 06, 2018 7:15 pm Haha. I was thinking maybe there’s a coating product that can prevent such scratches[emoji23] out there that I’m not aware off. But again, I really adore how you really take a good care of your parts & trims! Excellent!
I think the care i've is due to a professional defect (attitude close to paranoia). In aeronautical matters everything must be perfect.
Excellent! Three little donkeys, ...one of them will become a steed.
