ciclo's Polo. R-line 1.2 TSI 90hp 119gr.
New conditions
I'm waiting to receive the Gateway for the test bench.
2nd ECU, and BlueGT IC returns
Working on it. Level of difficulty 10/10 (without the appropriate tools).
- Abrites can't read the immo data from my GTI IC. 6RD920870A H04 0805 sw.
- Original VCP can't flash my GTI IC to downgrade to 0709 sw and get the immo data.
- I don't have the immo data from my 6R, well, I have them from my Original IC and BlueGT IC, but they are not correct or they are manipulated.
I still have an ace under the sleeve, maybe it works.
... I'm going to test these new lamps in my 6R Bixenon headlights ...
I have some envy of the headlights/lamps (6500K) that I installed in my wife's Golf.
viewtopic.php?f=56&t=70398&p=554361#p554101
Still working on the 2nd ECU and the BlueGT IC returns, now in the right direction ... super funny experience (we are learning things that have not yet been written due to the level of difficulty to solve some bugs ). I can't provide relevant information, sorry.
In anycase my 6R works like a charm with my GTI IC and BRP repro, as ever.
Some irrelevant info:
To highlight, these buttons work correctly in my test bench with the software 0709 of my BlueGT IC, it's possible to access all the menus, but they do not work with the software 0805 of my GTI IC.
Speculation: maybe VW / VDO has made corrections in the IC software 0805 to avoid the known bugs when you install new stalks with trip computer buttons and you also have them in the MFSW at the same time.
In some of the trial and error phases to make the BlueGT IC work correctly things like this happen. Black screen.
No problem.
Other corrections in eeprom file are needed.
More information when possible.
No problem.
Time... to try it in the car.
Mods in GTI IC EEPROM
CH341A programmer
Testing what happens when installing blue needles with red leds. (s**t )
Cruise Control Display available in adaptation channels
02D9 ... from 01 to 81 enable bit7
Needles glow after Ignition OFF
02F2 ... from 0E to 4E enable bit6
Brake wear indicator (necessary to install the cables up to the brake pads and 17-Instruments coding, Byte1 Bit0)
02D3 ... from 46 to 47 enable bit0
Profile
02E8 ... from 5C to DC enable bit7
BlueGT IC
I'm still struggling with the encrypted immobilizer data, many unsuccessful tests.
CH341A programmer
Profile
BlueGT IC
I'm going to test this type of 55W ballast ... which will really be 40W in its best condition ... together with the xenon OSRAM CBI 35W lamps.
The original ballasts are 35W, the original xenon lamps are 35W.
I'll let you know if my 6R comes out burning ... if I have time to escape ...
I still have to make an appointment with my VW dealer to regulate the headlights and other important things ... it will take some time. (I guess for the first week of June)
Making progress ...
Update
OK
My GTI IC
Perfect!
You can also enjoy watching this wonderful project https://www.drive2.ru/l/531400018091835697/
Update
OK
My GTI IC
Perfect!
Looking for a new menu ...
Convenience and/or Lights and Vision (CH/LH)
Example
Another example https://uk-mkivs.net/topic/20240-highli ... ntry761427
According to the information I have available, by activating the adaptation channel "Car menu source" and configuring it to "Version 1", the mentioned menus are activated in MFD.
This happens in the instrument clusters for PQ25 that are sold in South America, ... Gol, Fox, Suran, etc ...
The source from which this information comes is from the BCM or a unit that I think is called VW i-system for PQ25. (depends on the date of manufacture)
I have dumped the eeprom data, by blocks / sectors, from a 5Z0 920 865 A H07 0010 instrument cluster (which has the mentioned menus activated and whose data structure is similar) in the eeprom of my BlueGT IC (except IMMO data, logically).
In each block/sector I have been checking with VCDS if this adaptation channel changed to available, ...without success.
Not available.
With the IC in my test bench (without BCM, with Gateway) nothing appears, logically.
When the power was turned off a new information menu appeared suddenly in the MFD.
Example
Not available.
The tip to step on the clutch to start is between 0x000 and 0x13F
It disappears from my BlueGT IC when I paste in the eeprom this sector of Bytes from 5Z0 920 865 A eeprom.
2nd ECU updated in my Test bench viewtopic.php?f=56&t=58703&start=4695#p553672
- From sw 4039 to sw 5466.
- ODIS-E 9.0.4, VAS 5054, via Bluetooth. ... Perfect!
Friday,31,May,2019,06:21:10:32438
VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4505.4
Data version: 20190114 DS296.0
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO License Plate: MKE data set loaded. gAtEwAy 🤭
Mileage: 40540km-25190mi Repair Order:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 20 25 2E 37 44 55 56 65 77
VIN: WVWZZZ6RZDY0CICLO Mileage: 40540km-25190miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZC) Labels:. 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 GD HW: 03F 907 309 AJ
Component: SIMOS10.22AH10 5466
Revision: --H10--- Serial number: 00000000000000
Coding: 001100D6202400080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM12TFS02103F906070GD 004007
VCID: 6A8D3FD44CF80237209-803E
Readiness: 0110 0101
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 BE HW: 6R0 907 379 AF
Revision: --------
Coding: 210228E3216D00B5842814EA84D300401700
Shop #: WSC 40308 002 104857
VCID: 025D77745448FA77889-8056
Serial number: 08021613470174
Coding: 01
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA5038420709E97EC1-802A
Part No SW: 6R0 907 044 H HW: 6R0 907 044 H
Component: Climatronic H11 0711
Revision: V0000000
VCID: 3829D59C425460A766D-806C
Part No SW: 7E0 937 090 C HW: 7E0 937 090 C
Revision: B9082001 Serial number: 4000 122170091
Coding: 3CB02FBF48E12400B3380F317CEB9FD05AC0670F600D30D0200000030800
Shop #: WSC 00046 648 00255
VCID: 2B03FAD08302DB3F1BF-807E
Component: RLHS 220816 0 42 0106
Coding: 0728DD
Subsystem 2 - Part No SW: 6R0 959 801 BD HW: 6R0 959 801 BD Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 8612
Coding: 0200A3
Subsystem 3 - Part No SW: 6R0 959 802 BF HW: 6R0 959 802 BF Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 003 8612
Coding: 1000A3
Component: DWA-Sensor 00 001 0103
Subsystem 5 - Part No: 1K8 951 605 B
Component: LIN BACKUP HO H11 9005
Subsystem 7 - Part No SW: 1K8 959 442 HW: 1K8 959 442
Component: E221__MFL-DC1 H03 0103
Serial number: 27140003142720054516
Coding: A4FFFF
Subsystem 8 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Serial number: KU0KU003051200017821
Coding: 18BC32
Subsystem 9 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Serial number: KU0KU010051200012315
Coding: 18BC32
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 AA HW: 7N0 919 475
Component: PARKHILFE 8K H06 0212
Revision: -------- Serial number: 28231708304294
Coding: 308001
Shop #: WSC 02739 790 50316
ASAM Dataset: EV_VW75XParkAssis8K 001012
VCID: 71BF28B8612EF1EF613-8024
Component: VW10Airbag01M H10 0020
Revision: -------- Serial number: 003GX01JKVVP
Coding: 00314D
Shop #: WSC 01383 785 00200
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4ACD9F542C38E237009-801E
Serial number: 3575HRB405N1C4LI7929
Serial number: 3585HRB405B1D5MS8GS2
Serial number: 3515RRB405B17ABS901.
Serial number: 3525RRB405B181TUDPKC
Part No SW: 6RD 920 870 A HW: 6RD 920 870 A
Component: KOMBI H04 0805
Coding: 140E01
Shop #: WSC 00233 572 00255
VCID: 47CBA6603F2A1F5F1F7-8012
Part No SW: 7E0 909 901 HW: 7E0 937 090 C
Revision: B9082001
Coding: 002204
VCID: 688945DC5274302736D-803C
Address 20: High Beam Assist. (J844) Labels:| 8S0-857-511.clb
Part No SW: 7E0 857 511 G HW: 7E0 857 511 E
Component: FLA H10 0003
Revision: AA001001
Coding: 0404000000000000000000
Shop #: WSC 03607 002 104857
VCID: 2E05F3C4B090AE173C1-807A
Component: IMMO H04 0805
Shop #: WSC 00000 000 00000
ROD: EV_Immo_UDS_VDD_RM09.rod
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H18 0530
Revision: A1001003 Serial number: 7662584630
Coding: 010100
VCID: 2A0DFFD48CF8C237E09-807E
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 1T0 035 680 L HW: 1T0 035 680 C
Component: RNS-MID H06 5274
Revision: AB001001 Serial number: VWZ6Z7L7654213
Coding: 04000442040000A10001
Shop #: WSC 12345 123 12345
VCID: 372BD6A04F4A6FDF6F7-8062
Subsystem 1 - Part No: 1T0 919 859 B
Component: EU West V15 8515
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11221
Shop #: WSC 00788
VCID: 2F3BEEC0BE5AA71F377-807A
Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Revision: -------- Serial number: --------------
Coding: 0112000001000000
VCID: 77AB16A00F4AAFDFAF7-8022
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 3AA 907 273 F HW: 5Q0 907 273
Component: RDKBERU30 H04 0011
Serial number: 40000000050821
ROD: EV_RDKBERU30_005.rod
VCID: 372BD6A04FCA6FDF6F7-8062
Address 77: Telephone (J412) Labels:| 7P6-035-730.clb
Part No SW: 7P6 035 730 L HW: 7P6 035 730 L
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007664158506
Coding: 0501000000010110
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
VCID: 3B23CA9073E24BBF8BF-806E
End----------(Elapsed Time: 01:58, VBatt start/end: 13.9V/13.9V)-----------
