VCDS vag com programming
- greypolo9n3
- Drives: white 6r 1.6 tdi rline/gti
anyone here with the programme?
Wanted to buy a trip and cruise stalk and get them programmed
Also get a few settings right, willing to travel . Thanks
Re: VCDS vag com programming
Where abouts are you based? Ive got a friend that has it
- greypolo9n3
in peterborough, can he use it properly?Jakey6r wrote:Where abouts are you based? Ive got a friend that has it
I am interested in this program but I am getting really confused as there appears to be a massive difference in price for this system....eBay for £40 (do they work??) or the full version for £300!!
I'm not looking to do much, and to be honest I'm not sure what I would be able to do. I have 2010 1.4 SEL with high line dash. Could anybody confirm I would be able to turn on these features?
Speedo/rev needle sweep
Auto locking above 10mph
Remove the (annoying) feature of ONLY unlocking the drivers door from key
If I can't sort this I can wait til next service time and get them to do it but I like messing and modding my car!!
Some of the cheaper ones do work, I'm on my phone at the minute but I can send you the link shortly to one I purchased off amazon for 30ish, it turned out to have all the features and can do what you want it to.
Only downside is its from Hong Kong I think, takes a few weeks to get here...
Edit: found the link from someone else's topic.. http://tinyurl.com/c7y8uc9
Hello
I'm new on here but have a few VW's
To answer some of the questions
Needle Sweep - i dont know the coding, it can be done on some Golf Mk6's
Auto Locking about 10 km/h is a simple job with the proper VCDS (i have this), i've set my 2009 (59 plate) 1.4 SE to work in this way, you can also simply check the unlock all doors function too so all those features are easily available with the correct Rosstech hardware and i have done them on my car so know they work
From memory there is something in the manual about how to set the locking, it involves holding the wiper stalk (could be drivng lights though as i only scan read it quickly)
Ray
Ray
Yeah thanks for that I had another look at the manual and its for disabling the DRL not the locking!!
I'll maybe take the plunge and order the part and have a play about.
no worries, couldnt remember, the VCDS will do all your bits easily
do you have any coding inof on the needle sweep?
To get the needle sweep, go into instruments-adaptation-indicator celebration mode- on
needle sweep will be there on the list as well, but it doesn't let you change it.
- greypolo9n3
so how hard is it exactly to do the coding via VCDS? My friend has it i may be able to borrow it of him
greypolo9n3 wrote:so how hard is it exactly to do the coding via VCDS? My friend has it i may be able to borrow it of him
It's easy, every option is there for you to choose from and its pretty much a case of toggling off/on
- greypolo9n3
oohh...ive seen some screenshots and all i see is binarycalvinw1 wrote:greypolo9n3 wrote:so how hard is it exactly to do the coding via VCDS? My friend has it i may be able to borrow it of him
like 0101010101010101101011010 matrix code s**t lol
aha yeah thats in the long coding. Won't need that for the majority of options
So this ISN'T something I can switch on, on my car then? It is present but can't change it to off/on.....is that right?calvinw1 wrote:To get the needle sweep, go into instruments-adaptation-indicator celebration mode- on
It's called indicator celebration mode NOT needle sweep. Like The guy said it can be done from instruments>adaptation>indicator celebration mode>on
