Polo 6R - Useful Part Numbers
ag69
Drives: 1.2TSi 77Kw 7DSG
Post by ag69 »
I got rid of flimsy one and replaced with 3Q0 955 455
I could hardly make any difference between 3Q0 955 455 and 4M0 955 267 except price.
DACA
Drives: Black 1.4 TDi SE BMT 2015
Post by DACA »
Can one of you let me have the part numbers for front and rear mud flaps. For a 2015 Polo 1.4 Tdi bluemotion no side skirts please.
DACA
Post by DACA »
Good morning I am new to this forum and was wondering if I can get some help and advice please. Are oem mudflaps available for a 2015 (65) polo 1.4 tdi bluemotion? If so what are the part numbers for front and rear. I do not have side skirts just the normal sill. Thanks for your help
DACA
Post by DACA »
Just thought i would add that i was rather disappointed with the lack of replies here :(
I have now bought a set of short mudflaps from China via Alibaba for 20 dollars. The front ones are spot on and the rear ones need me to drill a hole for the lower fixing. Just what the dr ordered really :P
DACA
Post by DACA »
Rear ones fitted. A good fit and quality is the same. Didn't take long to get from China to the uk and a great price at just over £15 from alibaba. Very happy with my buy. 👍😊
HappyGoLucky
Drives: 1.8 GTI
Post by HappyGoLucky »
Hi there,
Does anyone know where I can get Gloss black badges with red inserts for my 2016 Polo GTI?
Thanks in advance :)
BOAK
Drives: Polo BlueGT
Post by BOAK »
Would anyone have the part number for a Turbo Actuator on the Blue GT?
ag69
Post by ag69 »
I am looking for "Engine Start Stop Button" illuminating in Red color to be retrofitted in Polo 6R.
VW
Audi
The attachment audi-engine-start-stop.JPG is no longer available
Could anyone of you please confirm if which of these would glow Red?
Passat has a 3G1959839
Golf has a 5G1959839
or any other from VW group you can list would help too. xxx 959 839
5K0959839A and 5C7959839A are red, i got the 5K0 in my polo
5G1 is very likely white
ag69
Post by ag69 »
Thank you iichel.
If you get some time may be post a video of it.
I have seen image. One q is can we remove the actual button from black colored plastic cone? I am not sure where to place it but may be making a hole in dash or around gear lever.
it's probably not super difficult to separate the button and the body, most VW switches are very modular and can be taken apart easily.
i expect the start/stop button not to be different.
ag69
Post by ag69 »
thank you iichel,
ag69
Post by ag69 »
Would any vw reverse emblem camera work with RCD330G/340G?
5GM827469g -- from golf
3G0827469 -- from passat
size of emblem is 110mm so passat ( or any other model) emblem camera can fit in polo. (correct me)
But any idea about the connector?
Do we need to make any wire/connector alterations?
(iichel has :
OEM 5K Golf 6/T6 badge rear view camera Highline --> 5K0827469H + 7E0907441 + wiring
I am not sure if we need camera module with RCD330G and above.
I think the RCD330G works with a 2-wire system to the camera with a composite signal. My RNS510 (and the RCD510 and RNS315) works with the 26-pin connector and 4 wires with an sRGB signal.
Now in my case, the camera is also the version with a composite signal but goes to a module first, where it's converted to sRGB.
So 5K0827469H would work.
benzinkopf
Drives: 1.2TSI 105HP DSG7
Post by benzinkopf »
iichel wrote:I think the RCD330G works with a 2-wire system to the camera with a composite signal. My RNS510 (and the RCD510 and RNS315) works with the 26-pin connector and 4 wires with an sRGB signal.
How accurate the guidelines and how significant it provides compared to camera view without the dynamic guidelines? mind sharing a bit?
