Page 21 of 29
Posted: Thu Dec 12, 2019 10:19 am
by iichel
Yeah that one is a b***h, usually I cut them off and install a new one. They are very difficult to remove wires from.
Posted: Thu Dec 12, 2019 11:08 am
by ag69
Thanks iichel.
Posted: Wed Jan 01, 2020 11:27 am
by ag69
Can anyone help me differentiate/choose between sylvania 578 and 6411 41 mm festoon?
They have very less power consumption of 0.5W and I want to replace it for N 017 723 4 which is a 10W halogne in dome light.
Amazon uk has osram one
https://www.amazon.co.uk/OSRAM-6441CW-0 ... ive&sr=1-4
Amazon US has both
578 & 6411
https://www.amazon.com/SYLVANIA-6411-Fe ... r=8-3&th=1
Posted: Mon Mar 09, 2020 9:41 am
by JH1151
Hi, hoping someone can help me.
Does anyone have a part number for a bonnet?
I believe it is 6R it's a 2016 match edition 1.2 TSI DSG.
I'm not even sure on that but the vin starts with WVWZZZ6R
I was driving and what looked like a brick flicked up from the middle of the road and ruined the bonnet, bounced off and hit the windscreen
didn't go through but took a chunk out of both.
Posted: Mon Mar 09, 2020 10:26 am
by SRGTD
JH1151 wrote: ↑Mon Mar 09, 2020 9:41 am
A 2016 Polo will be a 6c, although the part no. will start 6r as the 6c is the facelift version of the original 6r Polo, and both the 6r and 6c use the same metal body panels.
A quick Google search turned up the part no. for the bonnet as 6R0823031A. Might also be worth trying breakers yards near to you as they may have undamaged used bonnets from cars that suffered rear end damage; you might also be able to locate one off a Pure White Polo, which would save on getting it painted.
Posted: Mon Mar 09, 2020 4:32 pm
by JH1151
That's brilliant thank you
Posted: Sun Apr 19, 2020 8:57 pm
by Robbo770
Can anyone confirm the new 1.4 tdi 3 cly glow plug part number 2014- think its 03L963319?
Posted: Sun Apr 19, 2020 9:07 pm
by iichel
For CUSA CUSB --> 059963319AB
Posted: Sun Apr 19, 2020 10:10 pm
by Robbo770
Thanks ichel, got major service coming up and going to change as 6 yr old now
Posted: Tue Apr 28, 2020 11:01 am
by limparka
Hello guys!
I'm new on this forum but I reading this forum since a long time. I have a Polo 6R 2009 1.4 and I got one R-line wheel set with 215/45 R16 tires. After I put on the new wheels I realized that the rear axle is so high so I would like to buy a new coil springs set for the rear axle. I read
ciclo's topic about his new springs and I found that he installed the
6Q0511115CK PR-1JS+0YE VAG number OEM springs on his car.
I looked for these springs at one of the local car parts dealer in Hungary but they said that spring is for the Polo 9N.
I'm a bit confused now. Will it fit on my Polo 6R or not?
Thank you for your help!
- limparka -
Posted: Tue Apr 28, 2020 11:53 am
by iichel
It is a suitable part for Polo
6R 2009-2014
Posted: Sat May 02, 2020 10:58 pm
by limparka
Thank you sir!
Do you suggest it instead of the factory springs? I dont want a racing car look, but with the factory springs it looks like a derby-cross car.
Posted: Mon May 04, 2020 9:47 pm
by Robbo770
Hi iichel,
Would these rear springs 6Q0511115CK
be able to be used on my 64 plate 1.4 tdi 6C?, want to lower the rear a bit.
Cheers Rob
Posted: Mon May 04, 2020 10:51 pm
by iichel
CK should be suitable for your 6C, yes.
Posted: Wed Jun 03, 2020 9:17 pm
by amer6R
Will golf mk7 gti pedal covers fit 6r ( with zip ties modification?)
Sent from my Nokia 6.1 Plus using Tapatalk
