My Polo 1.2 TSI DSG
Re: My Polo 1.2 TSI DSG
TheLizardKing wrote: Tue Sep 17, 2019 8:50 am
ciclo wrote: Tue Sep 17, 2019 7:55 am There is no problem with the voltage when installing LED lights (12-14v). In fact it is better to install LED lights inside.
The necessary wiring depends on the model of the LED lamp you install, there is no specific wiring for the 6R, you must manufacture it or modify the one you bought. It is not necessary to code anything.
Thank you for your help. The supplied harnesses come with the required connector at the lamp end. I needed help with the type of terminals required for the connections at the WRM (+ve) and Door Lock Unit
(GND) ends.
I promise you that all the information you are looking for is in the following link.
viewtopic.php?f=10&t=42713&p=466570#p466570
https://www.a4-freunde.com/attachment.p ... 1415539780
https://www.a4-freunde.com/attachment.p ... 1415951353
ag69 wrote: Tue Sep 17, 2019 9:50 am
I assume you/we are talking about LED in doors. Instead of so called ERROR FREE LEDs, can we use the LED Strip SMD 3528 or SMD 5050 in a case? Can all these be used in interior for footwell and dome lights?
Yes, they can be used according to the manufacturer's specifications, ... you must understand that there are many types of LED lights with different specifications.
TheLizardKing
Drives: VW GT TSI 1.2
Post by TheLizardKing »
ciclo wrote: Tue Sep 17, 2019 8:42 pm I promise you that all the information you are looking for is in the following link.
And everyone knows you always keep your promises, Fernando! :D I got all the information I was looking for, and also learnt a lot more that is sure to come in useful during my later DIY projects.
giannis20vt
Post by giannis20vt »
ciclo wrote: Mon Feb 02, 2015 2:39 am I have not yet made this mod because the door panels are very expensive if you make a mistake when cuttingImage but I rescue this interesting information (diagrams) that I published on the Italian forum to warning/illumination lights on the doors.
Driver door
Image Image
Left and right rear doors
Image Image Image
Front passenger door
Image Image
Pictures (with your permission thealbert) :wink:
+Supply from the connector on the unit window. (All is pin 16).
-Ground from the door contact. (see diagrams for exact pin each door).
In this way only turn on the light from the door which is opened.
Hi, i am thinking of doing this mod to my car, a Polo 6c MY2016. I can't find the door's contact wiring for the front doors. For example this is the picture from the passengers' door wiring. There is a contact switch (F3) but there is not a specific wire for that contact. On the other hand, i find this contact at the rear doors (always on wiring schematic)
Could someone help me?
6R vs 6C have the same assignment for the door switches (F).
DD ... T8/3
PD ... T8/5
RDD ... T8/2
RPD ... T8/5
In any case, for 6C you must pay attention to the coupling point T28/19 for all doors.⚡
giannis20vt
ciclo wrote: Mon Jun 07, 2021 11:39 am 6R vs 6C have the same assignment for the door switches (F).
DD ... T8/3
PD ... T8/5
RDD ... T8/2
RPD ... T8/5
Wow, thank you for your answer and for the good news.
I have already order the lights from aliexpress.
