Page 33 of 71
Re: iichels Polo 6R 1.2TDI Bluemotion --> OEM++ R-Line conversion
Posted: Wed Sep 23, 2020 2:19 pm
by iichel
Just regular maintenance... 4 new tires (old Hankook V12 were 2mm, so they were finished with the autumn rain coming).
New pair of Bridgestone Potenza 215/40 R17 mounted
The mechanic was surprised to see the Polo 6R with TPMS sensors. He was a bit confused and was looking for the reset button on the RNS510
Posted: Tue Sep 29, 2020 7:40 am
by ciclo
iichel wrote: âWed Sep 23, 2020 2:19 pm
New pair of
Michel, I'm a bit confused with your 6Rs, I thought you upgraded the front brake discs on your 1.2 TDI R-line ...
edit... maybe I'm seeing the front discs too small in that image ...
Posted: Tue Sep 29, 2020 7:50 am
by CNK
ciclo wrote: âTue Sep 29, 2020 7:40 am
Yep, he uses the same sizes of brakes like in Polo WRC Street, if I remember correctly they comes from Audi TT 8N.
Michel installed better brakes before me, a long time ago
Posted: Tue Sep 29, 2020 8:09 am
by ciclo
Thanks Szymon, ...I checked it on the first pg.
It's just that the front discs seemed a bit small to me in that image ...
I hope everything goes well with you.
Posted: Tue Sep 29, 2020 8:30 am
by iichel
New pair of
Szymon is completely right, perhaps the image doesn't do the size justice but it's 312mm at the front and 256mm at the rear. It's the WRC configuration.
It's a mix of several cars. Front calipers are 6R GTI, carriers are 6R WRC. Rear caliper carriers are Golf 4 GTI Jubileum edition and calipers are Audi 8N TT Quattro.
ciclo wrote: âTue Sep 29, 2020 8:09 am
All is good here. We have some stricter corona measures here since last night, still relatively easy compared to other countries in Europe.
We are still healthy and doing our best to stay out of trouble. I wish you and all the other forum members well in these interesting times.
Posted: Wed Sep 30, 2020 9:26 am
by ciclo
We are also well and fortunately we have not caught the infection yet, we continue with our particular way of protecting ourselves from this second wave of infections, which was very predictable (perhaps acceptable) after the supposed summer holidays and back to school, work, etc.
The show must go on, no doubt, but this pandemic has made it quite clear that the concept of humanity is not at its best. It seems that schools no longer teach that one was born on planet earth with other human beings who must be actively respected regardless of any ideology or condition.
I refer to health issues ... now the main thing is everyone's health.
Everything is compatible if done correctly, which requires a certain order and cheerful individual collaboration.
Posted: Tue Oct 06, 2020 2:18 pm
by patil
iichel wrote: âSat Sep 19, 2020 10:15 am
I'm curious to hear, thanks for checking. Very interesting info!
Perhaps you can already active the light sensor function in VCDS without the auto light? Byte 13 bit 7.
Hi iichel..
I finished installing autolight wiring I received from Master Ciclo successfully. After activating light sensor, the side assist(5Q0 radars) led brightness is indeed regulated by light sensor.!!
I could appreciate the difference in led brightness before and after activating the light sensor. In advanced measuring values of 3C address, I can see the values.
Posted: Tue Oct 06, 2020 2:36 pm
by CNK
good news
one day maybe I will also install 5Q0 radars (if will still alive)
Posted: Tue Oct 06, 2020 2:48 pm
by iichel
this is very interesting information, thank you very much
Posted: Thu Oct 08, 2020 5:15 am
by ciclo
iichel wrote: âTue Oct 06, 2020 2:48 pm
yes, ...at least we confirmed what we already suspected.
On the other hand, we confirm that Patil, our beloved Doctor, is notably improving in these matters ...
Posted: Thu Oct 08, 2020 5:22 pm
by patil
ciclo wrote: âThu Oct 08, 2020 5:15 am
I couldn't agree more Master
I still remember when it all started with dimmer switch installation few years ago, I have come a long way since then.
I take this opportunity to thank this beautiful forum, admins, members and especially Master Ciclo, iichel and others for immensely contributing the knowledge I and other have gained here.
We shall keep reviving dying PQ25
Posted: Thu Nov 12, 2020 3:03 pm
by iichel
Just a regular maintenance autoscan
Nothing too strange going on lately.
Just some small repairs:
- Replaced ventilator resistor
- Replaced wiring loom in roof due to a small melt-down but all the fuses did their work nicely
- Passed the yearly mandatory official inspection with compliments of the inspector
- Updated VCDS to the most recent version (very big advantage of original interface)
- Replaced a few broken LEDs
Done some small coding changes to suit my preferences
- Disabled rain closing since this doesn't work
- Disabled autobahn light (lights on if you drive faster than 140 kph)
Thursday,12,November,2020,15:57:51:11868
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(VMWare)
VCDS Version 20.4.2.0 (x64) HEX-V2 CB: 0.4513.4
Data version: 20200730 DS317.0
www.Ross-Tech.com
Workshop Code: 123 31889 005683
VIN: WVWZZZ6RZBYiichel License Plate:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 03 04 05 08 09 10 15 17 19 20 25 2B 2E 37 3C 44 47 55 56 57 61 65 69 6C 77
05-Acc/Start Auth. -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
47-Sound System -- Status: OK 0000
56-Radio -- Status: OK 0000
57-TV Tuner -- Status: OK 0000
69-Trailer -- Status: OK 0000
Address 01: Engine (J000-CFWA) Labels:. 03P-906-021-CFW.clb
Part No SW: 03P 906 021 B HW: 03P 907 425
Component: R3 1.2l TDI H06 9980
Revision: 12005001 Serial number:
Coding: 00114036033401080000
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_ECM12TDI03103P906021B 001043
ROD: EV_ECM12TDI03103P906021B.rod
VCID: 270B06DDAF6FF1F3339-8073
Readiness: 0 0 0 0 X
Part No SW: 6R0 907 379 AS HW: 6R0 907 379 AS
Component: ESP9.0i front 0002
Serial number: --------------
Coding: 21DD2885432500C5841A146EC25500521505
Shop #: WSC 31889 123 05683
ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
VCID: 0F7B4E7D27DF89B3DB9-805B
Address 05: Acc/Start Auth. Labels:. 5K0-959-434.clb
Part No SW: 5K0 959 434 E HW: 5K0 959 434
Revision: 00092000
Coding: 56574B45535359505133354750
VCID: 372BD69D7FCF6173A39-8063
No ASAM data for: "" (VW25)
Part No SW: 6R0 907 044 H HW: 6R0 907 044 H
Component: Climatronic H12 0812
Revision: V0000000
VCID: 3829D5A172516E0BAA3-806D
Part No SW: 7E0 937 090 C HW: 7E0 937 090 C
Revision: B9082001 Serial number: 4000 173171327
Coding: 3EB02FBF68EB2400B33807E0FFEB9FF0F08060EF608D78D071E000030800
VCID: 2B03FAEDB307D593D71-807F
Component: RLHS 220816 0 42 0106
Coding: 0214DD
Subsystem 2 - Part No SW: 6R0 959 801 BD HW: 6R0 959 801 BD Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 8611
Serial number: KU0KU011111300010103
Coding: 0200A3
Subsystem 3 - Part No SW: 6R0 959 802 BF HW: 6R0 959 802 BF Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 003 8611
Serial number: KU0KU007111300016463
Coding: 1000AB
Component: DWA-Sensor 00 001 0103
Component: LIN BACKUP HO H05 1501
Subsystem 8 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Serial number: KU0KU027011200011418
Coding: 58BC32
Subsystem 9 - Part No SW: 6R0 959 812 B HW: 6R0 959 812 B
Component: J389__TSG_HR 002 0803
Serial number: KU0-KU004.06.0913330
Coding: 08BC32
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 L HW: 7N0 919 475
Component: PARKHILFE 8K H06 0106
Revision: -------- Serial number: 28231422402620
Coding: 318001
VCID: 3B23CAAD43E74513471-806F
Address 15: Airbags Labels:| 5K0-959-655.clb
Revision: --------
Coding: 00314D
Shop #: WSC 01383 785 00200
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4ACD9F691C3DEC9BCC7-801F
Serial number: 3575HRB40650BI7U48C8
Coding: 00
Serial number: 3515RRB405T0BTBEF9G7
Serial number: 3525RRB405R0BTBEKPFQ
Address 17: Instruments (J285) Labels:. 5K0-920-xxx-17.clb
Part No SW: 6R0 920 870 A HW: 6R0 920 870 A
Component: KOMBI 0709
Coding: 140F01
VCID: 3333E28D6BB78D539F1-8067
No ASAM data for: "" (VW36 *)
Part No SW: 7E0 909 901 HW: 7E0 937 090 C
Revision: B9082001
Coding: 042200
VCID: 688945E162713E8BFA3-803D
Address 20: High Beam Assist. (J844) Labels:| 8S0-857-511.clb
Part No SW: 7E0 857 511 G HW: 7E0 857 511 E
Component: FLA H10 0003
Revision: AA001001
Coding: 0404000000000000010000
VCID: 2E05F3F98095A0BBF0F-807B
Component: IMMO H04 0709
Coding: 000007
VCID: 6A8D3FE97CFD0C9BEC7-803F
Address 2B: Steer. Col. Lock (J764) Labels: 5K0-905-861.clb
Part No SW: 5K0 905 861 B HW: 5K0 905 861 B
Component: ELV-PQ35 H20 0240
Revision: 00000000 Serial number: 11000256123005
Coding: 4100000000000000
ASAM Dataset: EV_ELVMarquMPVW36X A01001
ROD: N/A
VCID: 2F3BEEFD879FA9B3FB9-807B
No ASAM data for: "EV_ELVMarquMPVW36X" (VW25)
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 G HW: 5N0 035 342 G
Component: SG EXT.PLAYER H19 0770
Revision: A1001003 Serial number: 7666620365
Coding: 010100
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 1T0 035 686 E HW: 1T0 035 686 H
Component: RNS-MID H26 6276
Revision: AB001001 Serial number: VWZ6Z7P1950254
Coding: 00070002010000A10001
VCID: 3635DB997845987BB8F-8063
Subsystem 1 - Part No: 1T0 051 859 AS
Component: EU West V17 8557
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 7E0 907 566 B HW: 4L0 907 566 A
Component: J0769 SWA MasterH13 0120
Revision: 00H13000 Serial number: 6PZ 009 014-07
Coding: 0010161
Shop #: WSC 02756 790 00000
VCID: 2F3BEEFD8B1FA9B3FB9-807B
Subsystem 1 - Part No: 7E0 907 568 B
Component: J0770 SWA Slave H09 0110
Subsystem 2 - Serial number: 6PZ 009 014-27
Subsystem 3 - Serial number: 5F31.03.1100H090003CH21982Ë
Subsystem 4 - Serial number: H21982Ë
Address 44: Steering Assist (J792) Labels:| 6Rx-909-144-V2.clb
Part No SW: 6R1 909 144 AD HW: 6R1 909 144 E
Component: EPS_TRW_ALow 312 3124
Serial number: CF3F0205
Coding: 000300
ASAM Dataset: EV_SteerAssisUDSTRW 014026
ROD: EV_SteerAssisUDSTRW_014.rod
VCID: 79AF10A5095BB70315D-802D
Address 47: Sound System (R12) Labels: 5K0-035-456.clb
Part No SW: 5C6 035 456 C HW: 5C6 035 456 C
Component: KonzernAmp10K H08 6831
Revision: -------- Serial number: EAA098C0000052
ASAM Dataset: EV_AudioVerst10KanalSTT4 001001
ROD: N/A
VCID: 280905E1A271FE8B3A3-807D
No ASAM data for: "EV_AudioVerst10KanalSTT4" (VW25)
Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb
Part No SW: 6R0 907 357 C HW: 6R0 907 357 B
Component: AFS-ECU 005 0050
Revision: -------- Serial number: --------------
Coding: 0D4A000001000000
ROD: EV_HeadlRegulVWLWRCC.rod
VCID: 3A2DCFA94CDD7C1B5C7-806F
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
Address 57: TV Tuner Labels: None
Part No SW: 3C0 919 148 B HW: 3C0 919 148
Component: R78 DTV-JP 0250
Revision: R0H14000 Serial number: 80100800042102
Coding: 0000816
Shop #: WSC 01324 020 00200
VCID: 280905E1AEF1FE8B3A3-807D
Subsystem 1 - Part No: 4F0 919 805
Component: R204 TVKLeser 0010
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7E0 907 534 HW: 7E0 937 090 C
Component: Batt.regelung H82 0752
Coding: 030F1A5A
Subsystem 1 - Part No SW: 6C0 915 181 HW: 6C0 915 181
Component: J367-BDM H08 0223
Serial number: 61083A44504351928092
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 3AA 907 273 F HW: 5Q0 907 273
Serial number: 40000000058319
ROD: EV_RDKBERU30_005.rod
Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 E HW: 1K0 907 383 E
Component: Anhaenger H07 0080
Revision: 3A002002 Serial number: 00000116932377
Coding: 0100000100000000
VCID: 2F3BEEFD871FA9B3FB9-807B
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 7E0 907 441 HW: 7E0 907 441
Component: J772__Rearview 0040
Revision: 00H08000 Serial number: 525PA8-J060533
Coding: 0030115
VCID: 65974CD5996323E3C15-8031
Address 77: Telephone (J412) Labels:. 3C8-035-730-A.clb
Part No SW: 3C8 035 730 E HW: 3C8 035 730 E
Component: Telefon 0983
Revision: -------- Serial number: 35502105254406
Coding: 00
ASAM Dataset: EV_UHVPremi 002709
ROD: EV_UHVPremi.rod
VCID: 25170CD5D563E3E3015-8071
End----------(Elapsed Time: 02:36, VBatt start/end: 11.9V/14.1V)-----------
Posted: Mon Jan 11, 2021 11:14 pm
by Mocro
iichel wrote: âSat May 02, 2015 9:18 am
This way, the fog will be assessed to the empty place in the connector.
The reason for this is, the loose wire needs to go to fog in order to emit red light.
So now you have the passenger side tail light out, open it (it is a clicking system).
Take out the halogen fog light and put in the LED double color LED.
Solder the wire to the plate that ends in a dead end.
This is the pin that corresponds with the place where you moved the fog light wire to.
Now it is important to test first.
Put the car in reverse and you will see both sides have reverse light.
Put the car out of reverse and turn on rear fog. Now rear fog should light up in red.
If everything works, it can be necessary to turn of canbus error check of both rear fog and reverse.
What do you mean with this:
Do you have pictures or something?
So i have to solder the fog light pin to 1 or 2 see my picture?
- 82F5E547-BE1C-4ADF-AE68-E174C4C2D6DE.png (2.79 MiB) Viewed 2622 times
Posted: Tue Jan 12, 2021 6:25 am
by amer6R
Im also interested in this mode. One bulb doesnt do it for visibility.
Posted: Tue Jan 12, 2021 7:39 am
by iichel
Solder it to pin 5, place number two in your picture.
