Problem with electric window
- Drives: polo 6r 1.6 tdi dsg
Re: Problem with electric window
hello i know its little bit late but i have the same problem:(
i hope you would help to me
Sunday,18,March,2018,18:53:26:27676
VCDS Version: 17.1.3.0 (x64)
Data version: 20170220 DS267.3
www.Ross-Tech.com
VIN: WVWZZZ6RZEY064027 License Plate:
Mileage: 46670km-28999mi Repair Order:
Chassis Type: 6R (6N0)
Scan: 01 02 03 08 09 15 17 19 25 44 56
VIN: WVWZZZ6RZEY064027 Mileage: 46670km-28999miles
56-Radio -- Status: Malfunction 1110
Address 01: Engine (J623-CAYB) Labels: 03L-906-023-CAY.clb
Part No SW: 03L 906 023 MG HW: 03L 907 425 B
Component: R4 1.6l TDI H33 9979
Revision: --H33--- Serial number:
Coding: 00254016000400080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM16TDI02103L906023MG 003013
ROD: EV_ECM16TDI02103L906023LC.rod
VCID: 77FC68DFCEA158F9D8-8022
Readiness: 0 0 0 0 1
Part No SW: 0AM 300 058 F HW: 0AM 927 769 D
Component: GSG DSG AG7 431 4530
Revision: 00043014 Serial number: CU501307115999
Coding: 0000020
VCID: 34669FD3545773E13D-5140
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ABS82.clb
Part No SW: 6R0 907 379 AE HW: 6R0 907 379 AC
Component: ABS8.2 front H04 0001
Revision: --------
Coding: 200228E3017300B6042514E480D800000200
VCID: 010806079C651649E6-8054
Address 08: Auto HVAC (J301) Labels: None
Part No SW: 6R0 820 045 N HW: 6R0 820 045 N
Component: Man AC H02 0202
Revision: 0003SH02
VCID: 3978AEE7B0358E89EE-806C
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 P HW: 6R0 937 087
Component: BCM PQ25 H+4 H34 0411
Revision: BF034001 Serial number: 0581 214130719
Coding: 7CB82FBF68A3000000380E007F2B9CD90008410F60040040300000000000
Shop #: WSC 124697 483 00190
VCID: 4A9AE12BE5D3151177-801E
Subsystem 1 - Part No SW: 6R0 959 801 AT HW: 6R0 959 801 AT Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 8610
Serial number: KU0KU008081300013291
Coding: 0200A0
Subsystem 2 - Part No SW: 6R0 959 802 BE HW: 6R0 959 802 BE Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 003 8610
Serial number: KU0KU007081300015312
Coding: 0200A0
Subsystem 3 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H31 0037
Serial number: 0108556
Coding: 020000
Subsystem 4 - Part No SW: 6R0 959 811 N HW: 6R0 959 811 N
Component: J388__TSG_HL 003 8610
Serial number: KU0KU009081300012542
Coding: 0000A0
Subsystem 5 - Part No SW: 6R0 959 812 N HW: 6R0 959 812 N
Component: J389__TSG_HR 003 8610
Serial number: KU0KU001081300014903
Coding: 1000A0
3 Faults Found:
00967 - Left Turn Signals
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 205
Mileage: 46679 km
Time Indication: 0
Date: 2018.03.18
Time: 18:45:43
00968 - Right Turn Signals
011 - Open Circuit
Fault Priority: 2
Fault Frequency: 1
Reset counter: 205
Mileage: 46679 km
Time Indication: 0
Date: 2018.03.18
Time: 18:45:43
00901 - Back-Up Lamps
011 - Open Circuit
Fault Priority: 2
Fault Frequency: 1
Reset counter: 205
Mileage: 46679 km
Time Indication: 0
Date: 2018.03.18
Time: 18:45:43
Part No SW: 6R0 959 655 J HW: 6R0 959 655 J
Component: VW10Airbag00G H10 0020
Revision: -------- Serial number: 003GW00MC8W$
Coding: 003047
Shop #: WSC 01383 785 00200
VCID: 4998DE27E8D51E097E-801C
Part No SW: 6R0 920 861 M HW: 6R0 920 861 M
Component: KOMBI H02 0406
Serial number: 00000017687764
Coding: 140A01
ASAM Dataset: EV_DashBoardUDSJCIPQ25 A01723
ROD: EV_DashBoardUDSJCIPQ25_A01_VW25.rod
VCID: 3F8CC0FFA611A0B9D0-806A
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 H34 0411
Revision: BF034001
Coding: 002200
VCID: 70EE53C3A3CF0FC119-8024
1 Fault Found:
01304 - Radio
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 205
Mileage: 46679 km
Time Indication: 0
Date: 2018.03.18
Time: 18:45:48
Address 25: Immobilizer (J285) Labels: 5K0-920-xxx-25.clb
Component: IMMO H02 0025
Serial number:
ASAM Dataset: EV_ImmobUDSJCIPQ25 A01003
ROD: EV_ImmobUDSJCIPQ25.rod
VCID: 6ADA41AB8D13F51157-803E
Part No: 6R0 423 156 C
Component: LenkhilfeTRW V278
Coding: 10150
Shop #: WSC 00788
VCID: 306E93C3F74F4FC159-8064
Address 56: Radio
Cannot be reached
End-------------------------(Elapsed Time: 02:22)--------------------------
www.Ross-Tech.com
Coding: 0000020
Revision: --------
Revision: 0003SH02
Coding: 0200A0
Coding: 0200A0
Coding: 020000
Coding: 0000A0
Coding: 1000A0
3 Faults Found:
011 - Open Circuit
Fault Priority: 2
Fault Frequency: 1
Reset counter: 205
Mileage: 46679 km
Time Indication: 0
Date: 2018.03.18
Time: 18:45:43
011 - Open Circuit
Fault Priority: 2
Fault Frequency: 1
Reset counter: 205
Mileage: 46679 km
Time Indication: 0
Date: 2018.03.18
Time: 18:45:43
011 - Open Circuit
Fault Priority: 2
Fault Frequency: 1
Reset counter: 205
Mileage: 46679 km
Time Indication: 0
Date: 2018.03.18
Time: 18:45:43
Coding: 003047
Coding: 140A01
Revision: BF034001
Coding: 002200
1 Fault Found:
01304 - Radio
Fault Priority: 2
Fault Frequency: 1
Reset counter: 205
Mileage: 46679 km
Time Indication: 0
Date: 2018.03.18
Time: 18:45:48
Serial number:
Coding: 10150
Shop #: WSC 00788
Address 56: Radio
Cannot be reached
Hello reborno, welcome. (manchester)
RHD or LHD?
Do the following if it's RHD.
New GW coding.
Revision: BF034001
Coding: 002300
New WRMs codings. (4)
Coding: 1000A0
Coding: 0000A0
Coding: 1000A0
Coding: 0000A0
... and set the comfort function with window switches according the user manual.
Please report the results.
What happened or were you doing for this fault to happen?
I know it's an LHD but maybe I'm wrong.
RHD or LHD?
New GW coding.
Revision: BF034001
Coding: 002300
Coding: 1000A0
Coding: 0000A0
Coding: 1000A0
Coding: 0000A0
I tried to change everything for to fix problem. And also I am flying to madrid today;) i heard most from spain. Car options was module not installed and lhd rhd was not installed before i changed them. Should i return to previous? Tomorrow i would inform the codes, thank u friend
It is lhd. Should i try the codea anyway?
LHD
GW coding.
Revision: BF034001
Coding: 002200
WRMs codings. (4)
Coding: 0000A0
Coding: 1000A0
Coding: 0000A0
Coding: 1000A0
GW coding.
Revision: BF034001
Coding: 002200
WRMs codings. (4)
Coding: 0000A0
Coding: 1000A0
Coding: 0000A0
Coding: 1000A0
Great. Its working! Thank you bro
- Drives: Polo Highline 1.2 Petrol 6R
Hello ,
I am also facing the same issue . The driver and the front passenger side windows are working in wrong way .
This is a RHD polo [indian specific].
Possible cause - I had tested a VCP cable on my car at my friends place for the intermittent headlights(H4 led bulbs) getting off [ I have replaced all bulbs with led bulbs in my car]. The issue was not resolved but I am getting a whole lot of errors now in the VCDS autoscan .
Please also let me know if its possible to stop led headlight flickering [ intermittent turning off and on ] using VCDS .
Can someone please help me !!
VCDS Scan :
Wednesday,10,October,2018,15:45:32:00006
VCDS Version: 18.2.0.3 (x64)
Data version: 20180212 DS287.0
www.Ross-Tech.com
VIN: WVWB10602AT000319 License Plate:
Mileage: 56200km-34921mi Repair Order:
Chassis Type: 60-VW25 (6N0)
Scan: 01 03 09 15 17 19 25 44
VIN: WVWB10602AT000319 Mileage: 56200km-34921miles
Address 01: Engine (CJL) Labels: None
Part No SW: 03E 906 023 P HW: 03E 906 023 P
Component: SIMOS91 1.2l 4V 5811
Revision: --H05--- Serial number: 00000000000000
Coding: 0000031
Shop #: WSC 01234 785 00200
VCID: 2C57B2B28C0B312494-5178
2 Faults Found:
18045 - Powertrain Data Bus
P1637 - 009 - Missing Message from Electric Load Controller - Intermittent
16556 - Fuel Trim; Bank 1
P0172 - 007 - System Too Rich - Intermittent
Readiness: 0010 0001
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ABS82.clb
Part No SW: 6RF 907 379 HW: 6R0 907 379 AB
Component: ABS8.2 front H03 0002
Revision: --------
Coding: 500200C1006D00B20A2800E300DA00004000
Shop #: WSC 02069 000 00000
VCID: 11290346CC697CCC87-8044
1 Fault Found:
01299 - Diagnostic Interface for Data Bus (J533)
Fault Status: 00100100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 88
Mileage: 55703 km
Time Indication: 0
Date: 2013.02.05
Time: 16:22:30
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x32D4
Hex Value: 0x16A9
Hex Value: 0x00FF
Hex Value: 0x007F
Hex Value: 0x7E00
Hex Value: 0x0000
Part No SW: 6RU 937 086 HW: 6RU 937 086
Component: BCM25 IM M+4 H46 0207
Revision: BY046001 Serial number: 0118 289090026
Coding: 32B02BBF08B30000003000003C2B04900040410F60040000200000000000
VCID: 1E33687A09B7D3B40A-804A
Subsystem 1 - Part No SW: 6R0 959 802 D HW: 6R0 959 802 D Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 002 3411
Coding: 030000
Subsystem 2 - Part No SW: 6R0 959 801 F HW: 6R0 959 801 F Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 002 3411
Coding: 030000
Subsystem 3 - Part No SW: 6R0 959 811 E HW: 6R0 959 811 E
Component: J388__TSG_HL 002 3411
Coding: 020000
Subsystem 4 - Part No SW: 6R0 959 812 E HW: 6R0 959 812 E
Component: J389__TSG_HR 002 3411
Coding: 020000
2 Faults Found:
01332 - Door Control Module; Passenger Side (J387)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 88
Time Indication: 0
01331 - Door Control Module; Driver Side (J386)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 88
Mileage: 55703 km
Time Indication: 0
Date: 2013.02.05
Time: 16:39:24
Part No SW: 6R0 959 655 E HW: 6R0 959 655 E
Component: VW10Airbag600 H09 0018
Revision: -------- Serial number: 003DY000EBLA
Coding: 003030
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4487FA12CF9BD9647C-8010
1 Fault Found:
12666368 - Databus
U1122 00 [008] - Implausible Message
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 88
Part No SW: 6RF 920 860 HW: 6RF 920 860
Component: KOMBI X05 0006
Coding: 540800
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
VCID: 071D2D1EBE2D327C59-8052
1 Fault Found:
12664832 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Fault Priority: 6
Fault Frequency: 2
Reset counter: 88
Mileage: 55703 km
Date: 2018.09.15
Time: 16:22:29
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6RU 937 086
Component: GW-K-CAN TP20 0207
Coding: 002340
VCID: 70EF66C2A3A315C4E8-8024
Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb
Component: IMMO X05 0006
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03003
ROD: EV_Immo_UDS_VDD_RM09.rod
Part No: 6R0 423 156 A
Component: LenkhilfeTRW V275
Coding: 10150
Shop #: WSC 01234
VCID: 2E53B8BAED174334BA-807A
End-------------------------(Elapsed Time: 02:02)--------------------------
VCDS Scan :
www.Ross-Tech.com
Coding: 0000031
2 Faults Found:
Revision: --------
1 Fault Found:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 88
Mileage: 55703 km
Time Indication: 0
Date: 2013.02.05
Time: 16:22:30
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x32D4
Hex Value: 0x16A9
Hex Value: 0x00FF
Hex Value: 0x007F
Hex Value: 0x7E00
Hex Value: 0x0000
Coding: 030000
Coding: 030000
Coding: 020000
Coding: 020000
2 Faults Found:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 88
Time Indication: 0
Fault Priority: 2
Fault Frequency: 1
Reset counter: 88
Mileage: 55703 km
Time Indication: 0
Date: 2013.02.05
Time: 16:39:24
Coding: 003030
1 Fault Found:
12666368 - Databus
Fault Priority: 6
Fault Frequency: 1
Reset counter: 88
Coding: 540800
1 Fault Found:
U1111 00 [008] - -
Fault Priority: 6
Fault Frequency: 2
Reset counter: 88
Mileage: 55703 km
Date: 2018.09.15
Time: 16:22:29
Coding: 002340
Coding: 10150
Shop #: WSC 01234
No communication to either door control module. These modules also house the window motors.
You could start with having a look at the fuses, otherwise there could be something wrong with either the LIN connection (databus).
thank you iichel .
I have checked all the fuses , all are fine . I had also removed the battery negative terminal for 10 min and reconnected but still same issue .
All the power windows are working fine , only the front power windows are working in opposite .
Can you please tell how to check the LIN connection/databus !
Can anything be done using VCDS long coding to resolve the error.
I doubt something has gone wrong with canbus coding while using clone VCP cable few weeks back for led issue as my vehicle displayed 'TRV/trn' in dashboard and the central locking was disabled but the vehicle was running fine with the key and manual locking/unlocking.
Now 'trv/trn' mode and remote locking/unlocking is resolved but the front windows are working in opposite .
Well, the error is intermittent and the only thing they share is the data line.
I would check the wire from the bcm to either door module. Measure continuity end to end with a multimeter. Inspect the rubbers in the door hinges for damage, undo the connectors in the a pillar to check for corrosion and breaks in the wiring.
I'm not familiar enough with the coding of these door modules. Maybe ciclo can have a look at them, he knows a lot about them. But if you haven't changed the coding, I'm hesitant it is the source of your problem
Issue is resolved now ..
For anyone facing this issue with the below central electronics module :
Coding: 030000
New Coding : 010000
Coding: 030000
New Coding : 010000
Search for the VCDS autoscan results for your car model .Try to find the exact match with the Part No SW , HW ,component.
If your codings are different , update the new codes found from the Autoscan and give it a try.
Thanks iichel ,ciclo .
@ciclo - your replies on the earlier posts made me think for this solution and I hope above method is correct .
Coding: 030000
New Coding : 010000
Coding: 030000
New Coding : 010000
- Drives: 1.6 TDI 6R 90HP CAYB
Hello to all.
I'm digging up this thread to ask for your help as I am facing a similar problem with my Polo 6R CAYB 2010 RHD.
I experience intermittent problems with driver's (mainly) and passenger's window: automation is not working quite often and in the same time the windows are running on the wrong way. When I pull the switch, it should close the window but now the window is coming down when I pull the switch.
Any help/advice will be much appreciated!
*I will upload the full VCDS scan asap as I cannot post the log file neither as text nor as code*
