Poor quality audio from TPK Bluetooth system
Re: Poor quality audio from TPK Bluetooth system
Hi m8 took radio out but couldn't find where to plug cable in have got a photo of this
- Drives: 2012
Hi, I have the RCD 310 with the TPK system. As others have stated, playing music from the Bluetooth is very poor as the sound quality is really bad. Using the AUX connection is fine but @wilxay or anyone else, I read that if you plug is a 3.5mm into the back of the stereo and into the AUX input located next to the 12v the music will play fine using the Bluetooth. The problem I have is that I have no idea where I need to plug the 3.5mm end behind the stereo? I took out the head unit but couldn't see anywhere to plug the 3.5mm end into. Can anyone tell me where that needs to be plugged in?
