Needle sweep
- Drives: 1.2 TSI (105) SEL polo 6r
Needle sweep
Is it possible to activate needle sweep in my 2011 polo TSI 1.2 SEL?
Re: Needle sweep
Fifty per cent of time yes you can activate needle sweep on your cluster via VCDS
But some cluster's will not allow you activate this function even with VCDS, which has to be edited by eeprom to be enabled.
Re: Needle sweep
eeprom?
Re: Needle sweep
Yes eeprom, using special cluster software you can rewrite the file so it enables the cluster to have needle sweep.
Re: Needle sweep
Ah! Something new i didnt know
Can anyone do it or do you need to be knowledgable on how to rewrite the files?
Re: Needle sweep
if you're on of the lucky 50%: vcds, 17 instruments, adaptation, enable indicator celebration or staging.
if it says 'channel not available', you're not so lucky
Re: Needle sweep
Oh! I have tried that method and I am indeed one of the Unlucky bunch.
Didnt recognise the word eeprom.
Re: Needle sweep
Electrically erasable programmable read-only memory
- Drives: Polo 1.4 2013 6R
Re: Needle sweep
Hey where can i get someone to do this to my cluster ?. Does anyone know ?.
Re: Needle sweep
To anyone interested, I can enable needle sweep to any VW Polo 6R cluster/tacho which can't be activated via VCDS.
Re: Needle sweep
Oh how ?. Im in iceland..lolJIC Cracked wrote:To anyone interested, I can enable needle sweep to any VW Polo 6R cluster/tacho which can't be activated via VCDS.
Re: Needle sweep
Don't worry my friend I used to live in Iceland myself a good few years back.
I might be there in July or August?
Re: Needle sweep
Oh what really ?. How did you like living here ?.JIC Cracked wrote:Don't worry my friend I used to live in Iceland myself a good few years back.
That would be great!!
- Ugabista
- Drives: Vw Polo 6R 1.6TDI 90CV CAYB
Re: Needle sweep
Hi,JIC Cracked wrote:To anyone interested, I can enable needle sweep to any VW Polo 6R cluster/tacho which can't be activated via VCDS.
can you give more information about this?
I have the vag programmer and the vag commander + editor hex xvi32.
Do you know witch hexadecimal field changes?
Re: Needle sweep
Yeah I would be interested in this aswell
