If you don´t know your original coding, please try reading the following to generate the right one.Benetnash wrote: ↑Tue May 01, 2018 5:55 pm Hello,
I'd like to get help with my Polo, problem is ABS Long Coding is all zeros,
Some time ago, there was a problem with an ECU, and as result there was swap of ECU, Instrument Cluster and Immo, everything runing smooth, but
there is no coding in ABS, and when I try to input a code, VCDS says something like this "Coding Rejected. Error 22: Conditions not correct or request sequence error".
here is my AutoScan, I hope some one can helpThere is also wrong coding in CAN Gateway, any sugestions?Code: Select all
Tuesday,01,May,2018,12:40:55:00006 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 18.2.0.3 (x64) Data version: 20180212 DS287.0 www.Ross-Tech.com Dealer/Shop Name: FIX VIN: WVWZZZ6RZAY019004 License Plate: Chassis Type: 6R-VW25 (6N0) Scan: 01 03 04 08 09 15 17 19 25 44 56 VIN: WVWZZZ6RZAY019004 Mileage: 79350km-49305miles 01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: Malfunction 0010 04-Steering Angle -- Status: Not registered 0001 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: OK 0000 15-Airbags -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 25-Immobilizer -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 56-Radio -- Status: Malfunction 0010 ------------------------------------------------------------------------------- Address 01: Engine (CGP) Labels: 03E-906-033-AZQ.lbl Part No SW: 03E 906 023 L HW: 03E 906 023 L Component: SIMOS91 1.2l 4V 4489 Revision: --H04--- Serial number: Coding: 0000071 Shop #: WSC 00000 000 163936 VCID: 285F4EA298F31D0470-515A No fault code found. Readiness: N/A ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb Part No SW: 6R0 907 379 R HW: 6R0 907 379 R Component: ESP8.2i front H04 0002 Revision: -------- Coding: 000000000000000000000000000000000000 Shop #: WSC 02069 000 00000 VCID: 4D91DF3610D1182CA3-8018 2 Faults Found: 03306 - Coding Not Valid 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 0 Fault Frequency: 6 Reset counter: 78 Mileage: 79356 km Time Indication: 0 Date: 2012.09.21 Time: 12:18:10 Freeze Frame: Hex Value: 0x0003 Hex Value: 0x0002 Hex Value: 0x32E7 Hex Value: 0x2598 Hex Value: 0x007F Hex Value: 0x7F7F Hex Value: 0x7F00 Hex Value: 0x0000 01042 - Control Module; Not Coded 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 0 Fault Frequency: 2 Reset counter: 78 Mileage: 79356 km Time Indication: 0 Date: 2012.09.21 Time: 12:23:26 Freeze Frame: Hex Value: 0x0007 Hex Value: 0x0002 Hex Value: 0x3211 Hex Value: 0x1498 Hex Value: 0x007F Hex Value: 0x7F7F Hex Value: 0x7F00 Hex Value: 0x0000 ------------------------------------------------------------------------------- Address 08: Auto HVAC (J301) Labels: 6R0-820-045-9AP.clb Part No SW: 6R0 820 045 HW: 6R0 820 045 Component: Climatic 23 0500 Revision: 00 09 23 VCID: 6BD571AE8A85F61CDD-803E 1 Fault Found: 16372 - Control Module; Unspecified Internal Error 014 - Defective Freeze Frame: Fault Status: 01101110 Fault Priority: 1 Fault Frequency: 1 Reset counter: 255 Mileage: 15444 km Time Indication: 0 Date: 2011.01.02 Time: 16:42:59 ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb Part No SW: 6R0 937 087 D HW: 6R0 937 087 D Component: BCM PQ25 H+4 H46 0207 Revision: BF046001 Serial number: 0147 045100658 Coding: 3CB82DBF08A10000002000C03F6B0CD8B0C841DF60060000200000000000 Shop #: WSC 12345 123 61029 VCID: 3E7388FAA977B3B42A-806A Subsystem 1 - Part No SW: 6R0 959 801 R HW: 6R0 959 801 R Labels: 6R0-959-801.CLB Component: J386__TSG_FT 006 0912 Serial number: KU0-KU020.01.1011432 Coding: 08BC30 Subsystem 2 - Part No SW: 6R0 959 802 T HW: 6R0 959 802 T Labels: 6R0-959-802.CLB Component: J387__TSG_BT 006 0912 Serial number: KU0-KU002.02.1014646 Coding: 08BC30 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:| 5K0-959-655.clb Part No SW: 6R0 959 655 C HW: 6R0 959 655 C Component: VW10Airbag00L H09 0018 Revision: -------- Serial number: 003DW00CD63$ Coding: 00304C Shop #: WSC 124697 483 00190 ASAM Dataset: EV_AirbaVW10BPAVW250 A01001 ROD: EV_AirbaVW10BPAVW250.rod VCID: 428BFC0AD58FD7544E-8016 Crash sensor for side airbag: driver side: Serial number: 3572SRB40000AB110A2- Crash sensor for side airbag: front passenger side: Serial number: 3582SRB40000AB114A95 Crash sensor for side airbag: rear: driver side: Serial number: 3516GRB402N9LLFMQ3HH Crash sensor for side airbag: rear: passenger side: Serial number: 3526GRB402V9LLFMKJS4 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1 Part No SW: 6R0 920 860 A HW: 6R0 920 860 A Component: KOMBI H23 0110 Serial number: 00000000000000 Coding: 140A00 Shop #: WSC 12345 123 61029 ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040 ROD: EV_Kombi_UDS_VDD_RM09_004_VW25.rod VCID: 326BACCA652F67D4DE-8066 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb Part No SW: 6N0 909 901 HW: 6R0 937 087 D Component: GW-K-CAN TP20 0207 Coding: 000100 Shop #: WSC 12345 123 61029 VCID: 70EF66C2A3A315C4E8-8024 1 Fault Found: 01044 - Control Module Incorrectly Coded 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 2 Fault Frequency: 2 Reset counter: 255 Mileage: 79356 km Time Indication: 0 Date: 2012.09.20 Time: 23:54:45 ------------------------------------------------------------------------------- Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb Part No SW: 6R0 920 860 A HW: 6R0 920 860 A Component: IMMO H23 0110 Serial number: ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004 ROD: EV_Immo_UDS_VDD_RM09.rod VCID: 326BACCA652F67D4DE-8066 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 6Q0-423-156.clb Part No: 6R0 423 156 A Component: LenkhilfeTRW V275 Coding: 11241 Shop #: WSC 06402 VCID: 2E53B8BAED174334BA-807A No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb Part No SW: 5M0 035 186 AA HW: 5M0 035 186 AA Component: Radio RCD310 013 0036 Revision: 01000000 Serial number: VWZ1Z2I6253963 Coding: 0500040004 Shop #: WSC 124697 483 00190 VCID: 6BD571AE8A85F61CDD-803E 4 Faults Found: 00876 - Treble Speaker Rear Left (R14) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 60 Mileage: 78828 km Time Indication: 0 Date: 2012.09.14 Time: 13:33:19 00877 - Treble Speaker Rear Right (R16) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 60 Mileage: 78828 km Time Indication: 0 Date: 2012.09.14 Time: 13:33:19 00821 - Antenna 2 for Radio (R93) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 60 Mileage: 78828 km Time Indication: 0 Date: 2012.09.14 Time: 13:33:25 03138 - Input AUX IN 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 68 Mileage: 79192 km Time Indication: 0 Date: 2012.09.16 Time: 13:53:48 End-------------------------(Elapsed Time: 02:04)--------------------------
https://www.mypolo.nl/xenforo/threads/6 ... ish.11917/
