Thank you!!iichel wrote: ↑Thu Jun 11, 2020 1:49 pm I'll share my google drive folder with all the information i found:
https://drive.google.com/drive/folders/ ... sp=sharing
retrofitting kessy to the Polo 6R
- Drives: 6R Polo(Vento)1.6TDi, Skoda Fabia 1.2MPi
Re: retrofitting kessy to the Polo 6R
Hello
Sorry as I know this thread is for Polo but I need some help with my Skoda Octavia mkII KESSY GO.
Octavia is PQ35 but I guess the procedure will be same as this . I have access few tools like VCDS , ODIS online , AVDI and VVDI
I have collected all the parts needed to do the upgrade. The mistake I made is I bought a new ELV
From what I have read I can not adapt new ELV to my car . I have to have a used one with the PIN and CS because Octavia MKII did not came with KESSY SO i can not adapt it using ODIS . So what I am hoping to do is adapt this ELV to a Skoda Superb MK II using ODIS which have the KESSY GO then I can extract PIN and CS using AVDI then later adapt it with VVDI in my car
Please suggest that is it possible to do this way or is there any way that I can adapt the new ELV using VCDS.
I don't know of any way to adapt your ELV, sorry
- Drives: Just a VW
brand new ELV can be adapt online to any compatibile IMMo system carSudhanshu.S wrote: ↑Sat Aug 01, 2020 7:01 am Hello
then you can play with AVDI
Hi
Thanks for the guide with ELV adaptation
So far I adapted it via Odis Online then extracted the CS pin after that I readapted it to my Car.
Now after that I need KESSY Module and Keys to be adapted . But so far I am not able to , I am getting “No or incorrect basic setting “ fault. I am using a used KESSY Module , how can I fix this any help is highly appreciated
@Iichel
So finally I have sourced all part required for KESSY retrofit.
Thanks to CNK, Spacewalker
I need some help from you for installation.
@Iichel
Here I am bit confused!iichel wrote: ↑Wed Mar 01, 2017 1:11 pm I'm not sure the BCM itself is the problem. In the beetle 5C1 and new Jetta, the normal ignition lock also involves the converter box J935 and T73a/55.
It's not that the T73a/55 is exclusive to the kessy system. It's present in all cars. My current 7E0 937 090 has the necessary pins for kessy (T73a/47, /55).
What exactly converter box J935 does?
My present BCM is 7E0 937 090 E
So do I need to add J935 relay?
if you do not mind please, elaborate this
Yes, it is needed to convert some of the input and output logic. Without converter box, it won't work. I tried
KESSY retrofit on 6R Vento
- IMG_20210130_094202.jpg (158.27 KiB) Viewed 2472 times
- KESSY KIT, door handle given for paint
- IMG_20210611_170643.jpg (388.4 KiB) Viewed 2472 times
Is this the relay?
- download.jpg (3.4 KiB) Viewed 2469 times
- D_NQ_NP_693498-MLM40764858012_022020-O.jpg (33.26 KiB) Viewed 2469 times
Hi all
Thanks for sharing experiences on this retrofit.
From my side, I retrofitted Kessy on Golf 6. Immo is learnt, ELV, kessy and key are ok.
But ELV doesn't engage. It doesn't lock steering wheel.
Coding and adaptation channels of the 05 start/stop authentication, 09 central electrics and 25 immobiliser have been checked with a working kessy car.
No differences found there.
I don't have defaults with VCDS.
Do you have an idea ?
thanks
thanks
What brand is your ELV?
What car does it come from?
Hi
Thanks for answering.
My ELV is VW.
It comes from Golf6.
I'm exactly in the iichel case:
https://forums.ross-tech.com/index.php?threads/11360/
I hope He will explain how he solved this situation
My ELV is VW.
- Shadow109
- Drives: Vw t5.1 2013
can you post autoscan ?
did you noticed any faults in vcds ?
