INSTALLING DIMMER SWITCH IN POLO-6R
patil
Post by patil »
Hello friends, I drive Polo6R 2015MY, TSI 1.2/DSG7/105hp.
Indian Polo does not come fitted with brightness control switch(Dimmer switch), but only fitted with headlight range control switch.
I am planning to install dimmer switch " 6Q0 941 333 C" . It has controls for both brightness as well as headlight range control.
I am posting a new topic with pictures as per advice of master ciclo :D
Picture of stock switch
Picture of new switch, which I am planning to install " 6Q0 941 333 C" .
Comparison
Back side of both switches(left is stock, right one is new switch)
Pictures of stock T6 connector
Fuse box Layout
VCDS autoscan
Thursday,02,March,2017,00:28:24:05031
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
www.Ross-Tech.com
VIN: MEXL15606GT048293   License Plate:
Chassis Type: 60 (6RU)
Scan: 01 02 03 08 09 15 17 19 25 44 56
VIN: MEXL15606GT048293   Mileage: 15420km-9581miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZB)       Labels: 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 KC    HW: 03F 907 309 AJ
   Component: SIMOS10.22AH10 6270
   Revision: --H10---    Serial number: 00000000000000
   Coding: 00250056232400080000
   Shop #: WSC 53863 002 1048576
   ASAM Dataset: EV_ECM21TFS02103F906070KC 004006
   ROD: N/A
   VCID: 6DD6519BBC82595686-8038
No ASAM data for: "EV_ECM21TFS02103F906070KC" (VW26)
Readiness: 0000 0000
Address 02: Auto Trans        Labels: 0AM-927-769.clb
   Part No SW: 0AM 300 065 N    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 6502
   Revision: 00043014    Serial number: CU501508317273
   Coding: 0000020
   Shop #: WSC 01260 002 1048576
   VCID: 3A7CAAC7754C3EEE53-806E
Address 03: ABS Brakes (J104)       Labels: None
   Part No SW: 6R0 907 379 BN    HW: 6R0 907 379 AS
   Component: ESP9.0i front H03 0001
   Serial number: --------------
   Coding: 62DD2463422703C8461624724254C0800908
   Shop #: WSC 29230 002 1048576
   ASAM Dataset: EV_Brake1ES9P0iBOSCH 003031
   ROD: N/A
   VCID: 0B123F03A256F76638-805E
No ASAM data for: "EV_Brake1ES9P0iBOSCH" (VW26)
   Part No SW: 6R0 907 044 Q    HW: 6R0 907 044 Q
   Component: Climatronic   H12 0615
   Revision: V0000000
   VCID: 418EDD2BD89A6D3612-8014
Address 09: Cent. Elect. (J519)       Labels: 6R0-937-08x-09.clb
   Part No SW: 6RU 937 087 M    HW: 6RU 937 087
   Component: BCM IM H+4    H40 0432
   Revision: BZ040001    Serial number: 0300 294150201
   Coding: 3AB02BFF08A10000003800007C2B949000C0414F608C0000200000000000
   Shop #: WSC 124697 483 00190
   VCID: 6CD05C9F8F98505E91-8038
   Subsystem 1 - Part No SW: 6R0 959 802 CC    HW: 6R0 959 802 CC  Labels: 6R0-959-802.CLB
   Component: -------------  007 5551
   Coding: 050000
   Subsystem 2 - Part No SW: 6R0 959 801 BT    HW: 6R0 959 801 BT  Labels: 6R0-959-801.CLB
   Coding: 050000
   Subsystem 3 - Part No SW: 6C0 959 442     HW: 6C0 959 442
   Component: E221__MFL-TAT  H04 0019
   Coding: 240000
   Subsystem 4 - Part No SW: 6R0 959 811 L    HW: 6R0 959 811 L
   Component: -------------  006 5550
   Coding: 020000
   Subsystem 5 - Part No SW: 6R0 959 812 L    HW: 6R0 959 812 L
   Coding: 020000
   Revision: --------    Serial number: 003GW0118WCJ
   Coding: 003036
   Shop #: WSC 01234 785 00200
   ASAM Dataset: EV_AirbaVW10BPVAW250 A01001
   ROD: N/A
   VCID: 499EC50BE8AAA576CA-801C
No ASAM data for: "EV_AirbaVW10BPVAW250" (VW26)
   Part No SW: 6RF 920 861     HW: 6RF 920 861
   Component: KOMBI         H01 0214
   Coding: 140800
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05729
   ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
   VCID: 0818000FB3209C7E15-805C
   Part No SW: 6RU 909 901     HW: 6RU 937 087
   Component: GW-K-CAN TP20 H40 0432
   Revision: BZ040001
   Coding: 002300
   VCID: 193E554B108A15F6BA-804C
   Component: IMMO          H01 0214
   Serial number:
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_DVD_RM09 A03710
   ROD: N/A
   VCID: 6ADC5A878D6C4E6EE3-803E
No ASAM data for: "EV_Immo_UDS_DVD_RM09" (VW36 *)
Address 44: Steering Assist (J500)       Labels: 1Sx-909-144-44.clb
   Part No SW: 1S2 909 144 P    HW: 1S2 909 144 P
   Component: EPS_ECU       H61 1702
   Coding: 0001000000000000
   ASAM Dataset: EV_TseerAssisNSK 014008
   ROD: N/A
   VCID: 418EDD2BD09A6D3612-8014
No ASAM data for: "EV_TseerAssisNSK" (VW12)
Address 56: Radio (J503)       Labels: None
   Part No SW: 6RD 035 187 A    HW: 6RD 035 187 A
   Component: MIB2-S-R-CN   025 0210
   Revision: -----001    Serial number: 01855GD0000318
   Coding: 00000440010005
   Shop #: WSC 00081 790 00118
   VCID: 4586C93BCCB241162E-8010
End-------------------------(Elapsed Time: 02:22)--------------------------
Any help to complete the installation will be gracefully accepted. :D
Re: INSTALLING DIMMER SWITCH IN POLO-6R
patil
Post by patil »
Thanks a lot master :D
I will study the diagram and get back to you.
Actually there is not much to study, are just two wires and the new Dimmer.
The new Dimmer (once connected) is the one that changes the direction of things. (signals)
Therefore:
- a wire from the output (b) of the SB7 fuse (to protect the installation, isolate original SB7b) to the slot 3 of the Dimmer connector.
- and the second wire spliced to the wire that feeds the right parking/side light to the 'A' point (diagram pic) to power the license plate lights. (isolate the cut ends)
Use a multimeter to know the exact points. :wink:
The signal for the license plate lights must always be 58.
Simple, easy, and effective ...
With BCM Max it is otherwise. (yours is BCM High)
If someone illustrates all this with images it will help others. :|
Oh! yes, patil, excellent images and info. Thank you very much for that. :D
  This is the way to ask ... :mrgreen:
patil
Post by patil »
Thank you so much master for your kind words :D I am happy that I lived up to your expectations :D
Now I understood clearly what I am supposed to do. But still I have some questions to you as follows:
1. What do you mean by " to protect the installation, isolate original SB7b" What are the consequences if I leave it connected
2. Where should I use the multimeter( I mean during which step of installation)
3. The wire to be used to bridge connection between slot3 and output of SB7b should be of any particular thickness(0.35/0.5/1.0) ?
Why I am asking this particular question is that, I have already hooked up a wire(0.35mm) to slot no3 and isolated the other end because I was not sure where to connect it.
I know my questions might be very silly, but please spare me master. I am still a novice :mrgreen:
- I mean that the installation must be protected by a fuse with a BCM High.
- The new Dimmer will not work if you do not remove the original SB7b terminal and isolate it.
2 You should always use the multimeter. For example:
- To differentiate terminal SB7a (input) from terminal SB7b (output). voltage
- To know which is the terminal that feeds the right parking/side light. voltage
- To locate the license plate wires. continuity
3
- the wire from fusebox to Dimmer. 1.0mm2 thickness (mandatory). VW reference 000979133. That wire is perfect (correct contact-terminals on both sides).
- the wire to hook to RPL wire and the LPL wires. 0.5mm2 thickness
Many people spend two hours washing a car. (and a lot more...e.g. me :mrgreen:)
Few are those who spend half an hour avoiding ruining the electrical installation of their cars. Those things that human beings do ... :lol:
IMHO it is necessary to have a little respect for those who developed all the microchips that carries installed any car in this first part of the 21st century. :wink:
Image Namaste.
patil
Post by patil »
ciclo wrote:1
3
Image Namaste.
Master Namaste :D
Thank you for clarifying my doubts. You made it lot easier for me to go ahead with installation. :lol:
Once SB7b terminal is isolated, I guess the power supply to plate lights is cutoff(?)
So to restore the power supply to plate lights, I need to bridge a connection from Rt tail lamp +12 feed (58) to plate wires?
By doing this, the plate lights are completely isolated from dimmer switch control and Rt tail lamp starts feeding the plate lights, right?
By the way master, even me too spend lot of time washing my car :mrgreen:
Pleasure of driving a clean car is addictive :wink:
Everything YES (exactly)
Remove some cloth tape to get the new splice away from connector.
Please take pictures of the process.... and if possible take a video of how the Dimmer works once installed. Thank you very much. :wink:
It is highly possible that many users are interested in retrofitting the Dimmer. :wink:
Fuse box info:
Interesting to see the parking lights with 58r. Parking lights with stalk to the left + ignition off = no license plate lights? Or 6R IND doesnt have the parking lights by stalk?
patil
Post by patil »
iichel wrote:Interesting to see the parking lights with 58r. Parking lights with stalk to the left + ignition off = no license plate lights? Or 6R IND doesnt have the parking lights by stalk?
Hi iichel... Namaste(greetings) :D
Yes. 6R IND Polo's(RHD) parking lights are not controlled by stalks, instead they are controlled by headlight switch.
Both parking lights and plate lights are from 58 , hence both glow together once parking lights are switched on irrespective of ignition On/Off.
patil
Post by patil »
ciclo wrote:Everything YES (exactly)
Fuse box info:
Thank you Master. I couldn't have asked for more from you!
You are walking encyclopedia of Polo6R :mrgreen:
Surely I will document all the details of installation process with pictures and videos. I will post all the details when it is done for the benefit of everyone. 8)
I will install the central trunk light too at the same time. Thanks for the tip :D
With BCM High they do not have parking lights, they have side lights only, activated by the light switch (->fuse->bulbs).
So it's just perfect to retrofit the Dimmer. :)
patil
Post by patil »
Oh ok. Thanks for explaining it correctly, Master :D
Perfect. Looking forward to see your work and results. :wink:
patil
Post by patil »
Today finished installation of dimmer switch. It works perfectly :D
Master Ciclo.... please take a bow. Always will be greatfull to you :lol: You are a wonderful person :)
I have photographed every step and soon will write up all the details here.
How to upload videos here?
