I'm having some trouble activating the rain closing feature.
When i try enabling "rain closing active" BCM--Byte4--bit6 i get the error message "Error 31: request out of range"
But the wired thing is that rain closing is set to active in RLS--Byte0--Bit2
Anybody got same issues?
Does my car even support rain closing?
Hi olegre
I'm afraid it's not possible with your BCM/RLS/WRMs. (I had exactly the same units configuration as you from the factory)
In any case, it is still unclear how to properly encode this function. (with new BCMs/WRMs/RLS)
Someone told me that there are European legislations that greatly restrict the functioning of locking systems in cars, but I do not remember any of this because I was never interested in this function.
ciclo wrote: ↑Tue May 16, 2017 11:24 am
Hi olegre
I dont think the newer RLHS's (Rain, Light, Humidity Sensors) fitted to the 6C support rain closing, sure the issue has been encountered on lots of newer MQB based models, the 6C sharing much of the newer MQB electronics.
pipsyp wrote: ↑Tue May 23, 2017 10:04 am
Yes, it could be, however we are talking about of the 6R units evolution.
BCM... 7E0 instead of 7H0/6R0
RLS/RLHS... 5K7 instead of 1K0
and WRMs.
My 6R with updated units. (BCM & RLHS end of 2016)
But the central locking does not work as you can see in the video. It may be necessary to find some Bit that activates it.
(but I do not want the central locking to work with this feature)
Rain Closing was possible at the beginning of 6R manufacture. (2009-2011)
and WRMs.
I have a Polo 6R from 2010 (1.2 tdi bm).
Could nog get rain closing to work, also adjusted the bytes in vcds...
Wednesday,12,July,2017,16:07:44:49450
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
VCDS Version: 16.8.0.3
Data version: 20160803 DS255
www.Ross-Tech.com
VIN: WVWZZZ6RZBY110997 License Plate:
Mileage: 199030km-123671mi Repair Order:
Chassis Type: 6R (6R0)
Scan: 01 03 08 09 10 15 17 19 25 2E 37 44 56 61 77
VIN: WVWZZZ6RZBY110997 Mileage: 199030km-123671miles
37-Navigation -- Status: Malfunction 0010
77-Telephone -- Status: Not registered 0001
Address 01: Engine (J0000-CFWA) Labels: 03P-906-021-CFW.clb
Part No SW: 03P 906 021 B HW: 03P 906 021 B
Component: R3 1.2 DCM3.7 H04 7345
Revision: 12004001 Serial number:
Coding: 00114014032401080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM12TDI03103P906021B 001023
ROD: EV_ECM12TDI03103P906021B.rod
VCID: 275D91FA5E2C3E7AC1-8072
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AJ HW: 6R0 907 379 AF
Revision: --------
Coding: 210224E3416E00B2842E24EB82D800521300
VCID: 0603FC7EB5E607729A-8052
1 Fault Found:
02214 - Tire Pressure Warning
002 - Lower Limit Exceeded
Fault Status: 01100010
Fault Priority: 0
Fault Frequency: 100
Reset counter: 4
Mileage: 184098 km
Time Indication: 0
Date: 2012.12.12
Time: 09:11:53
Hex Value: 0x0000
Hex Value: 0x8000
Hex Value: 0x1203
Hex Value: 0x2BBC
Hex Value: 0x5D7F
Hex Value: 0x807B
Hex Value: 0x7EF9
Part No SW: 6R0 907 044 H HW: 6R0 907 044 H
Component: Climatronic H11 0711
Revision: V0000000
VCID: 387F42868B92A18258-806C
3 Faults Found:
00705 - Relay for Coolant Fan; Stage 1 (J279)
009 - Open or Short to Ground
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 187
Mileage: 180653 km
Time Indication: 0
Date: 2012.11.04
Time: 18:29:08
00706 - Relay for Coolant Fan; Stage 2 (J513)
Fault Priority: 3
Fault Frequency: 1
Reset counter: 187
Mileage: 180653 km
Time Indication: 0
Date: 2012.11.04
Time: 18:29:08
01271 - Positioning Motor for Temperature Flap (V68)
000 - - - Intermittent
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 24
Mileage: 198430 km
Time Indication: 0
Date: 2017.07.01
Time: 14:10:55
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 088 B HW: 6R0 937 088
Component: BCM PQ25 Re4 H46 0321
Revision: BU046001 Serial number: 0328 261100822
Coding: 3AB02BBF48E12400B33807B07CEB9FD8DF80670F7E860001200000000000
Shop #: WSC 12345 123 123456
VCID: 3D715392A4B084AA8B-8068
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 170910 05 54 0403
Coding: 03302D
Subsystem 2 - Part No SW: 6R0 959 801 R HW: 6R0 959 801 R Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 006 0903
Serial number: KU0-KU014.09.1013849
Coding: 58BC30
Subsystem 3 - Part No SW: 6R0 959 802 T HW: 6R0 959 802 T Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 006 0902
Serial number: KU0-KU015.09.1010829
Coding: 48BC30
Component: DWA-Sensor 00 001 0103
Subsystem 5 - Part No: 1K8 951 605 A
Component: LIN BACKUP HO H11 9004
Subsystem 7 - Part No SW: 5K0 959 542 HW: 5K0 959 542
Component: E221__MFL-TAS H05 0010
Serial number: 0053518
Coding: 020000
Subsystem 8 - Part No SW: 6R0 959 811 F HW: 6R0 959 811 F
Component: J388__TSG_HL 006 0902
Serial number: KU0-KU013.09.1010932
Coding: 48BC32
Subsystem 9 - Part No SW: 6R0 959 812 F HW: 6R0 959 812 F
Component: J389__TSG_HR 006 0902
Serial number: KU0-KU010.09.1011253
Coding: 48BC32
2 Faults Found:
00978 - Lamp for Low Beam; Left (M29)
010 - Open or Short to Plus - Intermittent
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 254
Reset counter: 42
Mileage: 180653 km
Time Indication: 0
Date: 2012.11.04
Time: 19:06:01
00979 - Lamp for Low Beam; Right (M31)
Fault Priority: 3
Reset counter: 34
Mileage: 180654 km
Time Indication: 0
Date: 2012.11.04
Time: 19:14:54
Address 10: Park/Steer Assist (J446) Labels: 6R0-919-475.clb
Part No SW: 6R0 919 475 HW: 6R0 919 475
Component: PARKHILFE 4K H07 0008
Revision: -------- Serial number: 71391025068486
Coding: 100001
ASAM Dataset: EV_VW250ParkiAssis2 S01006
ROD: EV_VW250ParkiAssis2.rod
VCID: 7BF59D8AF2244A9AF5-802E
Component: VW10Airbag00G H09 0020
Revision: -------- Serial number: 003GX007PJZ9
Coding: 003047
VCID: 4A9B084EED7E23123E-801E
Serial number: 3572SRB40000CAD11184
Serial number: 3582SRB40000CB406A8A
Serial number: 3515RRB40656VQ8AJH40
Serial number: 3525RRB405B6THNCFGTW
Part No SW: 6R0 920 870 HW: 6R0 920 870
Component: KOMBI H21 0320
Coding: 140E00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
VCID: 72EBB0AEA56E0BD2A6-8026
Address 19: CAN Gateway Labels: 6R0-907-530-V1.clb
Part No SW: 6R0 907 530 B HW: 1K0 907 951
Component: J533 Gateway H28 0020
Revision: H28 Serial number: 110910F1001179
Coding: 7D631D00080000000002
VCID: 326B70AEADEE4BD266-8066
1 Fault Found:
000 - -
Fault Status: 01100000
Fault Priority: 1
Reset counter: 255
Mileage: 189000 km
Time Indication: 0
Date: 2017.02.06
Time: 00:03:20
Component: IMMO H21 0320
Serial number:
Shop #: WSC 00000 000 00000
VCID: 6ADBA8CE8DBEC3121E-803E
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 C HW: 5N0 035 342 C
Component: SG EXT.PLAYER H13 0111
Revision: A1001003 Serial number: 7668638629
Coding: 020000
VCID: 275D91FA562C3E7AC1-8072
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 L HW: 1T0 035 680 B
Component: RNS-MID H11 5238
Revision: AB001001 Serial number: VWZ6Z7K6025043
Coding: 00000402040000A00001
VCID: 377D41BA868CAEFA51-8062
Subsystem 1 - Part No: 1T0 919 859 B
Component: EU West V13 8348
1 Fault Found:
01523 - Microphone for Telephone (R38)
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 5
Reset counter: 4
Mileage: 189000 km
Time Indication: 0
Date: 2017.02.06
Time: 00:05:42
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11230
Shop #: WSC 00788
VCID: 2F6D79DAEADC663A09-807A
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
3 Faults Found:
00876 - Treble Speaker Rear Left (R14)
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 4
Mileage: 199024 km
Time Indication: 0
00877 - Treble Speaker Rear Right (R16)
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 4
Mileage: 199024 km
Time Indication: 0
011 - Open Circuit
Fault Priority: 5
Reset counter: 4
Mileage: 189000 km
Time Indication: 0
Date: 2017.02.06
Time: 00:05:42
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 6R0 907 534 HW: 1K0 907 951
Component: Batt.regelung H28 0020
Coding: 030B1A5A
VCID: 74E7B6B6D77A05E2B4-8020
Component: J367-BDM H07 0125
Serial number: 00000000002790431473
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 M HW: 7P6 035 730 M
Component: TELEFON H16 4217
Revision: 1B001001 Serial number: 00007670303058
Coding: 0A01000000010110
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA.rod
VCID: 3C775E96B7AA8DA2BC-8068
End-------------------------(Elapsed Time: 03:18)--------------------------
Thanks in advance
PS. maybe you noticed the other fault codes...i could not get rid of the HVAC errors even tho I tried @iichel solution by changing adaption channel 2 - value = 1. (somehow it doesn't change the value..)
