Hi everyone just a quick question got a polo blue gt was thinking about changing the alloy wheels..... does anyone know what size wheel I can go up to with out any problems plus any ideas on what style many thanks
Bigger wheels
- Drives: Polo '14 6R, Golf 07' Edition 30
Re: Bigger wheels
I think it's 17 inch without problems, and then 18inch with a bit of rubbing when turning.
- Drives: A2 Polo 6R conversion !
Re: Bigger wheels
Just make sure the tyre diameter matches original so as not to affect speedo and insurance and ensure the width is suitable for the rims.
Radius changes also affects effective gearing based on final drive ratio. Smaller combo faster acceleration lower top speed and visa versa.
Biggest issue is lower MPG with larger rims (alloy wheel density higher than tyre + air) and usually higher un-sprung weight which affects suspension, ride, cornering etc - explains a little why race cars tend to use small rims.
Here's an excellent place to start with tyre sizes vrs new wheel dimensions:
https://www.tacomaworld.com/tirecalc
Re: Bigger wheels
Sites that might be useful:
https://www.wheel-size.com/size/volkswagen/polo/
http://www.carbibles.com/tyre_bible_pg4.html
- Drives: Polo gt bluemotion
Re: Bigger wheels
TTBjork wrote:Sites that might be useful:
Re: Bigger wheels
Thanks guys for all you comments appreciated,now it's trying to find a set of alloys what would look good on the car
