Polo 6R by RekinPoznan
Re: Polo 6R by RekinPoznan
You make it easy for me to help you. Thanks to you.
In response to your question by private message:
You need to supply power from the fuse box to the BCM Pins T73a/63 and T73b/68 to make work your interior lights (T73b/1 ... to ... T6/3).
It is exactly what you assumed.
Step by step...
Step by step...
- RekinPoznan
- Drives: 6R
Hello
Good news all works fine at the moment rewiring done 100% , all functions working perfect.
This is CECM scan:
I dont have new labels...... what difrence is coding from you last ....030000 ? I have at this point 1.
Now is time to prepare RLHS to mount
What is best choice to mount new Stering whell ? now i Have original from polo only with left buttons , so is not possible to use MFA full options.
Many thanks for help.
This is CECM scan:
Address 09: Cent. Elect. (J519) Labels: 7H0-937-08x-09.lbl
Part No SW: 7H0 937 090 B HW: 7H0 937 090
Component: BCM PQ25 Max4 H74 0712
Revision: B9074001 Serial number: 0571 207130625
Coding: 3CB02BB808E12400923808D17E2B0CD0FA80670F60051041200000010000
Shop #: WSC 02310 790 00105
VCID: 2DB4DEBB741EAE7A5EF8A4-8079
Subsystem 1 - Part No SW: 6R0 959 801 H HW: 6R0 959 801 H Labels: 6R0-959-801.LBL
Component: J386__TSG_FT 002 0803
Coding: 08BC30
Subsystem 2 - Part No SW: 6R0 959 802 K HW: 6R0 959 802 K Labels: 6R0-959-802.LBL
Component: J387__TSG_BT 002 0803
Coding: 08BC30
Subsystem 3 - Part No: 1K8 951 171 A
Component: DWA-Sensor 00 001 0103
Subsystem 4 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 5 - Part No: 1K8 951 171 A
Subsystem 6 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C
Component: E221__MFL-TAS H31 0033
Coding: 020000
Subsystem 7 - Part No SW: 6R0 959 811 B HW: 6R0 959 811 B
Component: J388__TSG_HL 002 0803
Coding: 08BC32
Subsystem 8 - Part No SW: 6R0 959 812 B HW: 6R0 959 812 B
Component: J389__TSG_HR 002 0803
Coding: 08BC32
Great! good job.
It's the control of 58d terminal via PWM (lights of switches, etc).
Yours is RLS only.
IMHO, viewtopic.php?f=56&t=58703&start=1290#p498666 but you need a 7E0 BCM (or 7H0937090D).
With your current BCM https://i83.servimg.com/u/f83/18/06/17/81/119.jpg (for example).
Yours is RLS only.
- RekinPoznan
- Drives: 6R
Hi
Thanks I must think about this solution.
Best regards Chriss
Best regards Chriss
- RekinPoznan
- Drives: 6R
Hi
Tooday RLS instaled and worked , but dont have any information the coding is corectly ?
And preparing to install Side Assist button from Audi
- RekinPoznan
- Drives: 6R
Hello
I have some problem after replace Light switch to Auto , is from MK7 so mayby this is the poroblem.... everythig is working good but Rear fog lights dont work
is connected exacly T17/9 to T10/7 , front fog dont work but I dont connect it at the moment beacose waiting for relay.....
Codin are now : 3CB02BB848E12400933808D17EAB0ED0FA80670F60053041200000010000
No error found.
No error found.
Yeah the Golf Mk7 light switch is intended for the MQB electronics. Front and rear fog light is operated by the same wire. The Polo 6R electronics cannot understand this.
- RekinPoznan
- Drives: 6R
Thanks for fast replay.
So here is the problem , monday I change to another switch.
Many thanks
Many thanks
In any case, its placement would not be correct in the 6R.
yes, no infoRekinPoznan wrote: ↑Thu Oct 05, 2017 3:27 pm Hi
0728DD
- RekinPoznan
- Drives: 6R
Thanks Ciclociclo wrote: ↑Fri Oct 13, 2017 8:53 pmyes, no infoRekinPoznan wrote: ↑Thu Oct 05, 2017 3:27 pm Hi
0728DD
You may have problems when coding that RLS due to your VCDS version. Coding rejected.
I think these problems were solved in the next version to yours.
It is recommended to buy the original VCDS cable. Enthusiast =199$
- RekinPoznan
- Drives: 6R
Hello
Looking for HBA preparing , on this diagram from Ciclo is no pinout for reverse gear signal input , Iiformation about reverse gear is send via can ?
Many thanks for answer
