Polo 6C Blue GT retrofit Xenon
Eduard
Drives: 6C
Re: Polo 6C Blue GT retrofit Xenon
Post by Eduard » Tue Sep 12, 2017 9:22 pm
Eduard
Drives: 6C
Post by Eduard » Tue Sep 19, 2017 8:07 pm
Basically ... you're exactly in my spot buddy. Please read this for a thorough wiring tutorial haha.
http://forums.ross-tech.com/showthread. ... ofit-Issue
That adapter you bought from kufatec is worthless .. you just need the T14 connectors .. and 2 small terminals ( the smaller holes in the sockets ).
If you already have DRL and Cornering via Fog-Lights in the front bumper, then you need no additional cable.
5 -> 5 + 7
6 -> 6
8 -> 11
9 -> 9
DRL wire -> 10
Side lights -> 12
If you want the cornering in the headlight, you need to rout the foglight wire into slot 14. Problem is you will also have fog lights into the headlights, and no other use for the bumper.
Otherwise you can just leave the cornering with the fog lights in the bumper ... or ... you can try some settings for me ( so I can see if there's any faults on my end ).
Please let me know if your DRL works after putting the DRL and Side lights wires in it without any other settings. Very interested!
