Vw Polo 6r 2010 3 door
When I lift the handle on the passenger seat, the back rest moves up and out of the way, however the seat itself does not move forward but instead stays in it's current position. This issue doesn't occur on the driver's side, is it an easy fix? I am able to tilt the seat and move it forward and backward without the lever, it's just a problem when people want to get access to the back, since the seat won't move forward!
What can I do?
Thanks!
6r 3 door passenger seat not moving forward when folded
Re: 6r 3 door passenger seat not moving forward when folded
I have posted a video on youtube to explain the problem clearly : https://youtu.be/kx0DN-uHgFw
- Drives: Blue GT
It's called Easy Entry by VW. Perhaps your car only has it at the driver's side?
I highly doubt it since my car has always had the two front seats move up and out of the way, the problem occurred yesterday when I was hoovering the car. I've found the seat cable (located near the seat rail on the left hand side) to be loose and frayed.peter_dk25 wrote: ↑Mon Oct 16, 2017 2:02 pm It's called Easy Entry by VW. Perhaps your car only has it at the driver's side?
- Drives: Polo Blue GT
I’d imagine you have just answered your own question.
- Drives: Blue GT
- 6RPotentialBuyer
- Drives: Candy White Polo 6R
Woah I never knew the Polo had this feature! My 2010 Polo S doesn't have this. Is it only on higher spec cars?
