Page 2 of 2
Re: Racechip Install
Posted: Wed Dec 06, 2017 10:55 pm
by Robby_boi86
Posted: Wed Dec 06, 2017 10:56 pm
by FerhaTopaLGT
Any electric cable ?
Tapatalk kullanarak iPhone aracılığıyla gönderildi
Posted: Wed Dec 06, 2017 10:58 pm
by Robby_boi86
No nothing to connect to battery
Posted: Wed Dec 06, 2017 10:59 pm
by FerhaTopaLGT
Ok I'm looking still
Posted: Wed Dec 06, 2017 11:11 pm
by FerhaTopaLGT
Posted: Wed Dec 06, 2017 11:13 pm
by Robby_boi86
Thank you
Posted: Thu Dec 07, 2017 1:01 pm
by iichel
Have you tried contacting racechip maybe?
Posted: Thu Dec 07, 2017 2:10 pm
by Oli3000
iichel wrote: ↑Thu Dec 07, 2017 1:01 pm
This. Or even contacting the reseller - I wouldn't be connecting the box if I thought it was for the wrong engine! If the pictures are wrong - is the box wrong too?
Posted: Thu Dec 07, 2017 4:36 pm
by Ricmondo
Racechip are very helpful, they will advise upon suitability, convertibility and installation. If you need a different harness they will supply.
Great company to deal with.
Posted: Sat Jan 06, 2018 6:25 pm
by robbo32
Hi
To fit second connector you need to remove the engine undertray and then you will find the boost connector you need to connect to.
It's an awkward one to remove as there is an Air con pipe right in front of it.
Took me a bit of time to get it off, but once done the racechip on their supplied settings really transforms the car, makes it much sharper and more eager than factory.
Make sure when you tie wrap the racechip cables that you route them away from the radiator fans which are unshrouded and therefore you need to be careful.
