Hill Hold Assist
- gaza1994
- Drives: Match 1.4 2012 (6r) (85ps)
Hill Hold Assist
Hi Guys,
I'm sure i've made a post about this before but cannot remember!
I've done a little reading regarding hill hold assist, and to this day it still does my t**s in!!
Is there anyway i can disable it or make the breaks release quicker?
I have VagCom so would be able to do this myself, but just dont really wanna go poking around at settings i have no idea what they do!
Starting to look like an idiot that cant drive up hills -__-
Thanks Guys
Thanks Guys
Re: Hill Hold Assist
sure let's see a vcds autoscan
- gaza1994
As promised:
Saturday,09,December,2017,15:27:19:39744
VCDS Version: 17.1.3.0 (x64)
Data version: 20170203 DS267.2
www.Ross-Tech.com
VIN: WVWZZZ6RZCU047894 License Plate: XXXXXX
Mileage: 79230km-49231mi Repair Order:
Chassis Type: 6R (6N0)
Scan: 01 03 04 08 09 15 17 19 25 2E 44 56
VIN: WVWZZZ6RZCU047894 Mileage: 79230km-49231miles
Address 01: Engine Labels: 03C-906-024-BXW.lbl
Part No SW: 03C 906 024 CN HW: 03C 906 024 BH
Component: CGGB MM4HV 8994
Revision: --H09--- Serial number:
Coding: 0000071
Shop #: WSC 31414 790 31414
VCID: 6CD01FF24C10B72125-515A
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 BC HW: 6R0 907 379 AF
Component: ESP8.2i front H05 0002
Revision: --------
Coding: 230224E3217100B9C42D24EB84D500801300
VCID: 00085B4297984341E9-8054
Address 08: Auto HVAC (J301) Labels: None
Part No SW: 6R0 820 045 N HW: 6R0 820 045 N
Component: Man AC H02 0202
Revision: 0003SH02
VCID: 397EF6A6B0C2D289EE-806C
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 K HW: 6R0 937 087
Component: BCM PQ25 H+4 H46 0254
Revision: BF046001 Serial number: 0434 330110383
Coding: 7CB02BBF08A10000003008002D2B0CD00040410F60060000200000000000
VCID: 45868A56CC3AA6699A-8010
Subsystem 1 - Part No SW: 6R0 959 802 AB HW: 6R0 959 802 AB Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 008 1611
Serial number: KU0KU030111100010926
Coding: 18BC30
Subsystem 2 - Part No SW: 6R0 959 801 AD HW: 6R0 959 801 AD Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 008 1611
Serial number: KU0KU021111100014278
Coding: 08BC30
Subsystem 3 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Serial number: KU0KU028111100010796
Coding: 08BC32
Subsystem 4 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Serial number: KU0KU016111100011482
Coding: 08BC32
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Component: VW10Airbag027 H09 0020
Revision: -------- Serial number: 003GX00V0LHZ
Coding: 003237
VCID: 4A9CB96AED24491177-801E
Serial number: 3575HRB4051112GSEOED
Serial number: 3585HRB404V112GSA1OQ
Serial number: 3515RRB405B0TGJMM0E6
Serial number: 3525RRB405P0U8DGAOPP
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 6R0 920 960 H HW: 6R0 920 960 H
Component: KOMBI H03 0505
Coding: 440A01
Shop #: WSC 31414 790 50316
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
VCID: 3A7CE9AABDC4D991E7-806E
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 H46 0254
Revision: BF046001
Coding: 002300
VCID: 70E80B82A33853C119-8024
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Component: IMMO H03 0505
Serial number:
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDSV_DD_RM09 A03009
ROD: N/A
VCID: 6ADC19EA8DE4A91157-803E
No ASAM data for: "EV_Immo_UDSV_DD_RM09" (VW36 *)
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Component: SG EXT.PLAYER H13 0240
Revision: A1001003 Serial number: 7661478015
Coding: 010000
VCID: 295E26E6406262099E-807C
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11250
Shop #: WSC 31414
VCID: 2F6AC8FEEA860C3940-807A
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 5M0 035 186 J HW: 5M0 035 186 J
Component: Radio RCD310 042 0082
Revision: 01000001 Serial number: VWZ1Z2L3609808
Coding: 01000400020001
VCID: 3362C48E92AE28D924-8066
1 Fault Found:
00856 - Radio Antenna
007 - Short to Ground
Fault Status: 01100111
Fault Priority: 5
Fault Frequency: 68
Reset counter: 19
Mileage: 72730 km
Time Indication: 0
Date: 2012.02.14
Time: 00:15:37
End-------------------------(Elapsed Time: 02:28)--------------------------
Byte 16:
13
Change bit 0 to 0
Byte 16 new:
12
New long code
230224E3217100B9C42D24EB84D500801200
Byte 16:
13
Change bit 0 to 0
Byte 16 new:
12
New long code
copy-paste the bottom line into your coding screen of VCDS
nah there is no such thing as a stupid question, but yes. in the ABS controller.
completely disables hha
I do agree it can be annoying, even in my driveway I wait until the time has run out before letting the clutch out fully, ie after the "release" command has been given by the clutch pedal switch!
- gaza1994
Yea, its got its fair uses! It's just REALLY annoying when your at a roundabout that's on a slight incline with rows of traffic behind you and hill assist decides to not release the breaks and your either sitting there revving the t**s off the car or stall instantly!
