Polo 6R Europe, 2010-->2014
Bixenon headlights with AFS For polo gt Tsi 2015
- Drives: Polo 6R
Re: Bixenon headlights with AFS For polo gt Tsi 2015
Hrishikesh wait till vw launch 2018 polo in India it may come with full led lights all parts will be available in Indiahmthakur wrote:Is it a Audi part?? Manufacturing dates are 2010,11,12
Vento comes with afs but it's mountings are different
Sent from my Pixel 2 using Tapatalk
- Drives: Polo gt tsi 1.2 dsg
Enquired about 2018 polo, but they don’t have any clue
I am not interested in led headlights as they don’t give enough light and spread.
- Drives: Polo 6R
AFS setup is same for led and bixenon headlights..hmthakur wrote:I am not interested in led headlights as they don’t give enough light and spread.
Hi ciclo
When installing bcm high i will have to isolate two can wires from instrument cluster, will these wires will be live i.e. will these wires be connected to bcm?? Can i us these wires for OPS, AFS?? Can we make a connector like two wires to four.??
Yes the old wires to IC are powertrain canbus high and low.
They will still be live. You can use them for PDC/OPS, AFS, TPMS high etc.
Can we make a connector like two can wires in to six out wires connections
yes of course, but think about the limited space available behind the IC in your choice of connector.
What connectors do you suggest??
Well, it seems that you are going to set up a worldwide communications network in your 6R , therefore, the connectors that best suit your taste/possibiities/neededs/tools and are within your reach...
Yesterday was 19, today is 20, and tomorrow 21, the 21 is a good day to ...
Hi hmthakur, how's your electric installation going?
Remember that in order for everything to work properly it's necessary to code the new BCM.
When you need it request me here the new BCM coding, by telling me all the new equipment installed so far.
Can anybody please confirm if afs control module from 2012 gti 6r having vin no. WVWZZZ6RZCY239904 Will fit polo 6r?? Part no is 6R0907357
- Drives: 1.2TSI 105HP DSG7
Sure. As long it’s coming from polohmthakur wrote:Can anybody please confirm if afs control module from 2012 gti 6r having vin no. WVWZZZ6RZCY239904 Will fit polo 6r?? Part no is 6R0907357
I think it will also depend on what sensor you're planning to put on the rear axle. As far as I understood, there are several types of sensor with different sampling frequencies. This needs to match with the AFS control module.
