Adam’s T5.1 GP
Re: Adam’s T5.1 GP
Does the HBA work well after this change?
Re: Adam’s T5.1 GP
HBA has always worked well, I’ve not tried it since the MKE addition, but I don’t see why not?
Re: Adam’s T5.1 GP
I tried with VCP and converted file. I have fault when loading via VCP, but MKE works.
Moment ago I noticed new issue: when I turn on HBA I can't disable it :O
Here is video: https://photos.google.com/share/AF1QipP ... BMajJsRS13
Re: Adam’s T5.1 GP
What is the fault?
Post here the converted file that you have loaded. Between []
Your HBA system works perfectly according to the video.CNK wrote: ↑Sat Jun 15, 2019 10:20 pm Moment ago I noticed new issue: when I turn on HBA I can't disable it :O
Check this video to find out who or what does not work correctly.
Do exactly the same as in the video.
Re: Adam’s T5.1 GP
Ok, sorry for the confusion. I think I was too tired
So it's okay, during the day we switched HBA/no HBA because we use DRL. At night we switched HBA/high beams, because we have low beams turned on
Converted file: https://pastebin.com/Xg02rYM6
Fault in VCP:
(i use the original VCP)
Fault in VCP:
Error writing memory : 49 Operation Write_data_to_F1A1 31 Request out of range.
Re: Adam’s T5.1 GP
I can send you the file I used for VCP if you like? I had a quick look at yours and without comparing it looks ok.
Re: Adam’s T5.1 GP
I wrote with firegrafik, he did a test on his old BCM and had the same fault, but noticed it works despite the error in VCP.
Didn't you have this error?
Re: Adam’s T5.1 GP
No, mine said writing ok, do you get errors (dtc) reading the module?CNK wrote:I wrote with firegrafik, he did a test on his old BCM and had the same fault, but noticed it works despite the error in VCP.
Re: Adam’s T5.1 GP
I have only high beam headlamp bulb faults (Break / short to + Lamp OFF), left and right (I think I have this after HBA install, all works but can't fix these faults).
Re: Adam’s T5.1 GP
Question (only):
Adam, did you check the EraseFullMemory box when loading the data set?
Remember that the GW coding in Byte2 is not 05 HEX, it is 04 HEX.
Re: Adam’s T5.1 GP
No because it’s not a full memory flash, just a section. Or a t least that is my thoughts. It worked anyway haha.
Did you Fernando?
Did you Fernando?
Re: Adam’s T5.1 GP
Ok.
I did it with ODIS-E (recommended, I hope you have it soon).
Everything perfect with a single try.
Superhappy with ODIS-E!
Re: Adam’s T5.1 GP
Do you use ODIS-e with VAS 5054 cable?
I had no issue using VCP but just a little more time figuring out how to convert file from Odis to VCP
Be right back once I’ve watched all 7 HOURS....! [emoji23] btw, how long did it take to learn to play all them horns???[emoji2957]ciclo wrote: [emoji1787]
Re: Adam’s T5.1 GP
Yes, ODIS-E 9.0.4 with VAS5054, under W7, I connect it via Bluetooth, without cable.
I have used it twice, once to flash/update my second ECU viewtopic.php?f=56&t=58703&start=4695#p556178 , the other to load the MKE data set.
Everything perfect, without any kind of deficiency ...
ODIS Engineering 9.0.4
I'm going to test how the Konis Hupen sounds with my Helix sound system.
Re: Adam’s T5.1 GP
Hi Adam,
I’m trying to contact you regarding the wiring for the retrofit or AC. Do you still have any information?
