Adam’s T5.1 GP
CNK
Drives: 6R
Re: Adam’s T5.1 GP
Post by CNK »
Does the HBA work well after this change?
Adam87
Drives: T5.2
Re: Adam’s T5.1 GP
Post by Adam87 »
HBA has always worked well, I’ve not tried it since the MKE addition, but I don’t see why not?
CNK
Drives: 6R
Re: Adam’s T5.1 GP
Post by CNK »
I tried with VCP and converted file. I have fault when loading via VCP, but MKE works.
Moment ago I noticed new issue: when I turn on HBA I can't disable it :O
Here is video: https://photos.google.com/share/AF1QipP ... BMajJsRS13
Re: Adam’s T5.1 GP
CNK wrote: Sat Jun 15, 2019 10:20 pm I tried with VCP and converted file. I have fault when loading via VCP, but MKE works.
What is the fault?
Post here the converted file that you have loaded. Between []
CNK wrote: Sat Jun 15, 2019 10:20 pm Moment ago I noticed new issue: when I turn on HBA I can't disable it :O
Your HBA system works perfectly according to the video.
Check this video to find out who or what does not work correctly.
Do exactly the same as in the video.
CNK
Drives: 6R
Re: Adam’s T5.1 GP
Post by CNK »
Ok, sorry for the confusion. I think I was too tired :roll:
So it's okay, during the day we switched HBA/no HBA because we use DRL. At night we switched HBA/high beams, because we have low beams turned on :mrgreen:
Converted file: https://pastebin.com/Xg02rYM6
Fault in VCP:
Error writing memory : 49 Operation Write_data_to_F1A1 31 Request out of range.
(i use the original VCP)
Adam87
Drives: T5.2
Re: Adam’s T5.1 GP
Post by Adam87 »
I can send you the file I used for VCP if you like? I had a quick look at yours and without comparing it looks ok.
CNK
Drives: 6R
Re: Adam’s T5.1 GP
Post by CNK »
I wrote with firegrafik, he did a test on his old BCM and had the same fault, but noticed it works despite the error in VCP.
Didn't you have this error?
Adam87
Drives: T5.2
Re: Adam’s T5.1 GP
Post by Adam87 »
CNK wrote:I wrote with firegrafik, he did a test on his old BCM and had the same fault, but noticed it works despite the error in VCP.
No, mine said writing ok, do you get errors (dtc) reading the module?
CNK
Drives: 6R
Re: Adam’s T5.1 GP
Post by CNK »
I have only high beam headlamp bulb faults (Break / short to + Lamp OFF), left and right (I think I have this after HBA install, all works but can't fix these faults).
Re: Adam’s T5.1 GP
Adam87 wrote: Sun Jun 16, 2019 10:24 am
Question (only):
Adam, did you check the EraseFullMemory box when loading the data set?
Remember that the GW coding in Byte2 is not 05 HEX, it is 04 HEX.
Adam87
Drives: T5.2
Re: Adam’s T5.1 GP
Post by Adam87 »
No because it’s not a full memory flash, just a section. Or a t least that is my thoughts. It worked anyway haha.
Did you Fernando?
Re: Adam’s T5.1 GP
Ok.
I did it with ODIS-E (recommended, I hope you have it soon).
Everything perfect with a single try.
Superhappy with ODIS-E!
Adam87
Drives: T5.2
Re: Adam’s T5.1 GP
Post by Adam87 »
Do you use ODIS-e with VAS 5054 cable?
I had no issue using VCP but just a little more time figuring out how to convert file from Odis to VCP
ciclo wrote: [emoji1787]
Be right back once I’ve watched all 7 HOURS....! [emoji23] btw, how long did it take to learn to play all them horns???[emoji2957]
Re: Adam’s T5.1 GP
Adam87 wrote: Sun Jun 16, 2019 7:05 pm Do you use ODIS-e with VAS 5054 cable?
Yes, ODIS-E 9.0.4 with VAS5054, under W7, I connect it via Bluetooth, without cable.
I have used it twice, once to flash/update my second ECU viewtopic.php?f=56&t=58703&start=4695#p556178 8) , the other to load the MKE data set.
Everything perfect, without any kind of deficiency ...
ODIS Engineering 9.0.4
:idea: I'm going to test how the Konis Hupen sounds with my Helix sound system. 🎺 :mrgreen:
Adam_T6
Drives: 9N
Re: Adam’s T5.1 GP
Post by Adam_T6 »
Hi Adam,
I’m trying to contact you regarding the wiring for the retrofit or AC. Do you still have any information?
