BCM High to BCM Max, AFS, LED Headlights and HBA
- federicodrdpro
- Drives: White Polo 6R TDI
Re: BCM High to BCM Max, AFS, LED Headlights and HBA
Ciclo, which is the right scheme for Auto Lights with HBA?
1)
2)
ciclo HBA
The first is the definitive scheme, right? You told me that the LED headlights work perfectly with my FOG lights. I need the relay FOG lights?
I can follow the "How to install 7E0937090B BCM Max for 2016 Polo 6R IND non Bluemotion H7 halogen headlights RHD" guide for Auto Lights and HBA.
1)
2)
ciclo HBA
Last edited by federicodrdpro on Sun Feb 18, 2018 10:01 pm, edited 3 times in total.
Probably this one: https://drive.google.com/open?id=0BxYPV ... VQ1Z0VkaEk
The two you post don't appear to be good to me.
Where do you run into issues with the guide for 2016 polo IND?
I explain you:
When I installed the HBA system in my 6R with a total success (1st 6R of the world with it, sincerely sorry to say this, but I'm forced to say it) there was no information about it, nor VW diagrams nor diagnostic tools with the needed info.
As everyone knows, it was a process of investigation with tests and errors (which is the reason there are different diagrams, but people like to copy and paste without referring of where the diagrams come from).
iichell points out the correct diagram for my 6R, but it is not right for your 6R with LEDs headlights. In no case you must follow the diagrams that you show us.
The wiring installation for a 6R RHD IND will not be exactly the same as for your 6R, logically.
XXXXXXXXXX did me a huge favor by manufacturing the same car (6R) with so many different electrical installations... It's an extraordinary advantage to know all the electrical installations from all 6R / T5 / T6 / Amarok, etc (PQ25) ... from 2008 until today.
Due to personal reasons I no longer want to give free technical support for these things.
https://drive.google.com/file/d/0B2nv91 ... luc3M/view
You must leave intact the electric installation for the fog lights.
SB34 & SB36 = 10 -15Amp... for example.
- federicodrdpro
Ciclo, which is the part number of this 10 pin connector (about Auto lights)?
- federicodrdpro
Looking good in the snow. Congratulations on the new mod. Some with great care and detail
- Drives: Cross Polo 2010 TSI
Very nice!
What primer and glue have you used for new sensor mounting?
- federicodrdpro
Thanks!
I used D 009 200 02 Primer and D 180 KD2 A1 glue. But the right glue for the plastic support is D 180 KU2 A1.
- federicodrdpro
Today I plugged the RLS sensor and the mirror. All works fine but the Rain closing doesn't work.
This is actually the coding:
3CB02BBF48E3260093380C916CEF9ED05A88732F608510C0200000030000
This is the coding of RLS:
028877
I tried this:
0668DD
028877
I tried this:
0668DD
Last edited by federicodrdpro on Thu Mar 22, 2018 9:02 pm, edited 1 time in total.
Full autoscan
Federico please, you are not a newbie in these matters.
Even the VCDS version you are using is important.
- federicodrdpro
Full Autoscan:
Thursday,22,March,2018,21:49:00:00001
VCDS Version: 17.8.0.1 (x64)
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: WVWZZZ6RZCY020628 License Plate:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 03 04 08 09 15 17 19 20 25 44 55 0B
VIN: WVWZZZ6RZCY020628 Mileage: 86240km-53587miles
Address 01: Engine (J0000-CFWA) Labels:. 03P-906-021-CFW.clb
Part No SW: 03P 906 021 HW: 03P 907 425 A
Component: R3 1.2 DCM3.7 H06 8410
Revision: 11002001 Serial number:
Coding: 00114014002400080000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_ECM12TDI03103P906021 001010
ROD: EV_ECM12TDI03103P906021.rod
VCID: 65C089086461C76E19-8030
Readiness: 1110 1000
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AK HW: 6R0 907 379 AF
Revision: --------
Coding: 210228E3416F00B2842B14E482D900421700
Shop #: WSC 00788 648 00255
VCID: 071CA380B22D357ECB-8052
Address 08: Auto HVAC (J301) Labels: None
Part No SW: 6R0 820 045 G HW: 6R0 820 045 G
Component: Man AC 02 0101
Revision: 0002S 02
VCID: 326A22546D2F60D64C-8066
Part No SW: 7E0 937 090 C HW: 7E0 937 090 C
Revision: B9082001 Serial number: 4000 128171814
Coding: 3CB02BBF48E3260093380C916CEF9ED05A88732F608510C0200000030000
Shop #: WSC 18752 008 00032
VCID: 2B543F304A05311E0F-807E
Subsystem 1 - Part No: 5K7 955 559 B Labels: 5K7-955-559.CLB
Component: RLS 060215 03 37 0059
Coding: 0668DD
Subsystem 2 - Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 008 1611
Serial number: KU0KU030051100011446
Coding: 18BC30
Subsystem 3 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 008 1611
Serial number: KU0KU025051100015419
Coding: 08BC30
Component: DWA-Sensor 00 001 0103
Component: LIN BACKUP HO H03 1301
Subsystem 7 - Part No SW: K8 951 171 A HW: K89 511 71A
Serial number: ÿK8951171A °103
Subsystem 8 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Serial number: KU0KU027051100012627
Coding: 08BC32
Subsystem 9 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Serial number: KU0KU027051100013292
Coding: 08BC32
Component: VW10Airbag022 H09 0020
Revision: -------- Serial number: 003GX00NWXFQ
Coding: 003232
VCID: 4A9A5AB4EDBF081614-801E
Serial number: 3575HRB40550INGS999T
Serial number: 3585HRB40570INGSBHPF
Serial number: 3515RRB40510JNPM7P50
Serial number: 3525RRB404P0K4DOA8O1
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb
Part No SW: 6R0 920 861 H HW: 6R0 920 861 H
Component: KOMBI H03 0505
Coding: 140A01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
VCID: 3A7A0A74BD5F989684-806E
Part No SW: 7E0 909 901 HW: 7E0 937 090 C
Revision: B9082001
Coding: 002200
VCID: 68DE803C9B73DA0622-803C
Address 20: High Beam Assist. (J844) Labels:. 8S0-857-511.clb
Part No SW: 7E0 857 511 G HW: 7E0 857 511 E
Component: FLA H10 0003
Revision: AA001001
Coding: 040400E200000000000000
Shop #: WSC 34948 001 1048576
ROD: N/A
VCID: 2E5236247117443628-807A
No ASAM data for: "EV_HighBeamAssisAU316" (VW25)
Component: IMMO H03 0505
Serial number:
VCID: 6ADAFA348D7FE81634-803E
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11210
Shop #: WSC 00788
VCID: 2F6C2B20EA1D4D3E23-807A
Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Revision: -------- Serial number: --------------
Coding: 0112000001000000
VCID: 77FCD340CECD45FEBB-8022
End-------------------------(Elapsed Time: 03:25)--------------------------
New BCM coding
3CB02BBF48E3260093380E906CEF9ED05A88732F608530C0200000030800
BCM adaptation channels
53 from 0 to 1
54 from 0 to 1
Auto lights + light Assist
Test and report.
53 from 0 to 1
54 from 0 to 1
Test and report.
