Amarok Oem Bixenon retrofit
Re: Amarok Oem Bixenon retrofit
Perhaps it may be possible to do it with VCP.
But it is necessary to have the TXT file with BCM parameters from georgenis (for example). Extracted file with VCP, logically.
BTW, copying and pasting codings from other Amarok is a serious mistake.
Original Autoscan?
Original Autoscan?
- Drives: Amarok
Remember that i have changed the Bcm. What Bcm do You have. The guy who helped me is an electrician at Vw dealer. But without Ciclo’s help it was impossible. My car had basis electrical wiring.
Hello! I have changed also the bcm to 7H0937090D .(also added the additional wires)
I have taken my car again at service with headlights, i do not find a service till now to make a scan or to try to resolve the problems.
The guy who is working on it is asking for an engine code from a factory fitted xenon headlights.
How can i found one?
Also if he can not make annything to my car i will ask him to give me the full auto scan.
Georgenis do you have the BCM parameters?
If you have a VCP cable, maybe you can find an Amarok with bi-xenon and correct BCM.
You can extract the parameters from an Amarok 7H0937090D BCM with xenon and write them to your own.
Tuesday,29,May,2018,12:17:03:11999
VCDS Version: 18.2.1.2
Data version: 20180518 DS287.1
www.Ross-Tech.com
VIN: WV1ZZZ2HZB8062680 License Plate: XXX
Mileage: 173470km-107789mi Repair Order: 1234
Chassis Type: 2H-VN81 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 32
VIN: WV1ZZZ2HZB8062680 Mileage: 173470km-107789miles
32-Differential Locks -- Status: Malfunction 0010
Address 01: Engine (J623-CDCA) Labels:. 03L-906-022-CAA.clb
Part No SW: 03L 906 019 FC HW: 03L 907 309 K
Component: R4 2.0l BTD H40 9978
Revision: 26H40--- Serial number: 00000000000000
Coding: 01194012232600080000
Shop #: WSC 28315 001 1048576
ASAM Dataset: EV_ECM20BTD01103L906019FC 004006
ROD: EV_ECM20BTD01103L906019FC_004.rod
VCID: 71E9EE97A087C5CCD8-8024
8 Faults Found:
4332 - Check Coding of ECUs on Powertrain Data Bus
P1647 00 [036] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 10
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 18 °C
Intake air temperature: 21 °C
Ambient air pressure: 980 mbar
Voltage terminal 30: 11.800 V
ACC target acceleration: 0.000 m/s²
ACC control module received status-Bits 0-7: 6
Status of ACC/CCS acceleration interface-Bits 0-7: 0
Acceleration: 0.000 m/s²
Engine status: COENG_READY
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 1
4481 - Cruise Control Switch (E45)
P0568 00 [044] - Implausible Signal
Fault Priority: 2
Fault Frequency: 4
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Coolant temperature: 26 °C
Intake air temperature: 20 °C
Ambient air pressure: 970 mbar
Voltage terminal 30: 13.200 V
Cruise Control System (CCS): switch position-Bits 0-7: 129
Cruise Control System (CCS): status-Bits 0-7: 232
Cruise control switch-off: irreversible-Bits 0-7: 255
Cruise control switch-off: reversible-Bits 0-7: 255
Cruise Control System: specified speed: 0.00 km/h
Engine control module reset status-Bits 0-7: 0
Engine control module reset status-Bits 0-7: 2
Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
4482 - Function Restriction due to Implausible Message(s)
U1112 00 [044] - -
Fault Priority: 2
Fault Frequency: 15
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Cruise Control System (CCS): switch position-Bits 0-7: 193
4483 - Function Restriction due to Faults in Other Modules
U1113 00 [044] - -
Fault Priority: 6
Fault Frequency: 8
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Coolant temperature: 22 °C
Intake air temperature: 23 °C
Voltage terminal 30: 14.240 V
4708 - No Communications with HVAC Control Module (J301)
U0164 00 [036] - -
Fault Priority: 6
Fault Frequency: 5
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Coolant temperature: 21 °C
Intake air temperature: 22 °C
Voltage terminal 30: 12.600 V
Limitation: accelerator pedal: 0.0 Nm
CAN status - engine control module-Bits 0-7: 0
Cruise Control System (CCS): status-Bits 0-7: 200
CAN status - transmission control module-Bits 0-7: 0
CAN status - brake control module 1-Bits 0-7: 0
CAN status - brake control module 2-Bits 0-7: 0
selected gear-Bits 0-7: 0
4717 - Body Control Module (Central Electric)
U0140 00 [036] - No Communications
Fault Priority: 6
Fault Frequency: 5
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
4719 - No Communication with Diagnostic Gateway
U0146 00 [036] - -
Fault Priority: 6
Fault Frequency: 4
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Cruise Control System (CCS): status-Bits 0-7: 201
4629 - ECM Power Relay Load Circuit
P068A 00 [040] - Opens Too Early
Fault Priority: 2
Fault Frequency: 1
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Coolant temperature: -40 °C
Intake air temperature: -40 °C
Ambient air pressure: 0 mbar
Voltage terminal 30: 0.000 V
Accelerator pedal travel: 0.00 %
Starter control: Interlock- or P/N-signal-Bits 0-7: 0
Engine status: COENG_STANDBY
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 0
Readiness: 1010 0000
Address 03: ABS Brakes (-----) Labels:. 2H0-907-37x-ESP.clb
Part No SW: 2H0 907 379 G HW: 2H0 907 379 D
Component: ESP MK25A XT H44 0106
Revision: 00H44001
Coding: C07324B69A9A039724A859AB6F5010
Shop #: WSC 07456 790 49164
VCID: 346727839715B0E4F3-8060
3 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
000 - - - Intermittent
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 0
Time Indication: 0
Count: 32768
Count: 4097
Count: 8280
Count: 514
03095 - Diagnostic interface for databus (J533) implausible messa.:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 0
Time Indication: 0
Count: 32768
Count: 4097
Count: 8257
Count: 514
01299 - Diagnostic Interface for Data Bus (J533)
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 0
Time Indication: 0
Count: 32832
Count: 4097
Count: 8233
Count: 514
Address 08: Auto HVAC
Cannot be reached
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 090 D HW: 7H0 937 090
Component: BCM PQ25 Max4 H78 0725
Revision: B9078001 Serial number: 9000 219150127
Coding: 350006380C211000003008312ECB96DD0F80664E60003040300000030003
Shop #: WSC 12345 123 12345
VCID: 2F6D28EF7E33933C8E-807A
Subsystem 1 - Part No SW: 6R0 959 801 M HW: 6R0 959 801 M Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 002 3321
Coding: 100000
Subsystem 2 - Part No SW: 6R0 959 802 P HW: 6R0 959 802 P Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 002 3321
Coding: 100000
Subsystem 3 - Part No: 1K8 951 605 B
Component: LIN BACKUP HO H11 9005
Subsystem 4 - Part No SW: 6R0 959 811 D HW: 6R0 959 811 D
Component: J388__TSG_HL 002 3321
Coding: 100000
Subsystem 5 - Part No SW: 6R0 959 812 D HW: 6R0 959 812 D
Component: J389__TSG_HR 002 3321
Coding: 100000
2 Faults Found:
000 - -
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
01504 - Bulb for License-Plate Light (X)
010 - Open or Short to Plus
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 0
Time Indication: 0
Part No SW: 2H0 959 655 B HW: 2H0 959 655 B
Component: VW10Airbag00B H06 0013
Revision: -------- Serial number: 003HN002N3WH
Coding: 000000000000000000000000000000003042
Shop #: WSC 07446 790 50316
ROD: EV_AirbaVW10BPAVN750_VW12.rod
VCID: 3365249F9A1BB7DCEA-8066
Serial number: 3495RRB40590BTBE4GV5
Serial number: 3505RRB40590BTBE7OT6
Serial number: 3555YRB405F060GK4GPT
Crash sensor for front airbag: front passenger side:
Serial number: 3565YRB405H060GKP98T
2 Faults Found:
9437211 - Igniter for Driver's Airbag
B1000 1B [137] - Resistance Too High
Fault Priority: 2
Fault Frequency: 1
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
12666368 - Databus
U1122 00 [008] - Implausible Message
Fault Priority: 6
Fault Frequency: 3
Reset counter: 40
Part No SW: 2H0 920 863 A HW: 2H0 920 863 A
Component: KOMBI H05 0304
Coding: 150A00
Shop #: WSC 07456 790 50316
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
VCID: 275DC0CF5EC3CB7C46-8072
2 Faults Found:
12664832 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Fault Priority: 6
Fault Frequency: 1
Reset counter: 0
13635840 - Supply voltage
U1011 00 [008] - Voltage too Low
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 090
Component: GW-K-CAN TP20 H78 0725
Revision: B9078001
Coding: 742200
VCID: 70EFEB93A38DCCC4D7-8024
2 Faults Found:
01336 - Company Data Bus for Comfort System
Fault Priority: 1
Fault Frequency: 21
Reset counter: 40
Time Indication: 0
00381 - Databus Instrument Cluster
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 1
Fault Frequency: 254
Reset counter: 0
Time Indication: 0
Component: IMMO H05 0304
Serial number:
Shop #: WSC 00000 000 00000
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6ADBF9FB8D51361499-803E
Address 32: Differential Locks (J647) Labels:* 2H0-927-771.clb
Part No SW: 2H0 927 771 HW: 2H0 927 771
Component: Quersperre H04 0014
Revision: 11001001 Serial number: 4DG 18.11.10 00
Coding: 000001
ASAM Dataset: EV_QuersUDSAAMVN817 A01005
ROD: EV_QuersUDSAAMVN817.rod
VCID: 6BD5FCFF82AB2F1CE2-803E
1 Fault Found:
12666368 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Fault Priority: 1
Fault Frequency: 4
Reset counter: 40
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Voltage terminal 30: 12.4 V
Voltage at sensor: 1.1 V
Actuator: coil current: 0.0 A
End-------------------------(Elapsed Time: 03:54)--------------------------
www.Ross-Tech.com
8 Faults Found:
P1647 00 [036] - -
Fault Priority: 2
Fault Frequency: 10
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Fault Priority: 2
Fault Frequency: 4
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
U1112 00 [044] - -
Fault Priority: 2
Fault Frequency: 15
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
U1113 00 [044] - -
Fault Priority: 6
Fault Frequency: 8
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
U0164 00 [036] - -
Fault Priority: 6
Fault Frequency: 5
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Fault Priority: 6
Fault Frequency: 5
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
U0146 00 [036] - -
Fault Priority: 6
Fault Frequency: 4
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Fault Priority: 2
Fault Frequency: 1
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Revision: 00H44001
3 Faults Found:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 0
Time Indication: 0
Count: 32768
Count: 4097
Count: 8280
Count: 514
Fault Priority: 6
Fault Frequency: 1
Reset counter: 0
Time Indication: 0
Count: 32768
Count: 4097
Count: 8257
Count: 514
Fault Priority: 2
Fault Frequency: 1
Reset counter: 0
Time Indication: 0
Count: 32832
Count: 4097
Count: 8233
Count: 514
Cannot be reached
Coding: 100000
Coding: 100000
Coding: 100000
Coding: 100000
2 Faults Found:
000 - -
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Fault Priority: 3
Fault Frequency: 1
Reset counter: 0
Time Indication: 0
2 Faults Found:
Fault Priority: 2
Fault Frequency: 1
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
12666368 - Databus
Fault Priority: 6
Fault Frequency: 3
Reset counter: 40
Coding: 150A00
2 Faults Found:
U1111 00 [009] - -
Fault Priority: 6
Fault Frequency: 1
Reset counter: 0
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Revision: B9078001
Coding: 742200
2 Faults Found:
Fault Priority: 1
Fault Frequency: 21
Reset counter: 40
Time Indication: 0
Fault Priority: 1
Reset counter: 0
Time Indication: 0
Serial number:
Coding: 000001
1 Fault Found:
U1111 00 [008] - -
Fault Priority: 1
Fault Frequency: 4
Reset counter: 40
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
I finally have the auto scan. The daylight drl is working but when i turn on the lights the drl stops working! What could be wrong?
If you can see i have a small bulb to check the electricity and it has lowerd in intensity when i turn on the xenon or parking mode it does like the drl should do to lower the intensity.
OMG!...
The first thing you have to do is install the new CAN lines for the instrument cluster.
Two wires from the instrument cluster to the BCM, in this way.
1st step here.
At the moment it is the main problem that is reflected in your Autoscan due to malfunction of almost all units.
1st step here.
Hi Guys.
I'm about to start a headlight bi xenon retrofit for my Amarok Canyon edition -2014
I have tried to gather as much information as possible in this matter on several forums regarding this retrofit, the only problem is that the installation process seems to be different depending on the manufacture year, level of equipment and so on... right now my head is spinning.
It´s pretty clear to me that ciclo and iichel seems to have alot of knowledge in this particular subject
My neighbor has VCDS if you need a autoscan, the number of my BCM module is: 7H0 937 090 B
Thank's in advance!
Thank's in advance!
Ok. Let's start with an autoscan
Of course!
At work right now... Posting autoscan this afternoon
Tuesday,01,October,2019,17:19:05:04550
VCDS Version: 15.7.0.2
Data version: 20150820
www.Ross-Tech.com
VIN: WV1ZZZ2HZEH021491 License Plate:
Mileage: 137340km-85339mi Repair Order:
Chassis Type: 2H (6N0)
Scan: 01 02 03 08 09 10 15 17 18 19 25 32 37 56 69 6C 6E 0B
VIN: WV1ZZZ2HZEH021491 Mileage: 137340km-85339miles
18-Aux. Heat -- Status: OK 0000
32-Differential Locks -- Status: OK 0000
56-Radio -- Status: OK 0000
69-Trailer -- Status: OK 0000
6E-Ctrl Head Roof -- Status: OK 0000
Address 01: Engine (J623-CSHA) Labels: 03L-906-022-CFC.clb
Part No SW: 03L 906 012 AF HW: 03L 907 309 AC
Component: R4 2.0l BTD H24 9977
Revision: 74H24--- Serial number: 00000000000000
Coding: 012A401A233600080001
Shop #: WSC 40190 222 00000
ASAM Dataset: EV_ECM20BTD01103L906012AF 004010
ROD: EV_ECM20BTD01103L906012AF.rod
VCID: 68C6AFB3C27322C2B770AE5-803C
Readiness: 1110 1000
Address 02: Auto Trans (J217) Labels: 0CM-325-025.clb
Part No SW: 2H0 927 158 D HW: 0CM 325 025
Component: 2H0 20RTDIRdW H18 3001
Revision: --H18---
Coding: 000001
ASAM Dataset: EV_TCMAL450211 002011
ROD: EV_TCMAL450211_VN81.rod
VCID: 2E4A19AB2017BCF2BDAC28D-807A
Address 03: ABS Brakes (-----) Labels: None
Part No SW: 2H0 907 379 M HW: 2H0 907 379 D
Component: ESP MK25A XT H44 0111
Revision: 00H44001
Coding: C07324B69A96039624A659AC6F51F0
Shop #: WSC 02310 790 49170
VCID: 3A6225FBEC5F60D2112454D-806E
Address 08: Auto HVAC (J255) Labels: 7E5-907-040.clb
Part No SW: 2H0 907 040 E HW: 2H0 907 040 E
Component: ClimatronicT5 H19 0407
Revision: 00001004
Coding: 0000000002
Shop #: WSC 02310 790 50316
ASAM Dataset: EV_ClimatronicT5 A01003
ROD: EV_ClimaAutoT5Basis_VN81.rod
VCID: 235CF89F7BD5019A2202511-8076
Address 09: Cent. Elect. (J519) Labels: 7H0-937-08x-09.clb
Part No SW: 7H0 937 090 B HW: 7H0 937 090
Component: BCM PQ25 Max4 H74 0712
Revision: B9074001 Serial number: 0571 122142778
Coding: 620002380C210000013806306CCB86D50F81610F60842041300000020003
Shop #: WSC 02310 790 00112
VCID: 2D481EA72D11C76A84A6279-8078
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 160514 05 54 0403
Coding: 02302D
Subsystem 2 - Part No SW: 6R0 959 801 M HW: 6R0 959 801 M Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 002 3322
Coding: 040000
Subsystem 3 - Part No SW: 6R0 959 802 P HW: 6R0 959 802 P Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 002 3322
Coding: 040000
Subsystem 4 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C
Component: E221__MFL-TAS H31 0037
Coding: 820000
Subsystem 5 - Part No SW: 6R0 959 811 D HW: 6R0 959 811 D
Component: J388__TSG_HL 002 3322
Subsystem 6 - Part No SW: 6R0 959 812 D HW: 6R0 959 812 D
Component: J389__TSG_HR 002 3322
1 Fault Found:
00978 - Lamp for Low Beam; Left (M29)
Fault Priority: 3
Fault Frequency: 1
Reset counter: 205
Mileage: 137343 km
Time Indication: 0
Date: 2019.10.01
Time: 17:15:10
Address 10: Park/Steer Assist (J446) Labels: 7E0-919-475.clb
Part No SW: 7E0 919 475 L HW: 7N0 919 475
Component: PARKHILFE 8K H06 0106
Revision: -------- Serial number: 28261413601402
Coding: 318103
ROD: EV_VW75XParkAssis8K_VN81.rod
VCID: 3B6C20FFE365595A0A32591-806E
Component: VW10Airbag00B H07 0013
Revision: -------- Serial number: 003HN00H8KY-
Shop #: WSC 02739 790 50316
ROD: EV_AirbaVW10BPAVN750_VN81.rod
VCID: 337C08DFCB35911AD262E11-8066
Crash sensor for side airbag; driver side:
Serial number: 3495RRB401052JN49OJO
Crash sensor for side airbag; front passenger side:
Serial number: 3505RRB401252JN4AOKK
Crash sensor for front airbag; driver side:
Serial number: 3555YRB401C50RNAEORM
Crash sensor for front airbag; front passenger side:
Serial number: 3565YRB401G50RNA4PD4
Part No SW: 2H0 920 871 HW: 2H0 920 871
Component: KOMBI H04 0709
Coding: 151A00
ROD: EV_Kombi_UDS_VDD_RM09_SE36.rod
VCID: 65D8A68735613FAA8C968F9-8030
Address 18: Aux. Heat Labels: None
Part No: 7E0 819 008 F
Component: J737__Standheizung 0605
Revision: 00086000 Serial number: 09024901A00000
Coding: 0011332
Shop #: WSC 02757 790 00000
VCID: 2C4E13A3160BC26293D8325-8078
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Component: GW-K-CAN TP20 H74 0712
Revision: B9074001
Coding: 742200
VCID: 70F6C7D3FAA3EA82EF00065-8024
Component: IMMO H04 0709
Serial number:
ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
VCID: 6AC2D5BBDC7F10D2A14444D-803E
Address 32: Differential Locks (J647) Labels: 2H0-927-771.clb
Part No SW: 2H0 927 771 A HW: 2H0 927 771
Component: Quersperre H04 0017
Revision: 11001001 Serial number: 4DG 24.03.14 00
Coding: 000001
ASAM Dataset: EV_QuersUDSAAMVN817 A01606
VCID: 2C4E13A3160BCEE293D8325-8078
Address 37: Navigation (J794) Labels: 1K0-035-27x-37.clb
Part No SW: 3C8 035 279 R HW: 3C8 035 279 R
Component: RNS315-EU H80 0500
Serial number: VWZAZ2P0292800
Coding: 000004110200160000031002
ASAM Dataset: EV_RNS315EUV2UDS 001705
ROD: EV_RNS315EUV2UDS.rod
VCID: 3A6225FBEC5F6052112454D-806E
Data medium:
Subsystem 1 - Part No: 3AA 919 866
Component: EUR_W_V6 0062
Address 69: Trailer (J345) Labels: 1K0-907-383-MY8.lbl
Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
Component: Anhaenger H09 0100
Revision: 3A001001 Serial number: 00008200296035
Coding: 010D000100000000
Shop #: WSC 02310 790 00114
VCID: 307607D33A23AA82AF80C65-8064
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 2H0 907 441 HW: 2H0 907 441
Component: J772__Rearview 0020
Revision: 00H13000 Serial number: 525 PA8J432501
Coding: 0030017
VCID: 63DCB89F3B554D1A6282911-8036
Address 6E: Ctrl Head Roof (J702) Labels: None
Part No SW: 7E5 919 037 G HW: 7E5 919 037 G
Component: Dachdisplay H15 0185
Revision: 10100011 Serial number: 338713
Coding: 000203
VCID: 357836C7C5418FAAFC769F9-8060
End-------------------------(Elapsed Time: 03:13)--------------------------
www.Ross-Tech.com
Revision: --H18---
Coding: 000001
Revision: 00H44001
Revision: 00001004
Coding: 0000000002
Coding: 02302D
Coding: 040000
Coding: 040000
Coding: 820000
1 Fault Found:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 205
Mileage: 137343 km
Time Indication: 0
Date: 2019.10.01
Time: 17:15:10
Coding: 318103
Coding: 151A00
Coding: 0011332
Revision: B9074001
Coding: 742200
Serial number:
Coding: 000001
Data medium:
Coding: 0030017
Coding: 000203
