Auto HVAC - 16372 - Control Module; Unspecified Internal Error
maTTew
Drives: 6R 2010 1.4 16V 63kW Highline
Post by maTTew »
I was doing VCDS scan to be shure nothing pops up at emission control (they control OBDII errors at emission control stations). I found one error and do not know what the hell it is. I can not clear the error, it pops up again after clearing wth same values - same kilometers and date, everything. AC works as usual, cooling works. I tried google, ross tech wiki etc and nothing. But the kilometers and date are weird. 2029.14.14?? Now I have 94400km not 93641km..
Anyone pls?
Log-WVWZZZ6RZAY167360.txt
Dnes
18:04
M
Nahráli jste jednu položku
Text
Saturday,14,April,2018,16:36:05:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: WVWZZZ6RZAY167360   License Plate:
Chassis Type: 6R (6N0)
Scan: 01 03 08 09 10 15 17 19 25 44 56 77
56-Radio -- Status: OK 0000
Address 01: Engine        Labels: 03C-906-024-BXW.lbl
   Part No SW: 03C 906 024 BH    HW: 03C 906 024 BH
   Component:       CGGB  MM4HV   8327
   Revision: --H09---    Serial number:
   Coding: 0000071
   Shop #: WSC 73202 133 86446
   VCID: 65C1571FAF941D36075-5072
Readiness: 0000 0000
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 R    HW: 6R0 907 379 R
   Component: ESP8.2i front H04 0002
   Revision: --------
   Coding: 210228E3217300B9842814E884D100401300
   Shop #: WSC 02069 000 00000
   VCID: 4D918FBF1024C5762F5-8018
Address 08: Auto HVAC (J301)       Labels: 6R0-820-045.clb
   Part No SW: 6R0 820 045 E    HW: 6R0 820 045 E
   Component: Climatic       24 0600
   Revision: 00 10 24
   VCID: 306FF64B63D6889E243-8065
1 Fault Found:
            014 - Defective
                    Fault Status: 01101110
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 93641 km
                    Time Indication: 0
                    Date: 2029.14.14
                    Time: 00:28:59
Address 09: Cent. Elect. (J519)       Labels: 6R0-937-08x-09.clb
   Part No SW: 6R0 937 087 D    HW: 6R0 937 087 D
   Component: BCM PQ25 H+4  H46 0207
   Revision: BF046001    Serial number: 0147 013100614
   Coding: 3CB02BBF08A10000003000007D2B0DD80040410F60860000200000000000
   Shop #: WSC 12469 483 00190
   VCID: 3E73D873A9826EEEA6F-806B
   Subsystem 1 - Part No SW: 6R0 959 801 R    HW: 6R0 959 801 R  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  006 0902
   Coding: 08BC30
   Subsystem 2 - Part No SW: 6R0 959 802 T    HW: 6R0 959 802 T  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  006 0902
   Coding: 08BC30
   Subsystem 3 - Part No SW: 6R0 959 811 F    HW: 6R0 959 811 F
   Component: J388__TSG_HL  006 0902
   Coding: 08BC32
   Subsystem 4 - Part No SW: 6R0 959 812 F    HW: 6R0 959 812 F
   Component: J389__TSG_HR  006 0902
   Coding: 08BC32
Address 10: Park/Steer Assist (J446)       Labels: 6R0-919-475.clb
   Part No SW: 6R0 919 475     HW: 6R0 919 475
   Component: PARKHILFE 4K  H07 0008
   Revision: --------    Serial number: 71390935615934
   Coding: 100001
   Shop #: WSC 124697 483 00190
   ASAM Dataset: EV_VW250ParkiAssis2 S01006
   ROD: EV_VW250ParkiAssis2.rod
   VCID: FBF5916772103BC6411-80AE
   Part No SW: 6R0 959 655 D    HW: 6R0 959 655 D
   Component: VW10Airbag008 H09 0018
   Revision: --------    Serial number: 003DX000S9BB
   Coding: 003038
   ROD: EV_AirbaVW10BPAVW250_VW24.rod
   VCID: 4385A987CA600306C91-8016
   Crash sensor for side airbag; driver side:
   Serial number: 3572SRB40000A7CCF91O
   Crash sensor for side airbag; passenger side:
   Serial number: 3582SRB40000A548BA3A
   Crash sensor for side airbag; rear driver side:
   Serial number: 3516GRB402BCA5L92JKC
   Crash sensor for side airbag; rear passenger side:
   Serial number: 3526GRB402N9M2G6U3FU
   Part No SW: 6R0 920 860 D    HW: 6R0 920 860 D
   Component: KOMBI         H03 0205
   Coding: 140E00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
   ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
   VCID: 3561C75F94B4ADB6775-8060
Address 19: CAN Gateway (J533)       Labels: 6N0-909-901-6R.clb
   Part No SW: 6N0 909 901     HW: 6R0 937 087 D
   Component: GW-K-CAN TP20 0207
   Coding: 002200
   VCID: F0EFB64B2356489EE43-80A5
   Component: IMMO          H03 0205
   Serial number:
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03006
   ROD: EV_Immo_UDS_VDD_RM09_VN35.rod
   VCID: EADBA4230D8AB24EAA7-80BF
   Part No: 6R0 423 156 A
   Component: LenkhilfeTRW        V275
   Coding: 10150
   Shop #: WSC 00000
   VCID: 2E53E833EDE29E6E36F-807B
Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 5M0 035 186 AA    HW: 5M0 035 186 AA
   Component: Radio RCD310  016 0049
   Revision: 01000000    Serial number: VWZ1Z2K7015092
   Coding: 0500040002
   VCID: 6BD521278A702B46511-803E
Address 77: Telephone (J738)       Labels: 1K8-035-730.clb
   Part No SW: 1K8 035 730 D    HW: 1K8 035 730 D
   Component: Telefon       H08 6900
   Revision: 00008000    Serial number: 00000329391009
   Coding: 412120
   Shop #: WSC 12345 123 12345
   VCID: 2A5BE423450AF24EEA7-807F
End
Re: Auto HVAC - 16372 - Control Module; Unspecified Internal Error
It's a defective climatronic but if everything works, there is no need to replace the module
maTTew
Post by maTTew »
You mean Climatic right? I disconnected the battery recently, could that be the cause?
I'd guess so, I have seen "stupid" dates before, but I can't remember which car or why - sorry.
I wouldn't take dates to seriously. A 6r doesn't know the date so this info in an error code is useless.
maTTew
Post by maTTew »
How it could be defective and working properly at the same time. I dont get it.
it's defective but not limited in its functionality.
the error is suggesting something like the software isn't fully adding up or a circuit is broken. but you don't notice it.
maTTew
Post by maTTew »
OK, it is this control module, right?
https://www.google.cz/search?q=6R0+820+045+E
It is just the panel with three circle controllers and AC/internal switch? Could this error mean something else? Like faulty fan?
i can't read Chechian but it the part number is OK. the only part at fault is the module.
maTTew
Post by maTTew »
Thanks, I order a new one when the old one completely die.
