Great forum you have here! I am from India.
I recently got a 2015 Polo GT 1.2 TSI DSG (6R/60 "IND")
When watching a YouTube review of the 6C Polo (UK) - LINK - I noticed that the UK Polo 6C has a DRL at the far corners of it's fog-lamps:
I checked the fog lamps in my car, but the section which houses the DRL bulb in the 6C is blanked out and serves no purpose
So I searched around for a replacement set of 6C fog-lamps which has bulbs for both fogs and DRL - I ordered a set from HERE
I received the fog-lamps, and there are 2 bulbs on each one - for fog and DRL.
Can I use my existing BCM to wire these DRLs? Here is the BCM that came with my car:
I searched around the forums and have seen that someone else from India has done this mod - HERE - but I see that car has a higher revision of the BCMAddress 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 6RU 937 087 M HW: 6RU 937 087
Component: BCM IM H+4 H40 0432
Revision: BZ040001 Serial number: 0300 244150128
Coding: 3AB02BBF08A10000003800006C2B04900040414F608C0000200000000000
Shop #: WSC 57837 002 1048576
VCID: 6CDDFAEB8F113724D4-8038
Subsystem 1 - Part No SW: 6R0 959 802 D HW: 6R0 959 802 D Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 002 3424
Coding: 010000
Subsystem 2 - Part No SW: 6R0 959 801 AH HW: 6R0 959 801 AH Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 006 5260
Serial number: 13102579150409033008
Subsystem 3 - Part No SW: 6C0 959 442 HW: 6C0 959 442
Component: E221__MFL-TAT H04 0019
Serial number: 3031401041900134AB1B
Coding: 240000
Subsystem 4 - Part No SW: 6R0 959 811 L HW: 6R0 959 811 L
Component: ------------- 006 5550
Serial number: 13102580140423001653
Coding: 020000
Subsystem 5 - Part No SW: 6R0 959 812 L HW: 6R0 959 812 L
Serial number: 13202581150707055742
Coding: 020000
Thank you for your inputs
