Tom's 6R 1.2 TDI Match to 6C Beats + Component protection Bypass
- Drives: Polo Advance
Re: Tom's 6R 1.2 TDI Match to 6C Beats + Component protection Bypass
amazing work that is relizando.
you could help me?
I have 2 units with active CP and I would like to put them into operation.
How much would you cost $$$?
you already tell me.
greetings and congratulations for the advances
you could help me?
Hi davitio, I'd write it in the following way for a better understanding. (I hope you don't mind my post, I'm just trying to help you)davitio_979 wrote: ↑Sun Mar 17, 2019 8:52 pm amazing work that is relizando.
you could help me?
Amazing job, congratulations for your advances.
Could you please help me? I've two units with active CP and I'd like to deactivate it.
How much do you charge for it? Looking forward for your reply.
Greetings.
Hi Tom, excellent job!
I follow with interest what you do in your 6R Beats.
Hello Ciclo.
Of course I do not care, I'm glad you help me.
I'm sorry for my low level of English.
I have to do it with the translator and I know that the translation is not very correct.
thank you very much Ciclo
- Tombirch95
- Drives: 2011 Polo Match 1.2 TDI
Main bench loom now made and working 100% to simulate how the newer kit works, more parts on order to allow the cross communication of modules but at present not a bad set up.
I’ve designed some software that intercepts signals from devices to allow me to see what’s being transmitted.
On a side note I’ve designed a dongle to work with the software that is a plug and play solution to component protection. It completely isolates any CP packets and disables it across all modules not just infotainment systems.
I’ve attached images before and after my newly modified loom.
Tom
Sent from my iPad using Tapatalk
Tom
- ag69
- Drives: 1.2TSi 77Kw 7DSG
Great test bench !!!
impressed
impressed
- Drives: 6C GTI
this is some great work. really interested in one of these dongles if you eventually sell them.Tombirch95 wrote: ↑Tue Apr 23, 2019 2:14 pm Main bench loom now made and working 100% to simulate how the newer kit works, more parts on order to allow the cross communication of modules but at present not a bad set up.
Tom
Hi Tom
Would it be possible if I send you an Eeprom dump from a 3Q0 035 820 can you remove the CP for me?
How much would this cost, thanks in advance .
Mark
Mark
Hi
Do you still offer the UNits with CP removed for retrofitting in a 6R?
Are you selling this? I would be interested in buying
- Drives: Polo SEL 1.4 tdi 2014
Hi looking to get in touch with Tom to secure a dongle to all me to upgrade to nav and appleplay on my 2014- SEL
No longer required all up and working
Cheers Rob
Cheers Rob
Hi Tom,
Very impressed with your bench kit! You seem to be the guru when it comes to this sort of stuff.
I was wondering if you could help me install a new hu into my eos. I’m happy with the mechanics but don’t really know anything about CP and coding.
