telphone menu polo 6r
- Drives: polo 6r 1.2 tdi
hello everyone, im franklin from holland.(sorry for my bad english)
I have my polo now for 1 year. I modefied my polo a litte.
i put in a fabia instrumet cluster with toledo plates
i put in a stearing wheel from a golf 6
i put in a beatifull blue gt inteurieur
and put in an rns 315 bluetooth dab+.
But one thing is not working. in my instrumet cluster mfa+ i can not get the phone menu active.
with the vcds i acitivatead phone. but its not working. is there somebody who knows the answar?
thank for now
greets franklin
thank for now
greets franklin
Re: telphone menu polo 6r
maybe little bit more information.
Everything is working good in my radio rns 315. calling no problem. bluetooth audio no problem.
when my mfa+ is on radio menu i see when sombody call me! i see this in my display.
greets
greets
Please post a vcds autoscan so we can see your car and its components and configuration.
i have made it. but can not bring it to my other computer. are pix good to?
Tuesday,19,June,2018,19:30:30:39744
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 17.1.3.0
Data version: 20170203 DS267.2
www.Ross-Tech.com
VIN: WVWZZZ6xxxxxxxxxx License Plate: xxxxx
Mileage: 147790km-91832mi Repair Order:
Chassis Type: 6R (6R0)
Scan: 01 03 08 09 15 17 19 25 2E 37 44 56 61 77
VIN: WVWZZZ6Rxxxxxxxxx Mileage: 147790km-91832miles
37-Navigation -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
77-Telephone -- Status: Cannot be reached 1100
Address 01: Engine (J000-CFWA) Labels: 03P-906-021-CFW.clb
Part No SW: 03P 906 021 B HW: 03P 907 425
Component: R3 1.2l TDI H08 9979
Revision: 12006001 Serial number:
Coding: 00114014032401080000
Shop #: WSC 61753 001 1048576
ASAM Dataset: EV_ECM12TDI01303P906021B 001042
ROD: N/A
VCID: 275A20DE5E76547988-8072
No ASAM data for: "EV_ECM12TDI01303P906021B" (VW25)
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AK HW: 6R0 907 379 AF
Revision: --------
Coding: 210224E3417600BA842524E882D300521300
Shop #: WSC 00788 648 00255
VCID: 071A405EB2B67479A8-8052
Address 08: Auto HVAC (J301) Labels: None
Part No SW: 6R0 820 045 G HW: 6R0 820 045 G
Component: Man AC 02 0101
Revision: 0002S 02
VCID: 326CC18A6DB421D12F-8066
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 088 F HW: 6R0 937 088
Component: BCM PQ25 Re4 H50 0351
Revision: BU050001 Serial number: 0456 251110213
Coding: 22B02BBF08A10000002809B06C2B0CD15F80612F7E860441A00000000000
Shop #: WSC 124697 483 00190
VCID: 418E9E46D8128A49A6-8014
Subsystem 1 - Part No SW: 6R0 959 801 R HW: 6R0 959 801 R Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 006 0903
Serial number: KU0-KU004.05.1017913
Coding: 58BC30
Subsystem 2 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 007 1611
Serial number: KU0-KU030.11.1013648
Coding: 48BC30
Subsystem 3 - Part No SW: 3C8 959 537 B HW: 3C8 959 537 B Labels: 3C8-959-537.CLB
Component: E221__MFL-TAP H4ÿ 0021
Serial number: 10000000000000125558
Coding: E20000
2 Faults Found:
03304 - Response Closing Status of Rear Right Door
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 14
Reset counter: 176
Mileage: 147776 km
Time Indication: 0
Date: 2018.06.17
Time: 19:52:35
00901 - Back-Up Lamps
010 - Open or Short to Plus - Intermittent
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 175
Mileage: 147776 km
Time Indication: 0
Date: 2018.06.17
Time: 19:51:58
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Component: VW10Airbag022 H09 0020
Revision: -------- Serial number: 003GX00W0JCT
Coding: 003232
ASAM Dataset: EV_AirbaVW10BPAWV250 A01001
ROD: N/A
VCID: 4A9CB96AED24491177-801E
Subsystem 1 - Serial number: 3575HRB405J0Q3SKGH97
Subsystem 2 - Serial number: 3585HRB405H096J66PST
Subsystem 3 - Serial number: 3515RRB40590NS9OF9G6
Subsystem 4 - Serial number: 3525RRB40590NS9OK1B%
No ASAM data for: "EV_AirbaVW10BPAWV250" (VW25)
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 6R0 920 870 A HW: 6R0 920 870 A
Component: KOMBI H04 0709
Coding: 140800
VCID: 3362C48E9AAE28D924-8066
Address 19: CAN Gateway (J533) Labels: 6R0-907-530-V2.clb
Part No SW: 6R0 907 530 D HW: 1K0 907 951
Component: J533 Gateway H38 0035
Revision: H38 Serial number: 050911F1002705
Coding: 2500C2
VCID: 3460C79297A02FE13D-8060
1 Fault Found:
01303 - Telephone Transceiver (R36)
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 136
Mileage: 147799 km
Time Indication: 0
Date: 2018.06.19
Time: 19:26:59
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Component: IMMO H04 0709
Serial number:
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_DVD_RM09 A03710
ROD: N/A
VCID: 6ADC19EA8DE4A91157-803E
No ASAM data for: "EV_Immo_UDS_DVD_RM09" (VW36 *)
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Component: SG EXT.PLAYER H13 0240
Revision: A1001003 Serial number: 7660848898
Coding: 010000
VCID: 295E26E6406262099E-807C
Address 37: Navigation (J794) Labels: 1K0-035-27x-37.clb
Part No SW: 3C0 035 279 HW: 3C0 035 279
Component: RNS315 H05 0010
Serial number: VWZAZ2L8382725
Coding: 000004010100000000000000
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_NRS315VWEUV1UDS A01005
ROD: N/A
VCID: 60C87BC27BD8E34189-8034
No ASAM data for: "EV_NRS315VWEUV1UDS" (VW36 *)
2 Faults Found:
1048636 - ROD - Unknown Error Code
- 00 [009]
Fault Status: 00000001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 134
Mileage: 147759 km
Date: 2018.06.13
Time: 17:52:18
1048659 - ROD - Unknown Error Code
- 00 [009]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 136
Mileage: 147799 km
Date: 2018.06.19
Time: 19:26:54
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11230
Shop #: WSC 00788
VCID: 2F6AC8FEEA860C3940-807A
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 6R0 907 534 HW: 1K0 907 951
Component: Batt.regelung H38 0035
Coding: 030B1A5A
VCID: 74E00792D7206FE1FD-8020
Subsystem 1 - Part No SW: 6R0 915 181 D HW: 6R0 915 181
Component: J367-BDM H07 0180
Serial number: 00000000008900523030
Address 77: Telephone
Cannot be reached
End-------------------------(Elapsed Time: 02:16)--------------------------
Reason: code tags
Reason: code tags
what happens if you deselect 77 telephone in your CAN gateway?
nothing happens than. the same like now. its not working with 77 on or off. so i realy don't know.
- ag69
- Drives: 1.2TSi 77Kw 7DSG
franklin polo 6r wrote: ↑Tue Jun 19, 2018 11:30 am hello everyone, im franklin from holland.(sorry for my bad english)
thank for now
greets franklin
great franklin
nobody?
@iichiel if i put 77 off. the fold is gone in my gateway. is this what you mean?
als ik m uitzet is mijn foutmelding weg! is dat wat je bedoelde?
I honestly don't know what's going on. You have some interesting errors in the RNS module, that are flagged as unknown.
Probably has something to do with your clone VCDS.
Summary: no clue... sorry mate.
I don't know what these mean, maybe they have something to do with your problem. Or something went wrong in hacking your cluster and converting a Fabia cluster to Polo FW.Address 37: Navigation (J794) Labels: 1K0-035-27x-37.clb
ROD: N/A
2 Faults Found:
- 00 [009]
Fault Priority: 5
Fault Frequency: 1
Reset counter: 134
Mileage: 147759 km
Date: 2018.06.13
Time: 17:52:18
- 00 [009]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 136
Mileage: 147799 km
Date: 2018.06.19
Time: 19:26:54
thanks for your time. realy nice for looking for me.
so i must live with it. no other option.
thnx iichiel
thnx iichiel
- Drives: 6R 2010 1.4 16V 63kW Highline
What BT unit do you have?
Hello good evening. It's still not working. But i have a bluetooth module and cable now. But i installed it in my car but still not working. Can somebody give me the good code for installation .. the coding in the pix is my coding now. Thnx for looking and maybe helping
