Does anyone know the difference between 6r0959772A and 6r0959772D ?
Both are valid part number, A being fitted to 6R and D to 6C
Retrofitting Audi heated seats to 6R and just trying to figure out the difference and which is the best module to use.
Audi use D version throughout the A1.
Difference in heated seat modules
Re: Difference in heated seat modules
I'm using a 6R0959772C and 6R0959772D in my 6R (resp front and rear). I have no issues so far with any of them.
thanks!
How did you wire in rear heated seats?!
same as the fronts really. just different lengths for the wiring loom, otherwise identical.
Great!
Any tips you can provide for wiring the Audi seats, using Kufatec loom in a 6R?
I don't know, sorry.
Do you know what output is provided by bcm to the heated seat module? Is it +12v to activate it?
Just wondering if i can still use the heated seats without connecting and activating the bcm
@iichel
Did you connect the rear seats to the BCM as well?
Or do they work without any BCM connection?
They will work without BCM connection as well, however I did connect them. I think the wire prevents the heater from going on when the battery cannot sustain it yet
- Drives: Polo Beats 2017
hi lichel i see ur a busy man retrofitting your car. i was wondering if it is possible to install heated front seats for my polo 6c 2016? i dont have climatronic. thanks
Yes, certainly that's possible!
