Which lowering springs. Eibach or H&R
john__m
Drives: polo gti 6c
Post by john__m » Tue Oct 16, 2018 10:05 pm
Eibach or h&r springs on polo gti ?
Which is the better choice ?
Dink
Drives: 2015 GTI
Re: Which lowering springs. Eibach or H&R
Post by Dink » Thu Oct 18, 2018 3:19 pm
I have eibach springs fitted to my gti and the ride is better than standard (6c gti)
john__m
Drives: polo gti 6c
Post by john__m » Thu Oct 18, 2018 7:21 pm
Any pics so i can see the height?
H&r do a lower ride height than eibach
Dink
Drives: 2015 GTI
Post by Dink » Fri Oct 19, 2018 8:16 pm
This is with the eibach springs fitted. It's a subtle drop and is about right imho.
Andy1273
Drives: 1.2 tsi polo
Post by Andy1273 » Fri Oct 19, 2018 10:38 pm
The rear looks so much better. By how much did it lower by? Did you purchase a standard kit or a specific type for the height?
Any problems with speed bumps, kerbs, pot holes etc....
Dink
Drives: 2015 GTI
Post by Dink » Fri Oct 19, 2018 10:45 pm
Think eibach only do one drop height for the polo gti and it's around 25mm
I've not had any problems with rubbing or Kerbs.
I didn't want to go to low on the rear as it starts to push the wheel forward and just makes it look broken imho
john__m
Drives: polo gti 6c
Post by john__m » Sat Oct 20, 2018 12:30 pm
Does look better than standard, and probably not as rough a ride as the h&r ones but i do like the lower look
Andy1273
Post by Andy1273 » Sun Oct 21, 2018 10:33 am
I agree does look better than standard.
Where may I ask did you get the springs from? VW and how did you get them fitted, independent garage or at VW?
I presume although you've had them fitted to your GTI they will also fit a 6c TSI?
Dink
Drives: 2015 GTI
Post by Dink » Sun Oct 21, 2018 11:55 am
I got them from a site called autodoc.co.uk (they were the cheapest around) and got a local garage to fit them.
You will struggle to get vw to fit them.
There is a part for lowering springs from vw but they can sometimes be a bit of pain to find.
Andy1273
Post by Andy1273 » Sun Oct 21, 2018 1:11 pm
So do you need this part to be able to fit them? You have a part number?
Dink
Drives: 2015 GTI
Post by Dink » Sun Oct 21, 2018 3:25 pm
No. vw do lowering springs (well they used to) but it's difficult to find the part number. They won't be listed under your vin number
john__m
Drives: polo gti 6c
Post by john__m » Sun Oct 21, 2018 8:07 pm
You can still get them. They are called vw racingline. But ive heard the ride is terrible and they cost a lot more than eibach or h&rs
Dink
Drives: 2015 GTI
Post by Dink » Mon Oct 22, 2018 5:58 pm
I'd read up on what the h&r springs are like for ride quality 😉😁
Alexnesta
Drives: 6R Blue GT
Post by Alexnesta » Mon Oct 22, 2018 7:32 pm
I used Eibach and H&R, with H&R the car was very short and nice but it bounced all the time my car is a 6R Blue GT. After a week of use, Mount Eibach again as the car worked really badly. I bought H&R 35 / 55mm. I sincerely recommend eibach
Eibach:
H&R
Sorry for my english
john__m
Drives: polo gti 6c
Post by john__m » Mon Oct 22, 2018 8:34 pm
Looks good
