Polo 6r bluemotion BCM's problem
roby293
Drives: Polo 6R Bluemotion 1.2 TDI
Post by roby293 »
Hi to all!!
This forum is great, I like it!!
I'm here because my Polo is crazy...Unfortunately I can't solve my problem, so I did a scan with VCDS.
This is my log.
Friday,19,October,2018,20:44:42:39744
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86
VCDS Version: 17.1.3.0
Data version: 20170220 DS267.3
www.Ross-Tech.com
VIN:   License Plate:
Mileage: 155310km-96505mi   Repair Order:
Chassis Type: 6R (6R0)
Scan: 01 03 08 09 15 17 19 25 44 61
VIN: WVWZZZ6RZBY129884   Mileage: 155310km-96505miles
Address 01: Engine (J000-CFWA)       Labels: 03P-906-021-CFW.clb
   Part No SW: 03P 906 021 B    HW: 03P 906 021 B
   Component: R3 1.2l TDI   H04 9978
   Revision: 12004001    Serial number:
   Coding: 00114014032401080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM12TDI03103P906021B 001041
   ROD: EV_ECM12TDI03103P906021AA.rod
   VCID: 275A20DE5E76547988-8072
1 Fault Found:
15916 - Cylinder 1 Glow Plug Circuit (Q10)
          P0671 00 [088] - Electrical Fault
          Intermittent - Confirmed - Not Tested Since Memory Clear
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 8
                    Mileage: 155305 km
                    Date: 2018.10.18
                    Time: 08:41:57
                    Engine speed: 855.75 /min
                    Normed load value: 18.4 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 21 °C
                    Intake air temperature: 24 °C
                    Ambient air pressure: 980 mbar
                    Voltage terminal 30: 11.773 V
                    Unlearning counter according OBD: 0
                    Sensor for engine block temperature: raw value: 21 °C
                    Electric auxiliary heater: relay activation: 0
                    Glow status: 08
                    Outside air temperature: 20 °C
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AJ    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210224E3416F00BB842D24EA82D500521300
   VCID: 06044D5AB5BC6D71D3-8052
Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AP.clb
   Part No SW: 6R0 820 045 J    HW: 6R0 820 045 J
   Component: Climatic       25 0660
   Revision: 00 11 25
   VCID: 3566FA969CDA36E90A-8060
Address 09: Cent. Elect. (J519)       Labels: 6R0-937-08x-09.clb
   Part No SW: 6R0 937 088 B    HW: 6R0 937 088
   Component: BCM PQ25 Re4  H46 0321
   Revision: BU046001    Serial number: 0328 277100749
   Coding: 24B02BBF08A10000002007B07C6B9CD08F88000F7E8E0041200000000000
   Shop #: WSC 124697 483 00190
   VCID: 3D76E2B6A4EAEEA9C2-8068
   Subsystem 1 - Part No SW: 6R0 959 801 R    HW: 6R0 959 801 R  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  006 0903
   Serial number: KU0-KU027.09.1012816
   Coding: 58BC30
   Subsystem 2 - Part No SW: 6R0 959 802 T    HW: 6R0 959 802 T  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  006 0902
   Serial number: KU0-KU005.10.1016484
   Coding: 48BC30
5 Faults Found:
03430 - Terminal 30 for Turn Signals and Brake Lights
            011 - Open Circuit - Intermittent
                    Fault Status: 00101011
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 186
                    Mileage: 155305 km
                    Time Indication: 0
                    Date: 2013.03.09
                    Time: 00:37:42
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 186
                    Mileage: 155305 km
                    Time Indication: 0
                    Date: 2013.03.09
                    Time: 00:37:42
00329 - Control Circuit for Unlocking Rear Lid
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 186
                    Mileage: 155311 km
                    Time Indication: 0
                    Date: 2013.03.10
                    Time: 21:55:58
03396 - Supply voltage terminal 30 for central locking
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 186
                    Mileage: 155311 km
                    Time Indication: 0
                    Date: 2013.03.10
                    Time: 21:55:58
00532 - Supply Voltage B+
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 186
                    Time Indication: 0
   Component: VW10Airbag00G H09 0020
   Revision: --------    Serial number: 003GX0098FDB
   Coding: 003047
   VCID: 4A9CB96AED24491177-801E
   Serial number: 3572SRB40000CC0498BE
   Serial number: 3582SRB40000CC0D02FD
   Serial number: 3515RRB404T02CB8A1PD
   Serial number: 3525RRB406702CBC1GK%
   Part No SW: 6R0 920 861 F    HW: 6R0 920 861 F
   Component: KOMBI         H04 0304
   Coding: 540800
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
   VCID: 3878F3A283C8CB8111-806C
1 Fault Found:
10485833 - Internal Control Module Memory Check Sum Error
          B2000 49 [137] - Internal electronic failure
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 76526 km
                    Date: 2014.02.22
                    Time: 17:34:38
Address 19: CAN Gateway        Labels: 6R0-907-530-V1.clb
   Part No SW: 6R0 907 530 B    HW: 1K0 907 951
   Component: J533  Gateway   H28 0020
   Revision:   H28       Serial number: 240910F1002494
   Coding: 7D021C00080000000002
   VCID: 326CC18AADB421D12F-8066
   Component: IMMO          H04 0304
   Serial number:
   Shop #: WSC 00000 000 00000
   VCID: 6ADC19EA8DE4A91157-803E
   Part No: 6R0 423 156 B
   Coding: 11230
   Shop #: WSC 00788
   VCID: 2F6AC8FEEA860C3940-807A
Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
   Part No SW: 6R0 907 534     HW: 1K0 907 951
   Component: Batt.regelung H28 0020
   Coding: 030B1A5A
   VCID: 74E00792D7206FE1FD-8020
   Component: J367-BDM  H07 0125
   Serial number: 00000000002790060482
End-------------------------(Elapsed Time: 01:59)--------------------------
I hope someone can help me to find and solve all of that problems.
Big thanks.
Re: Polo 6r bluemotion BCM's problem
What exactly are the problems you are experiencing?
roby293
Post by roby293 »
The "real" problems are these:
- when I turn the key, the on-board computer gives me this message "error", but it don't say me what it's the error, only text "error",
- then the light check lamp lights up, but everything works,
- when I turn on the light switch: the dimmer, the light of the window, and the light of the cigarette lighter, doesn't work...
But all of the components works.
The instrument panel itself reports an internal electrical failure
The check engine light could be caused by the glow plug
The dimmer could be broken or the wire from BCM to the dimmer. Do you have a multimeter?
I'd recommend:
- Make an autoscan, clear all DTC's (on the left panel)
- Drive the car for a bit, couple of days of normal use
- Make new scan, see what returns. All errors are intermittent, so they don't appear all the time. This way we can see what really needs to be done.
Check the status of terminal 58 in the BCM (advanced measurement values, scroll for something like this). Does the radio/AC panel light red when you put the headlihts on?
If this is OK and if you have the chance, check the wire from BCM connector T73b (white) pin 1 to the dimmer pin 3. Make sure it's not broken, check for continuity with a multimeter.
roby293
Post by roby293 »
Huge thanks, i'll try.
For now I tried to pull out the dimmer but the headlight regulator motor works.
Maybe tonight I post a video because it's more esplicative.
Anyway radio works, but I have an Alpine and the backlights work.
The only backlights that work are on-board computer, radio and AC.
You could perhaps measure the voltage on pin 3 of the dimmer with headlights on. Should be 12v+
roby293
Post by roby293 »
Thank you very much.
This is a video of what I got https://drive.google.com/open?id=1byoak ... Z5Imn29eQ7
Tomorrow I will try to measure pin 3 of the dimmer.
If I help you, this problem is born in this way:
I buy a new switch light with a brightness sensor to have "AUTO" light, then with VCDS I activate the function "light sensor" or some similar but I can't remember the number of the byte. After the message "coding accepted" I have the problem that I write above.
I tried to deactivate the function but nothing changed.
Have a look on your c:\ross tech\vcds\debug\codinglog.txt.
If possible, paste the contents here. If you know when it happened, the correct bcm coding is in there.
This BCM coding will solve your problems in the BCM. Copy and paste with accuracy, that is, without spaces when copying.
24B02BBF08A10000002005B07C6B9CD08F88610F7E8E2041200000000000
Added the "Coming Home" function (semi-automatic function). :)
At first, do not install the light switch with the non-original light sensor. Then do what you think is convenient ...
roby293
Post by roby293 »
iichel wrote: Sun Oct 21, 2018 8:44 am Have a look on your c:\ross tech\vcds\debug\codinglog.txt.
Tried but I don't have this file, only "Readme.txt"
Anyway I don't tried with a tester to measure the pin 3 of the dimmer. I tried to "see" if the dimmer receiving the current with a bulb. The results was that the dimmer don't receiving current, so I connected a +12v to the pin 3 of the dimmer, and it works. But I don't want to solve in this way because the on-board computer give me always the check light error and the message "error" like the video I uploaded on my GDrive above.
ciclo wrote: Mon Oct 22, 2018 4:37 am This BCM coding will solve your problems in the BCM. Copy and paste with accuracy, that is, without spaces when copying.
Thanks, I will try this and post the result!!
I hope to solve it in the easiest way, because not even my electrician managed to solve the problem.
EDIT: Ciclo, huge thanks!!! After paste the code, I got a "coding accepted" message and all work again!!! Unbelievable!!!
