Page 4 of 5
Re: Lane Change Assist (Side Assist) Installation to Polo 6R 2012 1.2TSI 77kW RHD
Posted: Thu Jun 13, 2019 8:23 pm
by danikd
Address 17: Instruments (J285) Labels:| 1Sx-920-xxx-17.clb-SRI1
Part No SW: 1ST 920 870 A HW: 1ST 920 870 A
Component: KOMBI H05 0008
Revision: X0005001 Serial number: 00000000000000
Coding: 114A010000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_KombiUDSMM9RM10 A05808
ROD: EV_KombiUDSMM9RM10_A05_VW12.rod
VCID: 530898D89FB40E4985-8006
Many thx for any clue ... Daniel
Posted: Thu Jun 13, 2019 11:19 pm
by Adam87
Does the Beetle cluster not fit? It looks very similar
Posted: Fri Jun 14, 2019 2:24 am
by benzinkopf
As mentioned before. I think (referring to my radar version), BSD is really standalone and as I’m following the installation setup like the Audi Q7, the system get its own switch On button. Before I get to enable the menu inside the MFD, I can already switch on the system with the button. And now(with the help of Madwarlock), inside the coding, i can only either have the switch using the button OR change to the MFD menu which makes the button not function. Since the MFD control is only available when the car is stationary, i decided to use the button instead. Only the brightness settings i use the MFD which is also optional since you can adjust the brightness using the vcds anyway.
Posted: Fri Jun 14, 2019 8:40 am
by danikd
Many thx, I belive in you and this forum, I find many inspiration here and people here are very kind.
And thx to Adam87, great find, its seem same and Beetle has BSD ... BUT, its change form Skoda to VW cluster from different car possible?
Its must be adoptet at dealer service, no problem, friend works here, but it must be online and dont know if it can be done ...
Many thx guys!
Posted: Fri Jun 14, 2019 3:16 pm
by danikd
Official online at dealer its impossible, online detect different HW ID and refuse adopting ... so maybe anyone unofficialy offline ... but dont know who
Posted: Fri Jun 14, 2019 4:34 pm
by iichel
It's certainly possible but you'll need people that do this for a hobby or a living. Perhaps madwarlock or spacewalker could help out?
Posted: Fri Jun 14, 2019 7:03 pm
by danikd
I study New Beetle and only function tahat Citigo ahsnt is BDS system ...No High Beam Assist I hope ... So there are two variants :
1) 7E0 BSD System, as Benzinkopf has :
12pin connector - enabling by button from Q7 or I find better shapped A6 button - 4F0927451
Pros : cheaper, works standalone operated by button, no need to change instrumet cluster
Cons : need calibration ( no autocalibration )
, no rear traffic alert on MIB2 units( or it support?), which is main advantage for me
2) 5Q0 BSD System
8pin connector - enabling only via Maxidot, no pins for button
Pros : BSD 3.0, rear trafic allert, autocalibration
Cons : More expensive, need to change instrument cluster to Beetle = very very expensiv if possible
So I am sad ...
Calibration of 7E0 units is possible via VCDS or VCP ? Because officialy via ODIS probably not ...
Posted: Fri Jan 03, 2020 11:19 pm
by RobertVW
I am afraid calibration is possible with Odis plus Doppler simulator only, but if you use second hand radars you don't have to calibrate at all.
Your used radars have been calibrated with the donor vehicle and there is no need to repeat that process.
Posted: Sat Jan 04, 2020 4:24 am
by benzinkopf
Till now, i still got the missing calibration error because i havent try the calibration again after able only to calibrate one radar with vcds. the other radar im not sure why. But the system works no issue till now. so i’m just let it be. maybe i will look into 2nd/3rd gen like Madwarlock did and combine with Discovery Media and MQB pdc, we will be able to have both Side Assist and Rear Cross Traffic Alert.
Posted: Sat Jan 04, 2020 9:10 am
by iichel
I have a couple of 7E0 C units somewhere and if I remember correctly, they can be activated from the MFD and button. Not sure if they auto calibrate.
Posted: Sat Jan 04, 2020 12:10 pm
by benzinkopf
which model are you using now iichel if its not 7e0 C ?
Posted: Sun Mar 22, 2020 8:51 pm
by RobertVW
Has anyone managed to complete the retrofit of 5Q0 BSD System with RTA(rear traffic alert) on PQ25 platform vehicle? I am in the middle of getting this installed on my T6.
Posted: Sun Mar 22, 2020 11:47 pm
by benzinkopf
if i’m not mistaken madwarlock did that with Discovery Media+PDC module from MQB. You may want to search in Drive2.ru for his logbook.
Posted: Wed Mar 25, 2020 10:08 pm
by RobertVW
Thank you Benzinkopf.
Posted: Tue Apr 14, 2020 6:47 am
by Rlinegrey
Wow absolutely amazing retrofit! Did not know that this was possible on a 6R
