6R 2010, metal pins for Quadlock and fusebox
Posted: Sun Mar 10, 2019 8:57 am
by exantas
Does anybody know the code/type of the metal pins that are used for the oem radio quadlock on 2010 6R polo?
I am looking the codes for both male and female pins.
Also does anybody know the codes for the female pins used on the fuse box under the steering wheel?
I looking the female pins for locations 1-24 and 25-60
Theo
Posted: Sun Mar 10, 2019 9:24 am
by iichel
Quadlock: Junior power timer
1-24: Junior power timer
25-60: Standard power timer
https://www.a4-freunde.com/showwiki.php ... uebersicht
Re: 6R 2010, metal pins for Quadlock and fusebox
Posted: Sun Mar 10, 2019 11:08 am
by exantas
Thank you for the quick reply
Re:
Posted: Thu Mar 14, 2019 1:32 pm
by Dink
Can you recommend a decent crimper for these?
I'm looking to install a few things in my car and would like to use the correct parts.
Posted: Fri Mar 15, 2019 3:44 am
by ciclo
Posted: Fri Mar 15, 2019 12:02 pm
by Dink
No good for me far too small only goes up to AWG 18 which is like 1mm2 which is where I'd like it to start.
Posted: Fri Mar 15, 2019 1:05 pm
by Lktuning
Re: Re:
Posted: Fri Mar 15, 2019 5:58 pm
by ciclo
... a decent crimper
... and would like to use the correct parts.
Posted: Mon Mar 18, 2019 5:20 am
by pranaynewton
Has any one used this crimp tool instead of the Laser Tools 3932 for removal of fuse female crimps from the holder?
http://www.farnell.com/datasheets/15813 ... 1552885682
Also facing some issues in removing the female crimps from the fuse box for an upgrade. Does anyone have a manual / instruction sheet on fuse box female crimp replacement?
Posted: Mon Mar 18, 2019 6:57 am
by ciclo
There are better and worse tools, but none is the best and none is the worst, it depends largely on personal skills, ... well, sometimes also to be lucky that the terminal is not caught in the plastic due to pulling from the wire with excessive force.
Some time ago I was half an hour of attempts to remove a terminal from the BCM white connector. :lol:
There is a procedure explained in ELSAwin (also in my guide for automatic lights), although it is not definitive ...
These tools help a lot:
Posted: Mon Mar 18, 2019 7:05 am
by ciclo
Posted: Mon Mar 18, 2019 9:55 am
by joe6
This company has many electrical components including connectors and crimp tools http://www.vehicle-wiring-products.eu/
Re:
Posted: Tue Apr 02, 2019 8:41 pm
by exantas
Does somebody know the correct crimper size for these connectors ? ^
I bought this plier that say 26AWG-16AWG (0,5 - 1 - 1,5 mm^2) but the metal pins don't look to fit in the biggest crimper
