1.2 TDI CFWA Idle issue
evgenkoshevoy
Drives: Polo 6R, 1.2 TDI
Post by evgenkoshevoy »
I have a problem with idle on a warm engine.
here's a graph with normal idle
but sometimes idle turn to this
and how it sounds like
Tombirch95
Drives: 2011 Polo Match 1.2 TDI
Re: 1.2 TDI CFWA Idle issue
Post by Tombirch95 »
Its possible the DPF needs to be regenerated, mine used to do this when I first bought it, puzzled me at first till I regenerated the DPF, I used to just do about 20 miles a day so seen this quite allot.
You can buy a DPF cleaner spray where you remove the exhaust temp on the top of the DPF (when cold) then give it a 20 minute run should clean the system out.
Could also be the fuel you use, I only use shell Vpower combined with “millers diesel power ecomax” from Amazon never seen this issue since. Hope this helps
Sent from my iPad using Tapatalk
evgenkoshevoy
here, in Ukraine were sold without a particulate filter.
