gti 1.8 engine noise
get a weird tapping/rattling type noise from the engine which is quite loud it’s only when idling any clues??
- l3rady
- Drives: Polo GTI+ 2019
Re: gti 1.8 engine noise
Does the noise increase if you bring up the revs?
Could be a number of issues such as a worn part, or could be that your oil pressure is low. Check your oil levels as if there isn't enough oil then the upper part of the valve train might not be getting enough oil.
cheers for the reply! it’s only when it’s idling it’s fine when i rev or drive normally
- Drives: GTI 6c 1.8 TSI DSG 2016
Loose exhaust or heat guard perhaps?
it’s not the exhaust it’s been swapped out it’s definitely engine noise
- Drives: 2015 GTI
HPFP? that can make a tapping noise
- Jay-Jay
- Drives: Polo 6R HL 1.2TSI 77kw, Audi S1 MY2018
If you could post a video, it would be easier for everybody to better understand and help you.
