Patil's little Polo 6R 1.2 Tsi Dsg7 RHD
patil
Re: INSTALLING DIRECT TPMS IN POLOGT 6R RHD IND
Post by patil »
Update regarding tpms installation:
I installed maxidot cluster, changed BCM from 087M to 087AD, installed sensors ,tpms module wired and coded.
TPMS display failed to appear on cluster :oops:
VCDS autoscan shows tyre pressure status ok. The tpms module detects the sensor position, current pressure under measured values in address 65 but fails to display on cluster. :roll:
Here is the latest autoscan after tpms installation.
Tuesday,25,June,2019,04:13:51:09269
VCDS Version: 19.6.0.2 (x64)  HEX-V2 CB: 0.4505.4
Data version: 20190529 DS308.0
www.Ross-Tech.com
VIN: MEXL15606GT048293   License Plate:
Chassis Type: 60-VW25 (6R0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 44 56 65
VIN: MEXL15606GT048293   Mileage: 42600km-26470miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZB)       Labels:. 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 KC    HW: 03F 907 309 AJ
   Component: SIMOS10.22AH10 6270
   Revision: --H10---    Serial number: 00000000000000
   Coding: 00250056232400080000
   Shop #: WSC 53863 002 1048576
   ASAM Dataset: EV_ECM12TFS02103F906070KC 004006
   VCID: 6D84C0CEAD13BD3F117-8038
Readiness: 0110 0101
Address 02: Auto Trans        Labels: 0AM-927-769.clb
   Part No SW: 0AM 300 065 N    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 6502
   Revision: 00043014    Serial number: CU501508317273
   Coding: 0000020
   Shop #: WSC 01260 002 1048576
   VCID: 3A2E3B92A05DDA87C45-806E
   Part No SW: 6R0 907 379 BN    HW: 6R0 907 379 AS
   Component: ESP9.0i front H03 0001
   Serial number: --------------
   Coding: 62DD2463422703C8461624724254C0800908
   Shop #: WSC 29230 002 1048576
   VCID: 0B40AE56B3C7130FAF3-805E
   Serial number: 10051504650275
   Coding: 01
   Shop #: WSC 00000 000 00000
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EA6F782F07536A7B8D-802A
   Part No SW: 6R0 907 044 Q    HW: 6R0 907 044 Q
   Component: Climatronic   H12 0615
   Revision: V0000000
   VCID: 41DC4C7EC18B895F85F-8014
   Part No SW: 6R0 937 087 AD    HW: 6R0 937 087 AD
   Component: BCM PQ25 H+4  H42 0452
   Revision: BF042001    Serial number: 5400 033190412
   Coding: 3AB02BFF08A10000003800C07C2B9490F0C041FF608C0000200000000000
   Shop #: WSC 12345 123 12345
   VCID: 7F580A86F7FF3FAFB3B-802A
   Subsystem 1 - Part No SW: 6R0 959 802 BH    HW: 6R0 959 802 BH  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  003 8612
   Serial number: KU0KU015041441050460
   Coding: 1400B3
   Subsystem 2 - Part No SW: 6R0 959 801 BC    HW: 6R0 959 801 BC  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  003 8612
   Serial number: KU0KU014041441047765
   Coding: 0400B3
   Subsystem 3 - Part No SW: 6C0 959 442     HW: 6C0 959 442
   Component: E221__MFL-TAT  H04 0019
   Serial number: 1971517275001536AB2B
   Coding: 240000
   Subsystem 4 - Part No SW: 6R0 959 811 L    HW: 6R0 959 811 L
   Component: -------------  006 5550
   Serial number: 13102580150623202239
   Coding: 020000
   Subsystem 5 - Part No SW: 6R0 959 812 L    HW: 6R0 959 812 L
   Serial number: 13202581150812164218
   Coding: 020000
2 Faults Found:
            011 - Open Circuit
                    Fault Status: 01101011
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 42603 km
                    Time Indication: 0
                    Date: 2019.06.25
                    Time: 00:35:38
03432 - Activation of Right Parking Light
            011 - Open Circuit
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 42603 km
                    Time Indication: 0
                    Date: 2019.06.25
                    Time: 00:35:38
   Part No SW: 7E0 919 475 J    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0105
   Revision: --------    Serial number: 28261224902578
   Coding: 108101
   Shop #: WSC 02756 790 50316
   VCID: 392C249EA9DBD19FCDF-806C
   Revision: --------    Serial number: 003GW0118WCJ
   Coding: 003036
   Shop #: WSC 01234 785 00200
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 49CC545EF93B411F5DF-801C
   Part No SW: 6RD 920 870 A    HW: 6RD 920 870 A
   Component: KOMBI         H05 0805
   Coding: 140C01
   Shop #: WSC 00046 123 12345
   VCID: 47C85266EF2FB76F4BB-8012
   Part No SW: 6R0 909 901     HW: 6R0 937 087 AD
   Component: GW-K-CAN TP20 H42 0452
   Revision: BF042001
   Coding: 002300
   VCID: 74B2D5AACEB96CF7DE9-8020
   Component: IMMO          H05 0805
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A8ECBD29CFDAA07745-803E
   Part No SW: 1S2 909 144 P    HW: 1S2 909 144 P
   Component: EPS_ECU       H61 1702
   Coding: 0001000000000000
   ROD: EV_SteerAssisNSK_014.rod
   VCID: 41DC4C7EC10B895F85F-8014
   Part No SW: 6RD 035 187 A    HW: 6RD 035 187 A
   Component: MIB2-S-R-CN   025 0210
   Revision: -----001    Serial number: 01855GD0000318
   Coding: 00000440010001
   Shop #: WSC 00081 790 00118
   VCID: 45D4586ED5A3A57FB97-8010
   Serial number: 40000000058983
   ROD: EV_RDKBERU30_005.rod
   VCID: 372822A69FCFC7EF3BB-8062
End----------(Elapsed Time: 01:10, VBatt start/end: 13.7V/13.8V)-----------
2 fault codes remain in central electricals after swapping the BCM.
I wonder what am I missing :roll:
Hi patil
Easy:
1(mandatory)
You must make the file with the data you want for the tyres of your car with the RDKS program/editor and load/transfer them with VCP or ODIS-E in 65 Address so that the pressures and menu can be visualized in your New IC/display.
viewtopic.php?f=56&t=58703&start=3645#p525012
2
New BCM coding
3AB02BFF08A10000003800C07C2B9490F0C0414F608C0000200000000000
Namaste :D
It's fantastic that these BCM High PQ25 support TPMS. :wink: :lol:
patil
Post by patil »
ciclo wrote: Wed Jun 26, 2019 6:46 am Hi patil
Easy:
1(mandatory)
2
New BCM coding
Namaste :D
Thanks a lot, as usual you are a Master troubleshooter. :D
After spending just shy of 1000€ for this entire installation, I felt nervous for a moment when tpms display didn't appear on cluster :|
I don't have VCP nor ODIS-E, have to find a way out to get hold of one of these. Here some retro fitters are quoting ridiculously high price(130€ ) :shock: :shock: to just fill in the parametric file into module which I have already prepared.
Master, after adding the new BCM code provided by you, the fault codes disappeared but bulb out warning appeared on new IC. MY non OEM headlights are working correctly with all functions like before, even in presence of those 2 fault codes. :mrgreen:
Well, try this coding for your NO OEM headlights.
3AB02BFF08A10000003800C07C2B9490F0C0414D608C0000200000000000
Supposedly, the fault is with the new LED side lights. Either low or high consumption.
Good luck!
To transfer the TPMS data your best option is ODIS-E.
Buy the VAS5054 from ali... , and install the ODIS-E program (under W7).
Install the ODIS-E 9.0.4 from here :arrow: https://www.drive2.ru/l/526851338487726178/
Pleaaaase :lol: make a small donation, worth it, and it's fair. 8)
patil
Post by patil »
ciclo wrote: Tue Jul 02, 2019 9:23 am To transfer the TPMS data your best option is ODIS-E.
Master Namaste.
Today, I transfered the TPMS data into the module via ODIS-E with the help from Govind Sharma. The data set writing was successful, but then again, the TPMS display failed to display on IC. :oops:
I checked with VCDS after that, TPMS module status is ok , measured values are displaying sensor position and tyre pressures correctly.
Really frustrating to not to see the TPMS display on IC inspite of correct installation. :(
I don't understand, where is the missing link. :roll: I have started to think, whether the BCM high 087AD fully supports direct TPMS. :roll:
For all who have installed BCM Max, direct TPMS is displaying on IC for them. Should I try BCM Max and check? for that then, I need to do BCM wiring for Max.
Was setted the dataset file for ODIS?
or
I do not know where the missing link is, maybe you're the first one trying the Direct TPMS with BCM High. The result has a great relevance.
Life is full of many frustrations ... I think I will die without seeing a human on Mars. :lol:
patil
Post by patil »
Yes, data set file was set for ODIS. I checked it again, I used skodapilot software. should I try another software?
Master your sense of humor. :mrgreen:
I do not know. Try it.
It is possible that the data is not sent from the Gateway to the IC through the powertrain CAN line (your current installation)... and as you have thought the BCM Max is needed with the new CAN lines for the IC (T73b 54,57). That you had in mind from the beginning of this thread.
patil
Post by patil »
I tried with other software just now, no luck still the same.
Should I try with BCM Max? I have 090D with me.
Yes, but in this test you must add the new CAN lines for the IC with the new BCM Max and isolate the old powertrain CAN lines for IC.
It is explained in many tutorials I did for others, I think you already know how to do it.
Well, as this is a simple test to try to run your TPMS in your New IC, some new faults will appear in the autoscan with the new BCM Max due to your NO-OEM headlights and Chinese automatic light kit, ... for now do not worry about them, we will try to solve them later in the cheapest way for you.There is a way to wire your new BCM Max, fuse box and 17-pin connector in OEM way, without the need to install original headlights or the automatic lighting system, but it is likely that you have to assume some faults in the VCDS autoscan although the lights work correctly.
patil
Post by patil »
Finally, finally, the Max did the magic. :mrgreen: The much awaited TPMS menu appeared on the IC, after installing BCM Max. :D
The tyre pressures are read correctly on IC, and I could able to load parametric data as per my liking.
I could able to activate driver alert also through ODIS-E, my heartfelt thanks to Govind Sharma for sending me his VAS 5054 and helping me with all this.
I wonder, what was the problem with BCM High 087AD, may be the gateway(incompatible SW, HW to support Direct TPMS) was unable to feed the required data to IC, as you said Master.
Many questions remain, nevertheless, a lesson learned hard way, we all fall to rise again! 8)
Now coming to the issues faced after installing BCM Max, VCDS threw lot errors as expected.
Following functions are not working now:
1. Reverse lights, reverse camera (mine is aftermarket license plate camera).
2. Cornering lights not working( with both steering and turn light indicator stalk), fogs are working though.
3. 8k OPS display not working, but sensors are working.
Rest all other functions are working, including the dimmer switch.
I wish to wire the BCM Max properly oem way with adaptation, Master your help is paramount here. I also wish to retain my present non oem healights and chinese auto light module.
VCDS auto scan and pictures below.
Tuesday,09,July,2019,19:50:26:09269
www.Ross-Tech.com
Chassis Type: 60-VW25 (7E0)
VIN: MEXL15606GT048293   Mileage: 42750km-26563miles
10-Park/Steer Assist -- Status: Cannot be reached 1100
65-Tire Pressure -- Status: Cannot be reached 1100
   Coding: 0000020
   Coding: 01
   Revision: V0000000
   Part No SW: 7E0 937 090 D    HW: 7E0 937 090 D
   Component: BCM PQ25 Max4 H82 0762
   Revision: B9082001    Serial number: 8601 222180475
   VCID: 2C020DCA56097437469-8078
   Coding: 1400B3
   Coding: 0400B3
   Coding: 240000
   Coding: 020000
   Coding: 020000
4 Faults Found:
            011 - Open Circuit
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 42759 km
                    Time Indication: 0
                    Date: 2019.07.09
                    Time: 00:44:19
            011 - Open Circuit
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 42759 km
                    Time Indication: 0
                    Date: 2019.07.09
                    Time: 00:44:19
01516 - Terminal 30; Left
            011 - Open Circuit
                    Fault Priority: 3
                    Fault Frequency: 3
                    Reset counter: 0
                    Mileage: 42759 km
                    Time Indication: 0
                    Date: 2019.07.09
                    Time: 00:33:20
00927 - Terminal 30 (Right)
            011 - Open Circuit
                    Fault Priority: 3
                    Fault Frequency: 3
                    Reset counter: 0
                    Mileage: 42759 km
                    Time Indication: 0
                    Date: 2019.07.09
                    Time: 00:33:20
   Coding: 108101
   Coding: 003036
   Coding: 140C01
   Part No SW: 7E0 909 901     HW: 7E0 937 090 D
   Component: GW-K-CAN TP20 H82 0762
   Revision: B9082001
   Coding: 002300
   VCID: 688AB1DA82719817621-803C
2 Faults Found:
03075 - Parallel Parking Assistance Control Module (J791)
            004 - No Signal/Communication
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 42759 km
                    Time Indication: 0
                    Date: 2019.07.09
                    Time: 00:34:07
01325 - Control Module for Tire Pressure Monitoring (J502)
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 42759 km
                    Time Indication: 0
                    Date: 2019.07.09
                    Time: 00:34:07
2 Faults Found:
02873 - Control Module for Back-Up Camera (J772)
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 42759 km
                    Time Indication: 0
                    Date: 2019.07.09
                    Time: 00:34:34
01327 - Control Module for Parking Aid (J446)
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 42759 km
                    Time Indication: 0
                    Date: 2019.07.09
                    Time: 00:34:32
End----------(Elapsed Time: 01:11, VBatt start/end: 12.2V/12.2V)-----------
Allow me a time of meditation to help you with all this ... please be patient. You already know that I will try the best for you.
I will get in touch with you by private message as soon as possible, after my meditation process. :)
Between one or two months everything that is possible will be solved. (SP-IND)
Namaste
patil wrote: Wed Jul 10, 2019 6:17 pm 3. 8k OPS display not working, but sensors are working.
Have you tried to Reset/Reboot your radio system?
patil
Post by patil »
I tried rebooting the Radio, OPS is not displaying still. All 8 sensors are working with beep and dash switch gets lit whenever OPS is activated but no display.
Take your time Master, I will wait till you get free time to help me, no problem. I hope your meditation sessions will be enjoyable and relaxing. :D
