INSTALLING DIRECT TPMS IN POLOGT 6R RHD IND
ag69
Drives: 1.2TSi 77Kw 7DSG
Re: INSTALLING DIRECT TPMS IN POLOGT 6R RHD IND
Post by ag69 »
very nice.
patil
Drives: polo6r/tsi 77kw/DSG7
Post by patil »
ciclo wrote: Sun Sep 13, 2020 6:56 pm Top! 8) 8)
Enjoy it.
Thank you dear Ciclo master:)
It's not prefectly working yet.. perfectifying :mrgreen:
    ag69 wrote: Mon Sep 14, 2020 5:33 pmvery nice.
    Thank you. :wink:
    Sample video:
    Drives: 6R Rline/G7.5/Touareg Rline'19/T-Cr'20
    I never let trucks pass me, I only let it to delivery vans ... :lol:
    patil
    Post by patil »
    New Mod: MQB PLA 2.0 8K Auto active park pilot :mrgreen:
    I bought new module 5Q0 919 294L with 3 to 2 conversion adapter harness for plug and play installation. The new module was flashed with firmware 1K8 919 472C along with necessary parameter using VCP. :wink:
    Coded the module for Polo6R using VCDS, and the result:
    Activated Park pilot in IC, with new menu:
    Rear traffic alert(RTA) now works with additional beep along with colored warning display of moving object on reverse. With previous PQ 7E0 8K module, there was only display without warning beep.
    I really like the way new module works. Parking sensors are autoactivated with OPS display overlaying+ dash button glowing, if obstacle is/are detected upto 20km/hr of vehicle speed.
    If obstacles are detected in both front and back, there is no cacophony from both front and back speakers, only obstacle nearest to sensors will buzz, distracting the driver less. :lol:
    Music play also automutes if front sensors are in red zone, really liked this feature. The dash button is now essentially only for beauty :mrgreen:
    In picture below, obstacle at both front and back. only front sensors buzzing, rear sensors grey out silently:
    8) :wink:
    Another nice upgrade Patil! 👌
    We could say that your 6R is a PQ25+. (like many other 6Rs around the world)
    Automatic front OPS activation is great ... I mean, everything we've gotten to be automatic on the PQ25 is great. 8)
    patil
    Post by patil »
    ciclo wrote: Mon Oct 12, 2020 4:46 am Another nice upgrade Patil! 👌
    Thank you for your appreciation Master.
    Interesting designation for my 6R...PQ25+ :mrgreen: I liked it. 8)
    Even though the new module is working perfectly functionality wise, an error is hanging in address 10. I tried with different coding combinations, but the error refuses to go. :?
    I couldn't decipher the exact meaning of the error.
    Such error:
    J527 is the electronic steering column control unit.
    I assume the new PDC unit which is for a different platform than the PQ25 expects to receive the data from the BCM---G85 sensor on the powertrain CAN lines, which in turn I assume will show the directional lines (the vehicle path) on screen 5F.
    It seems that this new unit is not receiving data correctly from the BCM PQ25. :lol:
    Disable the 'Vehicle Path Display' on the PDC control unit if you have it enabled. Byte1 Bit5
    https://vagcode.info/components/78c8aa1 ... c43fa.html
    Another thing I can think of (and maybe it's stupid :mrgreen:), ... what if you enable Byte24 Bit4 in your BCM?
    Drives: Polo 6R 1.2 TDI
    Looks great Patil, very nice job. Do you think this will work on the old rns510 as well or only on the newer discover media unit?
    patil
    Post by patil »
    ciclo wrote: Tue Oct 13, 2020 1:33 am J527 is the electronic steering column control unit.
    Logical explanation Master!!
    I think our PQ25 steering column control unit has no required HW/SW to communicate with new module I think, the same goes with ABS unit. Today I saw 2 new errors in 5F related to error which is hanging in address 10( didn't click photos, will do it tomorrow and post here). I will try to dig more in adaptation channels of 5F related to park assist.
    I didn't enable vehicle path display at all knowing that it will not work on our PQ 25.
    I enabled Byte24 Bit4 in BCM, still error hangs.
    It looks like there are many reports of same error posted in many forums after installing such module on PQ 25 platform.. like Skoda Rapid, T6 multivan etc..
    This is my current coding for address 10: 0001151011
    patil
    Post by patil »
    iichel wrote: Tue Oct 13, 2020 9:15 am Looks great Patil, very nice job. Do you think this will work on the old rns510 as well or only on the newer discover media unit?
    Thanks iichel🙏
    Yes the module will work on RNS/RCD 330/340.
    For RNS/RCD, BAP 3.3 Protocol should be selected in Byte2.
    For Discover/ Composition media, BAP 4.0 protocol should be selected in Byte2.
    jor86yeh
    Drives: POLO 6R
    Post by jor86yeh »
    ciclo wrote: Thu Sep 19, 2019 10:58 am
    patil wrote: Wed Sep 18, 2019 4:09 pm ... and other people who relentlessly worked to make this possible in our 6R Maxidot IC. 8)
    +1 8)
    It has been shown that it is possible with KessV2 and with FGtech Galleto for 1.2 TSI CBZ. :lol:
    Hi ciclo ,my polo is 6R 2011 1.4 85HP CGGB+DSG7
    I already have 870A cluster
    Can it activate Gra_high in my polo?
    Hello, you must contact firegrafik, perhaps he can tell you how to activate it or who you should contact.
    I suppose it is possible with an emulator for your 6R 1.4 CGGB, not by activation in the ECU.
    ag69
    Post by ag69 »
    patil wrote: Sun Oct 11, 2020 10:58 pm New Mod: MQB PLA 2.0 8K Auto active park pilot :mrgreen:
    8) :wink:
    Very nice!!
    ag69
    Post by ag69 »
    + 1 (of many)
    patil
    Post by patil »
    Thank you ag69. 😊
    I must give credit to Slavik for his excellent posts about both BSD and MQB auto park mod on D2. His post was an inspiration to me to pursue similar mods. :wink:
    Slavik, if you are reading this post, I would like to thank you with heartfelt gratitude.🙏
    Namaste.
