Well, despite not having the Autoscan of your 6R BlueGT but because I have a huge amount of them I send you the 7E0 BCM/Gateway already coded and ready to work. The only thing someone will have to do with the VCDS cable is Matching your remote controls.
These are the codings already installed:
Gateway
Coding
002104
Installation list
01 03 04 08 09 10 15 17 19 25 2E 44 56 61
7E0 BCM
Coding
3CB029B808E12400B3280FB06CEB9ED05FC0612F608C20C1200400020000
Installation process
- Remove the original steering wheel. (according to Elsawin, erWin ... battery ground wire)
- Remove 7H0 BCM.
- Install the wiring for automatic lights. (According to instructions
viewtopic.php?f=56&t=73828&start=15#p562353)
- Install the wires that are necessary for the installation of 7E0 BCM. (According to instructions
viewtopic.php?f=56&t=73828&start=30#p562939)
- Install 7E0 BCM.
- Install GT MFSW.
* Keep in mind the instructions in the slip ring window to avoid problems with the inner cable.
https://servimg.com/view/18943939/870
- Matching the remote controls.
- Code the GT MFSW: Coding A4FFFF
BCM Adaptation
Channel 001: Remote Control Matching
1st Remote control
Start Matching new/additional Remote Controls by entering
0 for the New Value, then [Test] and [Save] the New Value.
Press and hold the Unlock button for at least one second on the Remote Control you want to add, the Blinkers will light up to confirm the Adaptation Process of each Remote Control.
2nd Remote control
Please, report the results or incidents to solve them.
