Polo 6R 09 1.4 85KM
Re: Polo 6R 09 1.4 85KM
Ah yes, installation of G85
OEM:
T41/5 goes to SB20 (red/yellow)
T41/6 goes to SB9 (blue/black)
If there is space, you can splice to these wires. I expect that there are already wires going to these fuses.
dcgumis
Post by dcgumis »
iichel wrote: Wed May 06, 2020 1:32 pm Ah yes, installation of G85
OEM:
thank you, yes, I have Sat 20 cables I have a Ciclo cable ;-) I'm a bit lost🤪
dcgumis
Post by dcgumis »
OEM:
thank you, yes sb 20 and sb 9, I have Sb 20 cables I have a Ciclo cable ;-) I'm a bit lost🤪Can I use SB 58?
You can connect T41/5 to SB58 in this case. That will also work.
dcgumis
Post by dcgumis »
Thank you for your help iichel :D
I did the installation according to Ciclo instructions :D In 03 ABS I can not calibrate the steering wheel sensor in the basic settings an error appears.
after selection
Bit 21-2.7
Bit 12-6
Bulb failure warning is also active on the instrument clusters.It may not work with ABS without ESP, or I have too old cable. :roll:
Wednesday,06,May,2020,19:09:14:05031
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
www.Ross-Tech.com
VIN: WVWZZZ6RZAY   License Plate:
Chassis Type: 6R (7E0)
Scan: 01 03 08 09 10 15 17 19 25 37 44 55 56
VIN: Mileage: 173390km-107739miles
56-Radio -- Status: OK 0000
Address 01: Engine
Cannot be reached
Address 03: ABS Brakes (J104)       Labels: None
   Part No SW: 6R0 907 379 AC    HW: 6R0 907 379 AC
   Component: ABS8.2 front  H04 0001
   Revision: --------
   Coding: 200228E3016F00B2042C14E280D800000200
   Shop #: WSC 02069 123 12345
   VCID: 7F0A9BD3EAEEDBC624-802A
Address 08: Auto HVAC (J30˙˙)       Labels: 6R0-820-045-9AP.clb
   Part No SW: 6R0 820 045     HW: 6R0 820 045
   Component: Climatic       23 0500
   Revision: 00 09 23
   VCID: 6BD25F838A96576698-803E
Address 09: Cent. Elect. (J519)       Labels: None
   Revision: B9080001    Serial number: 0771 014162029
   Coding: 3DB02BB828F3240092380010FC2B1DD00BC0670F608530C1200000030000
   Shop #: WSC 02737 022 00190
   VCID: 68D8208F9B607C7EF5-803C
   Subsystem 1 - Part No SW: 6R0 959 801 H    HW: 6R0 959 801 H  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  002 0803
   Coding: 08BC30
   Subsystem 2 - Part No SW: 6R0 959 802 K    HW: 6R0 959 802 K  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  002 0803
   Coding: 08BC30
   Subsystem 3 - Part No: 1K8 951 171 A
   Subsystem 4 - Part No: 1K8 951 605
   Component: LIN BACKUP HO  H09 9002
   Subsystem 5 - Part No: 1K8 951 171 A
   Subsystem 6 - Part No SW: 1K8 959 442     HW: 1K8 959 442
   Component: E221__MFL-DC1  H04 0103
   Coding: A4FFFF
   Subsystem 7 - Part No SW: 6R0 959 811 B    HW: 6R0 959 811 B
   Component: J388__TSG_HL  002 0803
   Coding: 08BC32
   Subsystem 8 - Part No SW: 6R0 959 812 B    HW: 6R0 959 812 B
   Component: J389__TSG_HR  002 0803
   Coding: 08BC32
1 Fault Found:
01134 - Alarm Horn (H12)
            000 -  -
                    Fault Status: 01100000
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 31
                    Mileage: 173392 km
                    Time Indication: 0
                    Date: 2020.05.06
                    Time: 19:01:55
Address 10: Park/Steer Assist (J446)       Labels: 7E0-919-475.clb
   Part No SW: 7E0 919 475 L    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0106
   Revision: --------    Serial number: 28231602503915
   Coding: 100001
   Shop #: WSC 35759 001 104857
   ROD: N/A
   VCID: 3B72AFC3B27607E648-806E
No ASAM data for: "EV_VW75XParkAssis8K" (VW25)
   Part No SW: 6R0 959 655 C    HW: 6R0 959 655 C
   Component: VW10Airbag005 H09 0018
   Revision: --------    Serial number: 003DW003YHK-
   Coding: 003035
   Shop #: WSC 124697 483 00190
   ROD: EV_AirbaVW10BPAVW250_SE25.rod
   VCID: 428CD227D59C762E0B-8016
   Crash sensor for side airbag; driver side:
   Serial number: 3572SRB40000911C8A98
   Crash sensor for side airbag; front passenger side:
   Serial number: 3582SRB4000091185980
   Crash sensor for side airbag; rear; driver side:
   Serial number: 3516GRB401V9F7IH9SA3
   Crash sensor for side airbag; rear; passenger side:
   Serial number: 3526GRB40219F7IH1K1-
   Part No SW: 6R0 920 870 B    HW: 6R0 920 870 B
   Component: KOMBI         H05 0607
   Coding: 140E00
   Shop #: WSC 00788 648 00255
   ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
   VCID: 346084FF9F28C89E89-8060
   Revision: B9080001
   Coding: 042200
   Component: IMMO          H05 0607
   Serial number:
   Shop #: WSC 00000 000 00000
   ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
   VCID: 6ADC5A878D6C4E6EE3-803E
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 R    HW: 1T0 035 680 R
   Component: RNS-MID       H24 6276
   Revision: AB001001    Serial number: VWZ6Z7S0418589
   Coding: 00010000010000A00001
   Shop #: WSC 01357 011 00200
   VCID: 3D76A1DBA46209D676-8068
   Subsystem 1 - Part No: 1T0 919 859 C
   Component: EU East V15  8522
   Part No: 6R0 423 156 A
   Component: LenkhilfeTRW        V275
   Coding: 10150
   Shop #: WSC 00000
   VCID: 2E549697ED04E24EFF-807A
Address 55: Headlight Range (J431)       Labels: 6R0-907-357.clb
   Part No SW: 6R0 907 357 C    HW: 6R0 907 357 B
   Component: AFS-ECU       005 0050
   Revision: --------    Serial number: --------------
   Coding: 0D4D000001000000
   Shop #: WSC 12345 123 12345
   ROD: EV_HeadlRegulVWLWRCC.rod
   VCID: 3A7CAAC7BD4C3EEE53-806E
Address 56: Radio
Cannot be reached
End-------------------------(Elapsed Time: 03:08)--------------------------
The bits and bytes are for cornering lights. You can put them back.
Did you select 04 in the CAN gateway installation list? Can you open the module with VCDS?
dcgumis
Post by dcgumis »
iichel wrote: Wed May 06, 2020 7:12 pm The bits and bytes are for cornering lights. You can put them back.
YES 04 CAN gateway installation list
I can't see it after entering the Select module.
Only when I make Autoscan can I enter Steering Angle I have too old cable.I am thinking about buying OEM VCDS, I have bought OEM VCP for now :D
What happens if you write 04 in the bottom (direct entry) and select GO in the 'select module' screen?
dcgumis
Post by dcgumis »
iichel wrote: Wed May 06, 2020 7:23 pm What happens if you write 04 in the bottom (direct entry) and select GO in the 'select module' screen?
Hi iichel :D , I bought OEM VCDS,There is a very big difference between OEM and clone :D :D now I can see 04 control tables in module 04.
In 04 basic settings, I cannot calibrate the sensor because you must have an access code.
Whereas 03 ABS
basic settings in group 060 I write that it is not available
In the evening I will try to do it
"[Select]
[03 - ABS Brakes]
[Security Access - 16]
Enter 40168
[Do It!]
Turn steering wheel full lock to lock then center out so front wheels are straight ahead, steering wheel is level.
[Basic Settings - 04]
[IDE02284-ENG98502] Steering angle sensor: carry out zero calibration
[Go!]
I believe you should get a message of "Finished Correctly".
[Stop]
[Done, Go Back]"
thank you for help :D
dcgumis
Post by dcgumis »
dcgumis wrote: Tue May 12, 2020 11:34 am
Whereas 03 ABS
"[Select]
[03 - ABS Brakes]
Enter 40168
[Do It!]
[Go!]
[Stop]
[Done, Go Back]"
I did as above, unfortunately I do not see the G85 sensor in ABS. :) There are no errors in automatic scanning :D It looks like it works :?: :roll:
Wtorek,12,Maj,2020,22:06:01:12281
VCDS -- Emulator VAG/VAS pracujący w środowisku Windows, uruchomiony na Windows 7 x64
Wersja VCDS: AKP 19.6.2.1  HEX-V2 CB: 0.4508.4
Wersja danych: 20200101 DS308.0
www.vcds.pl
VIN: vwvwvw Numer rejestracyjny:
Typ podwozia: 6R-VW25 (7E0)
Skanowanie: 01 03 04 08 09 10 15 17 19 25 37 44 55 56
VIN: WVWZZPrzebieg: 173450km
01-Silnik -- Stan: OK 0000
03-ABS/hamulce -- Stan: OK 0000
04-Kąt skrętu kierow. -- Stan: OK 0000
08-Klimatyzacja -- Stan: OK 0000
09-Centr.zesp.elektr. -- Stan: Usterka 0010
10-Asyst.park./kierow. -- Stan: OK 0000
15-Airbag -- Stan: OK 0000
17-Zest.wskaźników -- Stan: OK 0000
19-CAN Gateway -- Stan: OK 0000
25-Immobiliser -- Stan: OK 0000
37-Nawigacja -- Stan: OK 0000
44-Wsp.kierownicy -- Stan: OK 0000
55-Zasięg świateł -- Stan: OK 0000
56-Radio -- Stan: OK 0000
Adres 01: Silnik
Nie może być osiągnięty
Adres 03: ABS/hamulce (J104)       Plik etykiet: Brak
   Oznaczenie elementu SW: 6R0 907 379 AC    HW: 6R0 907 379 AC
   Komponent: ABS8.2 front  H04 0001
   Weryfikacja: --------
   Kodowanie: 200228E3016F00B2042C14E280D800000200
   Kod serwisu: WSC 02069 123 12345
   VCID: 7F5B06D127BF836FB0C-802A
Nie znaleziono błędów.
[b]Adres 04: Kąt skrętu kierow. (G085)       Plik etykiet:* 6R0-959-654.clb
   Oznaczenie elementu SW: 6R0 959 654     HW: 6R0 959 654
   Komponent: LENKW.SENSOR  H06 0070
   Numer seryjny: 19121204650811
   Kodowanie: 01
   Kod serwisu: WSC 12345 123 12345
   Zbiór danych ASAM: EV_LWSKLOVW25X 005001
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EA5FBD520758A67BBA-802A
Nie znaleziono błędów.[/b]
Adres 08: Klimatyzacja (J30˙˙)       Plik etykiet: 6R0-820-045-9AP.clb
   Oznaczenie elementu SW: 6R0 820 045     HW: 6R0 820 045
   Komponent: Climatic       23 0500
   Weryfikacja: 00 09 23
   VCID: 6B83C28143870FCF0C4-803E
Adres 09: Centr.zesp.elektr. (J519)       Plik etykiet:. 7E0-937-BCM-V1.clb
   Oznaczenie elementu SW: 7E0 937 090     HW: 7E0 937 090
   Komponent: BCM PQ25 Max4 H80 0736
   Weryfikacja: B9080001    Numer seryjny: 0771 014162029
   Kodowanie: 3DB02BB828F3240092380010BC2B1DD00BC0670F600530C1200000030000
   Kod serwisu: WSC 02737 022 00190
   VCID: 6889BD8D527124D7616-803C
   Podsystem 1 - Oznaczenie elementu SW: 6R0 959 801 H    HW: 6R0 959 801 H  Plik etykiet: 6R0-959-801.CLB
   Komponent: J386__TSG_FT  002 0803
   Numer seryjny: KU0-KU016.06.0911474
   Kodowanie: 08BC30
   Podsystem 2 - Oznaczenie elementu SW: 6R0 959 802 K    HW: 6R0 959 802 K  Plik etykiet: 6R0-959-802.CLB
   Komponent: J387__TSG_BT  002 0803
   Numer seryjny: KU0-KU019.06.0912110
   Kodowanie: 08BC30
   Podsystem 3 - Oznaczenie elementu: 1K8 951 171 A
   Komponent: DWA-Sensor 00  001 0103
   Kodowanie: 000000
   Podsystem 4 - Oznaczenie elementu: 1K8 951 605
   Komponent: LIN BACKUP HO  H09 9002
   Kodowanie: 000000
   Podsystem 5 - Oznaczenie elementu: 1K8 951 171 A
   Kodowanie: 000000
   Podsystem 6 - Oznaczenie elementu SW: 1K8 959 442     HW: 1K8 959 442
   Komponent: E221__MFL-DC1  H04 0103
   Numer seryjny: 29190000541900099111
   Kodowanie: A4FFFF
   Podsystem 7 - Oznaczenie elementu SW: 6R0 959 811 B    HW: 6R0 959 811 B
   Komponent: J388__TSG_HL  002 0803
   Numer seryjny: KU0-KU015.06.0913043
   Kodowanie: 08BC32
   Podsystem 8 - Oznaczenie elementu SW: 6R0 959 812 B    HW: 6R0 959 812 B
   Komponent: J389__TSG_HR  002 0803
   Numer seryjny: KU0-KU015.06.0914644
   Kodowanie: 08BC32
Znaleziono 1 błąd:
01134 - Syrena alarmu (H12)
            000 - -
             Ramka zamrożona:
                    Stan błędu: 01100000
                    Priorytet błędu: 6
                    Częstość błędu: 1
                    Wew.licznik błędów: 44
                    Przebieg: 173453 km
                    Wskaźnik czasu: 0
                    Data: 2020.05.12
                    Czas: 22:02:55
Adres 10: Asyst.park./kierow. (J446)       Plik etykiet:| 7E0-919-475.clb
   Oznaczenie elementu SW: 7E0 919 475 L    HW: 7N0 919 475
   Komponent: PARKHILFE 8K  H06 0106
   Weryfikacja: --------    Numer seryjny: 28231602503915
   Kodowanie: 100001
   Kod serwisu: WSC 35759 001 104857
   Zbiór danych ASAM: EV_VW75XParkAssis8K 001003
   VCID: 3B2332C173E75F4FDC4-806E
Adres 15: Airbag (J234)       Plik etykiet:| 5K0-959-655.clb
   Oznaczenie elementu SW: 6R0 959 655 C    HW: 6R0 959 655 C
   Komponent: VW10Airbag005 H09 0018
   Weryfikacja: --------    Numer seryjny: 003DW003YHK-
   Kodowanie: 003035
   Kod serwisu: WSC 124697 483 00190
   Zbiór danych ASAM: EV_AirbaVW10BPAVW250 A01001
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 42DD4F25140D2E879F2-8016
   Czujnik zderzenia bocznej poduszki bezp.po stronie kierowcy:
   Numer seryjny: 3572SRB40000911C8A98
   Czujnik zderzenia bocznej poduszki bezp.po stronie pasażera:
   Numer seryjny: 3582SRB4000091185980
   Czujnik zderzenia bocznej poduszki bezp.z tyłu po str.kierowcy:
   Numer seryjny: 3516GRB401V9F7IH9SA3
   Czujnik zderz.bocznej poduszki bezp.z tyłu po str.przedn.pasaż.:
   Numer seryjny: 3526GRB40219F7IH1K1-
Adres 17: Zest.wskaźników (J285)       Plik etykiet:| 5K0-920-xxx-17.clb-SRI1
   Oznaczenie elementu SW: 6R0 920 870 B    HW: 6R0 920 870 B
   Komponent: KOMBI         H05 0607
   Numer seryjny: 00000000000000
   Kodowanie: 140E00
   Kod serwisu: WSC 00788 648 00255
   Zbiór danych ASAM: EV_Kombi_UDS_VDD_RM09 A04716
   VCID: 343119FD5EB990371DE-8060
Adres 19: CAN Gateway (J533)       Plik etykiet:. 7E0-909-901.clb
   Oznaczenie elementu SW: 7E0 909 901     HW: 7E0 937 090
   Komponent: GW-K-CAN TP20 H80 0736
   Kodowanie: 002200
Adres 25: Immobiliser (J334)       Plik etykiet:| 5K0-920-xxx-25.clb
   Oznaczenie elementu SW: 5K0 953 234     HW: 5K0 953 234
   Komponent: IMMO          H05 0607
   Numer seryjny:
   Kodowanie: 000000
   Kod serwisu: WSC 00000 000 00000
   Zbiór danych ASAM: EV_Immo_UDS_VDD_RM09 A03709
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A8DC7854CFD16C7772-803E
Adres 37: Nawigacja (J0506)       Plik etykiet:. AKP\1T0-035-680.clb
   Oznaczenie elementu SW: 1T0 035 680 R    HW: 1T0 035 680 R
   Komponent: RNS-MID       H24 6276
   Weryfikacja: AB001001    Numer seryjny: VWZ6Z7S0418589
   Kodowanie: 00010000010000A00001
   Kod serwisu: WSC 01357 011 00200
   VCID: 3D273CD96D73517FE20-8068
   Podsystem 1 - Oznaczenie elementu: 1T0 919 859 C
   Komponent: EU East V15  8522
Adres 44: Wsp.kierownicy        Plik etykiet: 6Q0-423-156.clb
   Oznaczenie elementu: 6R0 423 156 A
   Komponent: LenkhilfeTRW        V275
   Kodowanie: 10150
   VCID: 2E050B95B955BAE76BA-807A
Adres 55: Zasięg świateł (J431)       Plik etykiet:. 6R0-907-357.clb
   Oznaczenie elementu SW: 6R0 907 357 C    HW: 6R0 907 357 B
   Komponent: AFS-ECU       005 0050
   Weryfikacja: --------    Numer seryjny: --------------
   Kodowanie: 0D4D000001000000
   Zbiór danych ASAM: EV_HeadlRegulVWLWRCC 002006
   VCID: 3A2D37C57CDD6647C72-806E
Adres 56: Radio (J0506)       Plik etykiet:. AKP\1T0-035-680.clb
Koniec (Skanowanie trwało: 01:39, Napięcie akumulatora - na początku skanowania / przy końcu skanowania: 12.1V/11.8V. VIgn 11.8V)
I guess, I don't really speak Polish...
Easiest way to check is to try your cornering lights
dcgumis
Post by dcgumis »
iichel wrote: Wed May 13, 2020 10:18 am I guess, I don't really speak Polish...
Hello :D :D
I am sorry now I have in my language VCDS :D :P
The cornering lights do not come on.In position 03 abs the g85 sensor is not visible.so it probably won't work for me :roll:
after selection
Bit 21-2.7
Bit 12-6
Bulb failure warning is also active on the IC.
Wednesday,20,May,2020,14:47:35:12281
VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4508.4
www.Ross-Tech.com
VIN: WVWZZ  License Plate:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 25 37 44 55 56
VIN: WVWZ   Mileage: 173810km-108000miles
Address 01: Engine
Cannot be reached
   Revision: --------
   VCID: 7F5B06D127BF83632A1-802A
   Component: LENKW.SENSOR  H06 0070
   Serial number: 19121204650811
   Coding: 01
   VCID: 7EA5FBD520758A6B217-802A
   Revision: 00 09 23
   VCID: 6B83C28143870FC3969-803E
   VCID: 6889BD8D527124DBFBB-803C
   Serial number: KU0-KU016.06.0911474
   Coding: 08BC30
   Serial number: KU0-KU019.06.0912110
   Coding: 08BC30
   Serial number: 29190000541900099111
   Coding: A4FFFF
   Serial number: KU0-KU015.06.0913043
   Coding: 08BC32
   Serial number: KU0-KU015.06.0914644
   Coding: 08BC32
1 Fault Found:
            000 - -
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 62
                    Mileage: 173813 km
                    Time Indication: 0
                    Date: 2020.05.20
                    Time: 14:45:28
   Coding: 100001
   VCID: 3B2332C173E75F43469-806E
   Coding: 003035
   VCID: 42DD4F25140D2E8B05F-8016
   Coding: 140E00
   VCID: 343119FD5EB9903B873-8060
   Revision: B9080001
   Coding: 042200
   Serial number:
   VCID: 6A8DC7854CFD16CBEDF-803E
Address 37: Navigation (J0506)       Labels:. 1T0-035-680.clb
   VCID: 3D273CD96D73517378D-8068
   Coding: 10150
   Shop #: WSC 00000
   VCID: 2E050B95B955BAEBF17-807A
   VCID: 3A2D37C57CDD664B5DF-806E
Address 56: Radio (J0506)       Labels:. 1T0-035-680.clb
End----------(Elapsed Time: 01:39, VBatt start/end: 13.5V/13.6V)-----------
[/codde]
Pipefoto
Drives: Vw polo 1.6 TDI
Post by Pipefoto »
Hi, I wanted to know where I can buy the automatic lights cable kit. Thank you.
Pipefoto
Post by Pipefoto »
ciclo wrote: Fri Dec 06, 2019 1:51 pm Hi Piotrek, thanks for sharing the images of your 6R.
You will have a nice 6R RED when you finish the installations, LED headlights, R-line bumpers, etc ... 8)
Your wiring looms 'B': viewtopic.php?f=62&t=69223&start=105#p563747
:arrow: The installation guide, download the PDF document.
I will send you a private message to contact me by email. (soon, wait a little please :wink: )
I mean this Thank you
dcgumis wrote: Wed May 20, 2020 2:54 pm
They will work for you when the SCLs wiring is installed correctly. You can be absolutely sure. :wink: :lol:
I wonder if you installed the wiring for automatic lights. :?: :?: :?:
According to iichel's instructions for installing the SCLs wiring, he is referring to the T17 connector of the old light switch, and it is not correct with the automatic lights wiring.
On the other hand, I notice that you do not want to have the automatic lights activated in the BCM coding. :?: :shock:
Note:
You cannot make any kind of correction, modification, calibration, basic setting or adaptation of your new G85 retrofitted sensor in YOUR ABS unit ---> WITHOUT ESP system .. no problem for this reason. Your ABS unit is not involved in the operation of SCLs at all. (G85 and BCM only)
However, you can check with VCDS if the steering wheel angles (steering column) reach the BCM at the advanced values ​​(or meas values). If the angle values ​​change when you move the steering wheel, the installation of your new G85 sensor ring is correct. Which is correct according to your last Autoscan.
Good to know that the TinyQ parameterization worked correctly for your AFS unit (6R Europe).👍
